Televison & Video Logo
Anonymous Posted on Jun 06, 2012
I have replaced the p board and sc boards in this panasonic tc-p50s30 viera tv and still have the 7 red blinks? what else can be wrong?
I have replaced the p board and sc board in this tv and the power light still blinks 7 times? what else can be the problem and do i have to reset the tv somehow?
Anonymous
Level 3:
  • Master 1,238 Answers
  • Posted on Jun 07, 2012
Anonymous
Master
Level 3:
Answers
1238
Questions
0
Helped
329682
Points
3603
7 blinks is indicate for faulty power supply however if you already replace it the possible problem is on main board..
5 Related Answers
djchillsnyc
charlie rodriguez
  • 152 Answers
  • Posted on Oct 14, 2009
SOURCE: panasonic viera tv won't turn on. Power light
hello, you have a either your su, sd or sc boards fualty and it is a driver sos1 thats what the manual reads the best thing to do if your not electronically inclined or able to fix it is to get a service manual and make sure it is for your specific model and size you will find what the 7 blink codes mean, on my side i have a 42 in pana the service manual for this set and your is similar so since it is not the same model i cant tell you exactly what the truoble is but your best bet is to find a service manual find the 7 blink fualt then without getting ripped off you will know what the service man needs to do if you dont know or cant replace the parts yourself that is besides having to download firmware from your computer to a sd card and update your set but you need to solve the blinking code first it may solve the entire issue. the tv should come on when you resolve the blink codes or replace the fualty board or boards
Anonymous
  • 458 Answers
  • Posted on Nov 10, 2009
SOURCE: Panasonic Viera TH-42PV7HS Plasma does not turn
replaced su or sd board and check sc board
Chi Chu
  • 8457 Answers
  • Posted on Jun 22, 2010
SOURCE: plasma 50 inches dont turn on
The power supply board is dead.Tries the websites like Shopjimmy.com,Ebay.com to buy the refurbish power supply board for the replacement.
Anonymous
  • 1779 Answers
  • Posted on Dec 27, 2010
SOURCE: My brand new Panasonic Viera
Jeff, do the right thing! Exchange it for a different brand !
Anonymous
  • 4889 Answers
  • Posted on Mar 04, 2011
SOURCE: Panasonic th-50pz85u: TV will not
10 blinks error code is definitely due to a malfunctioning A-board. Since you have already replaced it, the only possibilities are
1)Either you have obtained a malfunctioning replacement OR
2)You did not get the correct revision version. Not that the same model number of the tv can use different sets of parts. That is why it is always recommended to order by part number. I have had a customer recently who had a similar problem and it turned out to be incorrect version of the replacement board. So check the part number of the replacement and the original . Also compare the revision versions of both and see if everything matches. Please let me know what you found.
Panasonic viera TC-P50S30. no power no blinking lights. Solid red light. Black screen.p
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
https://electronicshelponline.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary. /
1helpful
My Panasonic plasma tv model tc-p50s30 has 14 blinking lights I tested the SU and SD boards and they are good
Are you sure its not 7 blinks then a pause and 7 more as according to the service manual the blink codes for a TV like yours only goes to 12
Flashing red light on tv
Depend flashing code ,
7 blinks Sc board bad
10 blink power board bad
No picture and power light blinks 7 times on my viera tc-p50st30 plasma tv when it is turned on
That can be caused by either the SC or SD board. Contact the people at www.tvrepairworld.com they can assist with proper diagnosis and they also should have the replacement board
3helpful
7 blinking Red Light. Power Supply problem??
Need replaced su.sd and sc board
Panasonic TXNSC1RKTUS SC BOARD BOARD, SCAN DRIVE ASSY
Panasonic TXNSU1RKTU SU BOARD BOARD, UPPER SCAN OUT ASSY
Panasonic TXNSD1RKTU SD BOARD BOARD, LOWER SCAN OUT ASSY
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
