Question about Canon DR-9080C Path-Through Scanner
Scanner to Pc File Size and Volume Problems
Cannon DR-9080C Scanned to Pc Volume Problems I have a problem with this scanner. Scanning grayscale at 300dpi after 9 pages the scanner will pause for 10-11 seconds. Considering it takes about 3 seconds to scan 9 pages and the pause time is 10-11 seconds the downtime is quite considerable. Also i am unable to scan an a4 colour image at 600dpi. Or scanning a few a4 24bit colour image at 300dpi after about 6 the pc just takes soo very long to transfer from scanner to pc. I have 504 megs of ram and a 2.26 gig pent 4 . Now i presume i need more ram and or chipset power. What kind of specs do i need to run to get proper usage out of my scanner and not be bottle-necked. PS: The minimum requirement specs on this scanner are so far off par!
Hello We have been having this same problem when scanning Black and White as well. We have just played around and have changed one of our settings that has seemed to solved the problem for now. Try Properties (on scan settings) then more then click on - Detect Page Size - Image Width instead of Guide Plates Hope this works for you to
Posted on Apr 04, 2007
  • 25 Answers
Check your scanning software settings for a "pre-scan cache" or for a "scan ahead" setting. Turning these on will usually eliminate the delay. Without a prescan cache, the computer will stop the scanning when its buffers are full, then give the OK to scan when the image processing is completed.
Posted on Jul 07, 2008
  • 490 Answers
Upto the first 8-9 pages, the data sent by the scanner is in the RAM of yr comp. ONce it is full, scanner cannot send more data and hence the delay. There is something called 'ack' (Acknowledgement) between scanner & computer. Try storing data in JPG format, by changing the settings. This will speed up scanning. Canon 9080C can give you JPG outputs comfortably. Pls note there is some quality drop in JPG As compared to TIFF format. IT depends upon your end use application.
Color at 600 dpi will be a huge file. i.e, 600 x 600 x (8x8x8) for thre colors only for 1 square inch, above 180MB of data.Check if you really need that kind of resolution. Normally printed page is about 150 dpi only and scanning in high resolution does not improve quality, but only increases size.
S. Mohan, Chennai, India
Posted on Dec 03, 2007
Hi, I scan documents (recto and recto-verso) using the InformatikScan software and the scanner Canon DR-9080C. When I scan for ex. 30 pages, after 10 pages the scanning process slows down in...
The scanner creates a Raster Image and if it is grey or color, the size is big. After a few images are scanned, the 'buffer' inside the scanner is full. It may take more time to process the scanned image by the scanner if it is 24 bit color. The image is sent to the computer Harddisk and if the disk is full or if it had not been defragged for a long time, the sectors may not be contiguous for speedy writing, This will slow up the scanning. Ensure the disk has large space. 'Scan ahead' slows down scanning speed. (Without scan ahead, the next page is fed only after processing, whereas when selected, just after the previous page is scanned, the scanner start the next one)
S. Mohan, India, Chennai
Jul 04, 2011 | Canon DR-9080C Path-Through Scanner
When scanning with the native scanning software, the scanner runs very fast but file size is huge. When I use Adobe 9 to scan, my files size is much smaller but the scanner pauses after each page. I need...
I would expect the problem with the Capture perfect fike size is down to the compression chosen for the output file. Ideally black and white inahes should be Group 4 TIFFs and Colour or Greyscale should be JPEG. Alternatively you may want to check the scanner is set to 'scan ahead' in the twain settings in Acrobat. If it is set to anything else the scanner will slow down to allow the PC to process every image. With 'Scan Ahead' turned on the scanners memeory buffer the PC speed a little giving you faster scanning.
Jan 25, 2011 | Canon DR-5010C Path-Through Scanner
1) How to Detect Automatic PageSize (eg. Remove Black Color of Scanned Image at the end of the Page.) 2) Compression Using JPEG Compression. 3) Set Name Rule and File Format How to set all...
I presume that you are using CapturePerfect ver 3 as scanning software. Please select "Auto-detection" under page size and also 'deskew' using both Roller & Image' under filters. Under file format, you need to select JPEG. Naming convention is available, however I'd suggest that you choose the name which is convenient to you. Multipage is NOT available with JPG format.
Jan 11, 2011 | Canon DR-9080C Path-Through Scanner
When we try to save the scanned documents it takes long time? any idea how to slove this issue please...thanks
The file size depends upon B&W or Color, the Format and the System performance. If you are scanning in color, try JPG format as it is lesser in size. TIF file will be huge as compared to JPG, though there is a drop with JPG, it is easily manageable. If B&W go for TIFF compressed instead of uncompressed TIFF.
Check if you have enough disk space in your computer. Do a defrag on you hard disk.
S. Mohan, chennai, India
Nov 30, 2010 | Canon DR-9080C Path-Through Scanner
Scanner Canon DR-9080C recently started scanning at a slower speed. All setting look to be the same compared to another unit. Any thoughts?
Do you have enough disk space? Try disk Defrag and create more space. Also check the Format you are saving, is it TIFF compressed or uncompressed? The uncompressed file size is really huge.
Oct 02, 2010 | Canon DR-9080C Path-Through Scanner
Canon 9080C not scanning 11x17 pages
The problem is probably in your scanning software, you have to tell it if you want to scan legal size, and if you leave it set for legal all the time it might put dark bars under the letter size docs. It depends on the version of software on your computer.
Sep 03, 2009 | Canon DR-9080C Path-Through Scanner
Canon DR-9080c scanner not lifting error no page found in feeder
There is a paper sensor just under the rolers in the lifting tray. Clean the area thoroughly with a damp cloth. Keep some sheets and try ]count only'. If it works then the sensor is okay, then you can try your scanning. If it is not sensing paper, check the sensor or connections to the sensor.
S. Mohan, India
Jul 09, 2009 | Canon DR-9080C Path-Through Scanner
DR-9080C intermittent stops during scanning which last 3 to 5 minutes
Do you have enough hard disk space? Reinstall your driver software. Run Scandisk on the Comp.
Is the problem coming on after a set time interval, any heating smell?
S. Mohan
Jun 22, 2008 | Canon DR-9080C Path-Through Scanner
Canon Dr-9080C scanner
to check the page count install the driver and setup the scanner as a "scanner device" on your computer. Once you have done that , go to the "control panel" than "scanners and printers". Right-click on the device that says "Cannon DR-9080C" and select "properties". The device information will appear, than select the "counter" tab on the information box; the scan count will be listed.
Apr 14, 2008 | Canon DR-9080C Path-Through Scanner
Canon DR-9080C Path-Through Scanner Logo
336 people viewed this question
Clive
Clive
old marine
old marine
