Question about Goodman GDS80703ANA Open Flame Mid-Size Heater
When i turn on my furance it starts up later it will try again and the system will lockout with one flash on the board indicating retries recycles exceeded any ideals?
  • 2 more comments
  • king_cleo Dec 01, 2008
    the inductor motor comes on the glow plug ignitor comes on the gas valve opens the furnance comes on but later it tries several times and locksout I would have to turn off the switch on the side of the furnance for about 30 seconds it will run for a few days and go back to lock out
    I cleaned the flame sensor I will let you know if this works
    Thanks
  • king_cleo Dec 02, 2008
    hello again the flame sensor was cleaned but it was not really dirty
    am still having the same problems any more ideals question can the ignitor be bad if it appears to be working with out any problems it glows each times
  • Tony Lozano Sep 18, 2013
    You have to see if the flame comes on before its the flame sensor could be the pressure switch or the igniter the furnace will try to light 3 times befor it locks itself out so on that note see if the igniter glows if not could be the pressure switch or the igniter
  • 34 Answers
Check to make sure the gas is on and the flu pipe is clear.  does the draft motor come on at all?  if not, you may have a failed control board.
Posted on Nov 30, 2008
  • chris seagraves
    chris seagraves Dec 01, 2008
    if the furnace comes on, you may have a flame sensor that needs cleaning.  it's the silver rod looking thing shaped like an "L" in front of one of the burners.  see if you can disconnect it and take a wire brush to it and try to get it back to silver if it's black.
  • chris seagraves
    chris seagraves Dec 02, 2008
    the ignitor isn't itermittant, it either comes on or doesn't. you may have a control board failure.  if the flame sensor isn't "sensing" the unit will shut down.  do the burners light at all?
Error code= two red flashes, lockout/ no flame
Trane XV80 hard lockout, 2 flashes, Can't be reset - DoItYourself ...
www.doityourself.com > ... > Gas and Oil Home Heating Furnaces
Jan 10, 2013 - The only way I can get diagnostic Red LED light to reset is to switch ... a2 flash with absolutely no operation from the furnace does seem to ..... inducer gets a demand you should get a pressure switch error code 3. ... the flame sensor wire and giving the furnace a heating demand after resetting power twice. Luxaire Furnace Blowing Cold - 8 Red LED Flashes
Mar 1, 2010
Winchester furnace diagnostics
Feb 14, 2010
American Standard Freedom 80 - Cold Air - Getting Error Code 9 ...
Nov 20, 2009
York ignition lockout due to retries
Dec 29, 2008
More results from www.doityourself.com
7 Tips and Tricks to repair your Furnace DIY - YouTube
? 13:25
https://www.youtube.com/watch?v=rAtcvPqUsBA
Dec 18, 2012 - Uploaded by JRESHOW .
cause this fault. 2 RED FLASHES: This indicates that thenormally open pressure ... The furnace will lock out for one hour and then restart. 7 RED FLASHES: This fault code indicates that the flame could not be established. This no-light ... problem. Bothheating and cooling operations will be affected. Check
Jan 23, 2016 | Heating & Cooling
Trane xv95 converted to propane is on system lockout
worth checking over heat temp sensors (klixon ) sensors can cause heater to go into a cool down purge Through an open circuit heat exchanger (Klixon ) temp sensor Ive seen before good luck
Nov 25, 2017 | Honeywell Electronic Programmable...
My daughter turned it off and now it wont turn back on
Now the tv LED power light indication is flashing?Yes.Tries tv unplug,replug back like about an hour later.By letting the tv restting itself back to the factory setting.Now tv should be working again.If tv have same result problems or again later on.The tv power supply board is the causes and the problems,that the board where the power a/c cord plug into it.Tries websites like Shojimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Jan 21, 2011 | Insignia 42" LCD Flat-Panel HDTV
Hi, the lights on my circiut board are flashing the one on the left is on all the time and the one to the right of it flashes two times and then waits and then flashes two times again
Error Codes
A green LED indicates system faults
Steady On: System OK
Steady OFF: Board control fault or no power applied
1 Flash: Ignition failure (control in one-hour lockout)
2 Flashes: Pressure switch fault, fails open (switch is
stuck open)
3 Flashes: Limit switch open (main or auxiliary)
4 Flashes: Pressure switch fault, fails closed (switch is
stuck closed)
A yellow LED indicates flame status
Steady on: Normal flame is sensed
Flashes: As flame weakens, frequency of LED flashes
increases
hope this is helpful.
Dec 21, 2010 | Ruud Central System Air Conditioner
LG 32L4DS this is my TV... my wife was watching and the screen went black no picture no sound any suggestions or is it a recyclable?????
Tv now turn on,tv have power LED light indicator flashes?Tries tv unplug,replug it back like an hour later,the tv now,should resetting itself back to the factory setting.The tv should work now.Not,than the power supply board is dead.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Oct 25, 2010 | LG 32LC2R 32 in. HD-Ready LCD Television
Gas furnance would only operate for about 3-5 minutes then turn off. Replaced gas valve on furance for a Rudd comerical A/C 4 ton unit model UKKA-A048JK10E. Now the blower fan turns on but the igniator and...
the rollout switches will be located at the ends of the burner assembly and will have a manual reset. they must be manually reset to ensure that the problem has been corrected. Most units will go into a soft lockout for a time and eventually a hard lockout if the problem persists. Go to tempstar.com and go to their troubleshooting section for a gas furnace. the codes they give are pretty common for alot of furnaces and see if they help
Dec 10, 2009 | Ruud UAKA042 Air Conditioner
Kenmore 790.9641240, while using stove top power burner (front left) a loud pop was heard and I thought I saw a blue flash (like an arc) above the pan, the next day received a slight electrical tingle...
Tom (Tchange): I also had arc/pop/short of SSB like g_royer. This was preceded over a few days by the Element ON indicator always ON (with all surface select switches OFF). I found the arc marks and burns on the SSB and replaced it. Element ON indicator went OUT, but like you, element no longer heats. I just checked continuity for each of the relays on the Lockout Board. In spite of the error designation on the Wiring Diagram (swapping P3 with P6), I found an OPEN relay for that element. Now to order the Lockout Board, just like g_royer.
Jun 25, 2009 | Kenmore 96422 / 96424 / 96429 Electric...
Heating & Cooling Logo
343 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
