Question about Nokia 6120
Nokia 6120c won't active after long standby
My nokia 6120c it won't work after i left it for long time (3-4 hour), it show blank screen and when i pressed keypad it didn't respons. please help me with my problem.
  • arie_hidayat Dec 11, 2008
    thank you for your solution its very helpful. but i have another problem that my new battery won't last long even i have charged it for 12 hours. i'm just using my phone for 30 minute and it says low bat. please help me with this problem.
Plug into car charger and leave for 1 hour, this will blast power in to phone the remove battery reconect batery and try
Posted on Nov 29, 2008
Unlock code for nokia 6120c
Hi, You can get the unlock code for a Nokia 6120C from www.unlocking4u.com/nokia-6120c/rs6wp9/ at affordable cost.
Here are the steps for unlocking a Nokia 6120C,
1 - Switch on your Nokia 6120C without any sim card.
2 - Don't bother as to what is displayed on your Nokia 6120C.
3 - Compose #pw+CODE+1#.
4 - The Nokia 6120C would then display the message "SIM Restriction Off" and will be unlocked!
Sep 14, 2012 | Cell Phones
My battery died on the Nokia 6790 Ive been charging the phone for over 3 hours and only the keyboard lights up when i hold the "on" button but the screen doesnt turn on
Ifthe cell phone battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Jul 11, 2011 | Nokia 6790 Surge Cell Phone
Is there any way I can take off the sleep mode on the nokia 6700 slide? As it just looks like a blank screen and to check for messages or missd calls, I need to press a button Thanks
A quick answer is NO you can not disable the blank screen, it's set like that for a reason. The back light of the display uses lots of power and the battery would be discharged in 3-4 hours if left on. Also the display isn't designed to work 24/7 and if it did would self destruct anywhere between 45 and 90 days of constant operation.
Jan 26, 2011 | Nokia 6700 Slide Cell Phone
How can the standby mode on the Nokia 2730 be fixed.
first decide that in your phone activated your screen saver if yes then customize your display setting. if not then active your screen saver which is watch.if you not get any solution then format your phone. these code are under the following.
*#7780# then want security code. please give your security code. then your phone will be restore factory settings.
Jul 03, 2010 | Nokia 2730 Cell Phone
My nokia 6120c will not boot up, it keeps freezing when the word nokia comes on screen, i need hel. I have removed the battery and sim card many times but it still keeps happening
Hi,when a phone displays a standby Nokie logo on the screen of you phone, it means that the has be affected through an application that was downloaded from the internet or from another phone and has affected it with VIRUS.
To remove Virus from phone,you need flash the phone.
Flashing the phone will restore back the phone back to normal.
You can use the link below to know about flashing and how to flash the phone.
unlocktotalk.com/UnlockCodeInstructions.htm.
Take care.
Jun 14, 2010 | Nokia 6120
Can not get Nokia 6120c V04.21 to online mode
there might be problem with the sim card holder. try to insert some piece of paper folded atop the sim card and close the sim holder
Aug 12, 2009 | Nokia 6120 classic Cellular Phone
Gud evening sir im ravi my mobil model no is nokia 3110 c i have one problam my musiplayer is not opening how will solve that prolam
1.Format your memory card
2.Make shortcut on your mobile so u can access very fast to your media player
2.1. In SETTINGS/DISPLAY/ACTIVE STANDBY/ACTIVE STANDBY MODE (TURN ON)/PERSONALIZE VIEW (MAKE IT THAT SHORTCUT BAR IS THE ONLY ONE THERE)
2.2. In SETTINGS/MY SHORTSUTS/NAVIGATION KEY make it so that standby key is 2nd
2.3. Get back to main screen and press DOWN key, options, select, select media player, and save, in organise shortcuts make it 1st and save your progress
3.Upload up to 5 songs
4. Update your media player, mobile will restart him self! BUT!!!...
5. In order to stop restarting u have 3 sec to start updating music library again
6. If u done all at step 2, u need to press fast one time down, central button, left blue line, down, central, up, and central (Need to be pressed in 3 seconds)
7. If u success in this 6th step u hawe solwed problem!
8. Next step is to upload next 5 songs and repeat steps 4-6
(9.) If you cant press so fast buttons to restart uploading I suggest to create a folder named "Amp3" so he can be first when u access to your memoru card so you could
erase him fast to stop restarting, instead formating whole card (In SETTINGS/MY SHORTSUTS/LEFT SELECTION KEY(Make it Gallery, so you can access fast to memory card to delete folder "Amp3"))
(10.)Buttons to erase "Amp3 folder" - While in main screen press : Left blue line, center, left blue line, down, center, center (Need to be pressed in 3 seconds)
(11.)You hawe stopped restarting and kept pics, and images on memory card
Dec 04, 2008 | Nokia 3110 Cellular Phone
NOKIA N95 BLANK SCREEN
It must be a connection problem, to the LCD, or the light is not working.
Can only be sorted by looking at it really.
Back to Telstra I'm afraid. If it's new let them sort it out, if it's not try a reset take the sim card out first then input this code *#7780# (Best to use this code as a last resort)
Give it time to work.
Jan 10, 2008 | Nokia N95 Cellular Phone
Bootloader screen
nokia n76 problem on display nokia steel picture
Aug 02, 2007 | Motorola Mobility E815
Nokia 6120 Logo
222 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
