Question about Sony Network Walkman NW-A3000 MP3 Player
Bricked NWA3000 wont' turn on. When plugged in to charge, the red light (charging) doesn't turn on. When plugged into computer with USB, not recognised and red light remains off. It was perfectly fine 2 days ago, and from then to when I first realised the problem, the player was just left in my room, no water damage, no impacts. Battery was at 80% last checked. I've tried reseting, but still unresponsive. Thought about reinstalling firmware, but as stated before, not being able to power up means I can't connect it to my computer. Help please?
  • Jon Kuo Apr 18, 2007
    nc11, what did they end up identifying the problem as?
    I just got my walkman back from the store in HK (the support centres here wouldn't accept it so I had to somehow get it to hong kong...), problem was apparently a faulty internal connection. All data still intact, thank god.
CZ\AD4h$nm424vz \x\5
Posted on May 30, 2010
My nwa 3000 has done the same,in the same situation. I'd advise taking it in to your nearest sony store, to see if they have any suggestions. I'm going to my nearest sony store on thursday, to see if anyone can be of any help.I've only just had mine for 1 year
Posted on Jan 31, 2007
How do I charge a hype usb recorder
HI,
You might have a faulty unit or the computer is not supplying enough current to charge the device.. Plug it into a USB phone charger and see it it charges then. If it still does not charge then the until is faulty.
Feb 02, 2018 | The Computers & Internet
I get the blue screen with MSDC on it, it doesn't turn on unless plugged into the wall/electronic device, it wont turn off after I get the blue screen unless I unplug it, and it's been chargin
It is charging by USB port using ac adapter, can also charge by computer USB port during picture uploads and downloads. Do you need an instruction manual.
Feb 17, 2012 | Vivitar ViviCam 8025 Digital Camera
Im trying to charge my camera via computer. . there is a red light on the charge cable connector and a green light on the camera which i have switched "on". it still says "low battery even...
Hi, I'd suggest using a wall charger as they're able to provide more power to charge then a computers USB port. Often with camera's the USB port doesn't supply enough power so the camera doesn't charge at all.
Aug 18, 2011 | Samsung SL102 Digital Camera
Hi, I just bought your product SYMA s107. I took it out of it's box and I started flying it. At first it was flying great but after a couple of minutes it started to not even lift of the ground. I charged...
you should have charged your heli BEFORE 1st flight.......anyway,,plug computer end of usb charge
cord into computer......turn heli OFF....before you plug cord into heli look at computer end of cord,,
should be bright red light inside......now plug other end of cord into heli.....bright red light goes out!
when heli is fully charged bright light on computer end of cord comes back on......disconnect
heli right away.....if left on charge your battery could wear out....it takes about 50-60 minutes
Feb 25, 2011 | SYMA Toys industrial New Syma S107 Radio...
I just got a brand new flip video mino hd and it wont turn on. i've charged it for atleast 4 hours. when it is plugged in the red light comes on. that is the only response i get from it. any...
I had to charge mine for 7 to 9 hours the first time, and make sure computer is left ON or it won't charge and the red light stays lit until it is fully charged. make sure the red light isn't blinking if it is, plug it into a different USB 2 port and don't use extension with it unless it is a powered USB extension.
Dec 28, 2010 | Pure Digital Flip Video Ultra Camcorder
I cant get my mda to turn on i hold down the power button for a while but it wont turn on i charged it for 3 days and it still wont work what should i do?
Mda Vario's don't charge when turned off, heres what you do.
cut wire off a usb lead the small end strip the red and black wires, put the red wire onto the posative connection where the battery is it tells you what side is posative and negative on the battery, use black with negative and red with posative making sure that no wires touch the other metal strips in the phone, replace battery plug usb into computer and start up the mda and wait for it to boot. once turned on leave to charge as it will charge through the wires connected to the battery, after 10 to 15 minutes plug in the actuall charger and try to remove usb wires without taking battery out. if that is not possable it is ok as the battery should have enough power to start up once it starts leave to charge and always keep some charge in the phone.
Jul 07, 2009 | T-Mobile MDA
My 24280 dig. Wont charge
the pc function means that it is connected to your computer this is good because now you should be able to upload pics and ect...the red light is simply to show its charge level and is always on when plugged in to computer also there should be a switch on the side to change from camera to charge if its on charge and the light is red then its carging and it will turn green when its done.
Jun 16, 2009 | Sakar 24280/24282 Digital Camera
My Mambo- Mano MP4-MP3 does no charge
it does not seems to charge / or turn ON either from the computer or when plugged to an electrical outlet to the wall. Red light is still ON after the whole night . What's wrong ?? Can you please HELP - CODY STELLER MINE IS A 4 GIGA BITE MP4 PLEASE HELP ONLY
Sep 01, 2008 | Kaser Corporation Mambo Mano Digital Media...
Jazz DV-179
YOU PEOPLE IT IS JUST THE BATTERY THAT IS IN IT!.. BECAUSE THAT BATTERY IS NOT ONLY FOR AFTER IT IS CHARGED IT ALSO WORKS TO SHOW THE DISPLAY SCREEN! BECAUSE IF YOU TAKE OUT THE BATTERY THE LIGHT STAYS ON WHILE ITS PLUGGED INTO THE COMPUTER! MY BF IS HAVING THE SAME PROBLEM TRY BUYING A NEW BATTERY!! ITS THE SOLUTION! the battery is caput!
Jul 12, 2008 | Jazz DV-179 Digital Camera
Sony Network Walkman NW-A3000 MP3 Player Logo
378 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Gyula Lacz
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
