Question about Toshiba 51H84 51" Rear Projection HDTV-Ready Television
Dim screen... Purchased the TV in Fall of '05, in Fall of '06 the screen began to dim. It's still watchable most of the time, but picture is almost as if you turned down the brightness. There's no distortion. Any ideas?
    Problem Solver:
  • 12 Answers
It could be the ballast lamp, or it could be the optical engine, can you see in the rear of the TV if you can see if the ballast lamp is lit up. usually you need to unplug the ev and remove the rear cover or at least the vant over it to see if it is lit. If it is dead replacement is usually covered under warranty, within a year or so otherwise they cost around 200-300 dollars. If not, then the Optical engine is probably having problems and I would suggest replacing it if under warranty.
Posted on Feb 03, 2007
LG 55LH90-UB LED TV I have an LG 55LH90-UB LED tv that has, what seems to be, sections of dim areas.
Hi ,
try swapping the screen with another one to just see if it is behaving the same, because some times the screen circuitry or the led screen could be damaged .
good luck buddy
May 18, 2017 | LG Televison & Video
The screen is very dim. Not watchable. Everything else works fine
Hi craig, Try adjusting the light on your monitor...... CHEERS..
Mar 31, 2016 | Computers & Internet
Samsung led tv no picture
What did you do when you say you cleaned the screen? If you shine a flashlight on the screen can you see some very dim picture? If the back light is out. This will require replacing the power board.
Jan 06, 2014 | Televison & Video
Hitachi 32UDX10S picture is dim with brightness at 100%
The led backlights may be failing or the driver circuit isn't working. TV Parts Universal TV Stands DLP Chips ShopJimmy You can get parts and led testers here.
Feb 12, 2018 | Hitachi 32UDX10S 32" TV
The screen or picture is dim/gray. When you first turn it on the screen is black and slowly fades into a dim picture pixel by pixel.
It sounds like the lamp is on its way out. Depending on the size of the television, it may not be cost-effective to try to have it repaired. If it's under warranty, then contact either the manufacturer or the place where you purchased the TV, and find out what your recourse is. If it's out of warranty, however, there is a good chance that fixing it will cost 60% or what it would cost to purchase a new one. Sorry for the bad news.
Oct 17, 2010 | Televison & Video
Can someone take a picture of the original video settings on their Zenith B25A24Z 25'' TV because my screen is all messed up and doesnt get much better when i play with settings.
If this TV is a 25"...then this is an older set. Is the picture dim and the colors dim, will the tint not correct the color scheme? Zenith picture tubes, as a rule, for this model go bad...sorry but this is true!
Dec 10, 2009 | Televison & Video
Screen is dim/dark picture
Time to replace your DLP lamp!  Expensive ($200 and up)!  Good luck!
Jul 31, 2008 | Sony Grand WEGA KDP-65WS550 65" Rear...
How can I clean the mirrors on this tv?
to clean the mirrors you must remove the screen first there are several screws in the back to remove the screen. then there is a mirror shaped like a polligon clean this with a dry cloth do not use a paper towel. soft colth must be used on any optical surface. then clean the optical engine lens in the same manner. them the large mirror in the back. remeber if you leave a defect on any of these surfaces it will be amplified by the screen. this system relies on a lamp to provide bright picture so replace that as well. this should be a part of your anual cleaning agreement of the after market warranty you purchased assuming you bought one. dim picture = lamp, fuzzy, dim, dull picture = dust
Feb 10, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Toshiba 51H84 51" Rear Projection HDTV-Ready Television Logo
104 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
