Question about Sony FD Trinitron WEGA KV-27FS100 27" TV
Component Video Problem
I'm having a problem with my Component Video connectors on my Sony KV - 27FS100 TV. I recently purchased a new component video cable thinking my old had gone bad. However, I am still having the same problem. The problem I am having is horizontal (black) lines across the screen when trying to play a DVD hooked up to my TV with component video cable. I can see that the DVD is playing and I am getting sound, but the picture is obviously not being seen because of the horizontal (black)lines are not allowing the picture to be seen. When I hook up using composite video cables (not my preference), everything is fine. So, I think problem lies with the component video connectors. I'm thinking that maybe something has become disconnected or loose? Is this something that I can fix myself? Or, do I need to take it to a repair shop? Is this a costly repair? Everything else works fine on the TV. Please advise! Thank you, Randy Dissmore
The problem is not with your tv it's with your dvd player. You have to go into the setup on the dvd player and change your output setting to component.
Posted on Feb 05, 2007
Try http://fletchersite.com/ask.html
Posted on Feb 06, 2007
Why does the tv have component video when its an analog tv and how do you hook it up
Component video IS analog. It is also known as Y-Pr-Br. These connections are typically RCA connectors colored Red/Green/Blue.
Component will give you the highest quality signal for analog connections (vs Composite Video (yellowRCA) or S-Video(the round 4 pin connector) Of course HDMI will be best if it is supported.
Keep in mind video signal formats are NOT interchangable, you cannot plug a Composite Video into a Component Input
All you need is a component source (typically a DVD player) and 3 RCA cables and match the colors up.
You will also need to connect the Audio connectors (Red/White) with RCA cables, as the Component is Video only
I hope this helps,
Magoo
Mar 11, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Blue colors are now green.
It sounds connections are not matched yet. Make sure connections are green to green, red to red and blue to blue in dvd player and tv are correct.
Try another component video cable.
If problem still exist, test dvd player to any other tv, found ok then component input of this TV is bad, need to get it repaired.
Jan 24, 2010 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Menu Screen pops up, try to exit and goes to video 1
This could be a stuck button on the front control panel or a bad solder connection on one of the switches on the front control panel.
Aug 02, 2009 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony KV-32FS12 Component Video 4 Has A Wavy Picture
sounds to me like the differnence between watchiing in progressive and interlace. these older tube tv's are not capable of displaying a progressive scanned image. like the first dvd players. check your video out settings on your ipod to make sure its an interlace output.
Apr 23, 2009 | Sony KV-32FS12 32" TV
Upconversion to 1080i playback
Hey smittybd,
According to information provided by the manufacturer, this specific model DVD player is only able to provide upconverted 1080i images via its HDMI output and a maximum 480p resolution using its component connectors. Please keep in mind that while component cables are able to support 1080i and 1080p resolutions, not all hardware (TV's and DVD players) will support these resolutions through component connections.
If you're having difficulty locating a model that specifically supports 1080i resolution images through its component connections, you may wish to try visiting individual manufacturers' websites for more information. Some companies (such as Sony) will provide detailed information regarding what each type of connection is capable of in their owner's manual documentation.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Jul 15, 2008 | Sony 36IN TV Stand Designed for Model...
Connect Apple TV to Sony 27FS100
the kv27fs100 is a standard 480i resolution check the output of the apple tv make sure it is not in progresive 480P
Feb 27, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony KV-27FV310
Component In is not converted to composite out (yellow)
TV monitor out normally goes to A / V receiver in......T.
Nov 18, 2007 | Sony FD Trinitron WEGA KV-27FV310 27" TV
if it is white brightlines along with blue back ground please check 1 sypply to blue video output transformer. 2 crt base or connector loose. 3 check components related to blue video ckt & blue video output transistor. 4 blue signal reaching to blue video section 5 verv very rare case if set is old set then there is a possibility of crt. hope this will help.
Oct 06, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony WEGA TV Red color wont display at all.
as other color are ok(blue&green)& no red colour.please check as follows. 1 check supply to red video transistor. 2 check for loose crt base. 3 check for loose connector 4 check components related to red video ckt.& cathode ckt. 5 check for red signal is coming to red video ckt. 6 check red cathoe voltage. 7 signal processor ic.
Sep 30, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony FD Trinitron WEGA KV-27FS100 27" TV Logo
798 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
