Question about HP Office Equipment & Supplies
Photosmart C6180 will not print in black ink. Have all HP genuine cartridges, although I have used cheaper imitations in the past. Have tried aligning print heads, cleaning, master reset (# & 6 keys), etc. Is this a fixable problem?
    Sergeant:
  • 217 Answers
Do not print the printout from the pc.tyr to print a test copy by pressing the menu button on the printer and in that select the option print a self test.then press OK.if the test copy from printer gives proper black colour then its the print setting problem in the pc.just adjust that setting.but if the test page does not print any black line or object that means the cartridge is out of ink and needs replacement.
Posted on Nov 29, 2008
I have changed the black ink cartridge and although it is o.k. the black wont print. help I have taken the cartridge back and changed it to check if its ok I have cleaned Please help urgently
Hi
If it is a original HP cartridge try running the inbuild cartridge clean and if that does not work you can get a replacement cartridge from HP if it falls under there warrenty agreements if it is not a genuine hp cartridge I suggest go and get yourself one. Also by using generic cartridges in these systems and mess up the ink systems of the actual unit
Peace
Nov 26, 2009 | HP Photosmart 3110 All-In-One InkJet...
Brand new yellow ink cartridges are always read as empty
We have a step by step solution posted on our we site at: www.ccl-la.com/HP.htm The problem is air in the ink lines and the guide helps you purge the air from the system and restore printing.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Jul 27, 2009 | HP Photosmart C6180 All-In-One InkJet...
6180 will not print black text
Are you using genuine or knock off inks?
Take out the blabk cartridge and knock in onto your hand while using a paper towel to absorb ink.
If ink comes out you have a communuication problen with the printer ink carriage or a defective cartridge.
Jul 21, 2009 | HP Photosmart C6180 All-In-One InkJet...
Black ink cartridge wont print, have installed a new ink refill still no joy. Will print in all other colours.
Well if you already installed a new black ink cartridge and still wont print, then try cleaning your printer head. It can be that the some ink was hardened and got stuck preventing you to print a black color.
Jul 19, 2009 | HP Photosmart C6180 All-In-One InkJet...
Won't print black ink
I am on my second Photosmart C6180, the first one I had quit printing black ink after 6 months, after hours with the HP help desk, the finally decided to replace the printer. I have now been using the replacement for several months and just this weekend it too quit printing black ink...no copying, no printing and no faxing.  I am now shopping for another, not a HP.
Sep 08, 2008 | HP Photosmart C6180 All-In-One InkJet...
Black wont print
How did you resetted the machine??
Did it gave you any error messages??
Try to take out the black ink cartridge and try to clean the contacts (the copper colored circles) with a cotton swab dampened with bottled water. (don't use tap water coz there are contaminants on the tap water might ruin the contacts). Send me a message if it still wont work
Aug 19, 2008 | HP Photosmart C6180 All-In-One InkJet...
C6180 printer
Well I hear time and time again that the non-manufactured ink is cheaper - and people are right since it really is. Unfortunately since the cartridge is a knock off of the original or a refill any number of things can happen including jams, ink leaking, false readings, power issues, and so forth.
I suggest you take out the OEM cartridges and put in real hp cartridges. The hp printers are getting smarter about genuine cartridges and sometimes will not accept which could be what your experiencing. Replace the cartridge with real hp cartridge and try to print something out.
Mar 12, 2008 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart C6180 All-In-One Is printing All Documnets Faded Colors
Try to clean your printheads or check the level of your inks, maybe you are low on inks. Operating system does not affect any printing outputs as I know. Check your inks also coz HP cannot guarantee the quality or reliability of non-HP ink. If ink cartridges have been refilled, try replacing them with genuine HP ink cartridges.
If the print defect is minor, it might be caused by reserve mode operation. When the printer runs out of some colors, it can continue printing using remaining inks, but print quality may be affected. If cyan, magenta, or yellow is out, the printer can print only in grayscale.
Replace any empty print cartridges. To check ink levels, follow the steps below.
  1. Press the Setup button.
  2. Press the down arrow button until Tools is highlighted.
  3. Press OK .
  4. The Display Ink Gauge selection should be highlighted. Press OK and the ink gauge will display.
OR try calibrate the color:
  1. Open the printer Toolbox :
  • Open HP Solution Center (click Start , then All Programs , then HP , then HP Solution Center ).
  • If you have more than one printer installed, make sure to select the correct printer tab in HP Solution Center .
  • Click Settings .
  • Click Print Settings .
  • Click Printer Toolbox .
2. On the Device Services tab, click Calibrate Color , then follow the onscreen instructions. The procedure takes about two minutes and requires two sheets of paper.
If the steps above did not help, clean the print head.
  1. Open the All-in-One Toolbox :
    1. Open HP Solution Center (click Start , click All Programs , click HP , and then click HP Solution Center ).
    2. If you have more than one All-in-One installed, make sure to select the correct All-in-One tab in HP Solution Center .
    3. Click Settings .
    4. Click Print Settings .
    5. Click Printer Toolbox .
  2. On the Device Services tab, click Clean the Print Cartridges , and then follow the onscreen instructions. Three levels of cleaning are available.
Please let me know if these steps helped you or not. Thanks
Jan 02, 2008 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart C6100 All-In-One Printer stopped printing black ink
Please clean the print heads :
Press Setup up - Tools - Clean Print heads on the All-in-One.
If this does not resolve the issue , Reset the All-in-One.
Reset the All-in-One to the factory default settings by using these instructions:
1. Unplug the power cable from printer when the printer is powered on.
2. Press and hold OK and HELP buttons while plugging in the power cord.
If issue stil persists. Contact HP.
Dec 19, 2007 | HP Photosmart C6180 All-In-One InkJet...
204 people viewed this question
Seeker5211
Seeker5211
