FixYa.com
Tags:
GE JE1640 Microwave Oven
Microwave Comes on when Door is Opened (by 3 users)
posted by Jeff C on Jan 18, 2007
Here's a wierd one. Every time we open the door to the microwave, it comes "on". And this happens even when the timer has timed out. It's like there's a switch on the door that says "come on" when the door is opened.
I don't see any mechanical switches on the door to reset. I've also opened the breaker to cut power off to the microwave in hopes that it would possibly reset a malfunctioning electronic control circuit; it didn't correct the problem.
Any suggestions?
Comment by Jeff C, posted on Jan 26, 2007
I've not tried your fix yet. I may try it, but this is why I'm skeptical as to why it would work and possibly why your response got a poor rating. None the less, I do appreciate your response.
In one way I can see where the switches may be the problem, but logically, I have a hard time understanding how.
The reason is that if the switches were stuck and kept the circuit closed instead of breaking it when the door is opened, then it makes sense. But with my microwave, the door can be shut and the microwave off (timer timed out); then, when the door is opened the microwave immediately comes on. How could the switches being stuck cause this?
Comment by Jeff C, posted on Feb 18, 2007
Well. The top switch on the door actually was the problem. It was sticking in the closed position. I exercised the actuator and sprayed some WD40 on it and it's working fine now.
As a side note, after looking at the schematic and tracing current flowpaths, only the fan, turntable and light were coming on when the door was opened. In order for the magnetron to power up, all three switches on the door have to be have to be made.
Thanks for your help MicrowaveSvc.
The above comment shown from guest is from Jeff C. I had not signed in prior to posting it.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Comment by sunshinechic, posted on May 12, 2008
I am having the exact same problem with this exact same model! ugh~
Comment by Guest, posted on Nov 04, 2007
I've tried the powering on and off solution, it didn't work. I've looked at the upper and lower door switch and I think it IS the upper one.
Now I have to convince my husband to help me get the microwave down so I can pull it apart CAREFULLY. I'm going to try to replace the switch as indicated.
And, many times we are guilty of interupting the cooking cycle by just opening the door. We'll certainly stop that now.
Best Solution
posted on Jan 21, 2007
FixYa! (100)
MicrowaveSvc
Rank:Guru Guru
Rating: 87%, 2676 votes
It sounds like a problem with the door switch or mount or the control panel.
I've attached an exploded view of the oven which shows the door switches and mount.
They're located behind where the door hooks go into the chassis.
You can find our safety and disassembly instructions at our site via my link here: http://tinyurl.com/yzjozk
If it's not switch-related, then you may have a shorted component on the control board.
We repair these for customers nationwide for $32.50 postpaid in most cases.
Comment by MicrowaveSvc, posted on Jan 21, 2007
Sorry the photo got cut off.
See: http://207.234.249.73/mwd/je1640_doorsw....
Comment by MicrowaveSvc, posted on Jan 26, 2007
Since my answer got a poor rating, I'd be happy to try again if you can update me. Thanks.
Comment by MicrowaveSvc, posted on Feb 19, 2007
It's almost always the top switch, but I hardly bother to get that specific anymore because some people don't seem to take my responses seriously. I think they're possibly killing the messenger...
Anyway, it's possible yours got some grease in it and the WD-40 is indeed a fix.
But it may be that you just loosened it up and it will eventually fail for good. Be ready for that.
My advise to anyone with door switch trouble is to replace both the upper or lower or even all three and then develop a habit of not opening the door while it's cooking.
Thanks for the follow-up! You are quite welcome.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Dec 12, 2007
Not Rated (0)
duderduder
Rank:Apprentice Apprentice
Rating: 100%, 1 votes
Most microwave ovens run the fan when the door is open. I believe that this is what is happening and you are not getting any microwaves from your magnatron.
Solution #3
Not Rated (0)
Guest
Guest
Rating: 0%, 0 votes
This Problem Also Relates To: GE JE1660 Microwave Oven GE JE1590 1000 Watts Convection / Microwave Oven GE JES1288SH 950 Watts Convection / Microwave Oven GE JES1456 1100 Watts Microwave Oven GE JVM1410 Microwave Oven GE JVM1651 Microwave Oven GE JVM1653 1000 Watts Microwave Oven
Can you Help with these Microwave Ovens problems?
Microwave Ovens
microwave, convection R930AK...
microwave, convection R930AK... Answer This...
Microwave Ovens
frigidaire mwo fmt144g1w2 mwo...
frigidaire mwo fmt144g1w2 mwo... Answer This...
Microwave Ovens
looking for wave guide cover
Hi, I have sunbeam microwave... Answer This...
Microwave Ovens
Kitchenaid microwave convection...
Kitchenaid microwave convection... Answer This...
Microwave Ovens
What size fuse is used
What size fuse is used on a... Answer This...
Repair Service
Find Microwave Oven Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
