Question about HP Office Equipment & Supplies
My printer is not working, I thinkis the connection between the printer and the computer as I did a print test page and it worked. when I print from the computer it does not print. Hope you can help
    Sergeant:
  • 217 Answers
1)right click the my computer icon
2)click properties and then click hardware n go to device manager.
3)uninstall all usb ports and then scan for hardware changes
4)ur pc will detect your printer and ask for printer drivers
5)re load drivers and your pc will communicate with your printer
6)for reloding install the cd follow the instructions on the screen and click next
7)restart when the printer is loded.connect the wires and cords properly.
Posted on Nov 29, 2008
  • maddyrcks Mar 16, 2011
    worked fyn for me..thanks bro...thanx alot
How do I get my iPad to work with hp7410 printer
I would suggest the app Print Burea
its kind of expensive($20)
works with i think all printers i thinki have not had any problems so far
Jan 09, 2012 | HP Officejet H470 InkJet Printer
Myy Brother MFC5460 will not print at all. Printer status says it is ready, but the printer never receives the print material. The information remains in the print queue. Work Offline is not checked, so I...
How is it connected?
If its connected via usb cable just follow the steps below:
1. Make sure that Mfc5460cn lcd shows date & time. 2. Disconnect the usb cable from the computer and printer. 3. Turn off the printer and unplug it from the power outlet. 4. On the computer, cancel the document on queu. Go to printers folder and right click on the Mfc5460cn icon and left click on cancel all documents. 5. Reconnect the usb cable from the printer then to your computer. Make sure that it is connected securely. 6. Plugged the printer back to the power outlet and then wait for the lcd to show date & time. 7. Open the printers folder again. Make sure that the status is ready document 0 8. Right click on MFC5460cn then left click on properties. ON the lower left side of the window click on print test page.
The printer should print a test page. And it should work,
Hope this helps. Rate if it works. Thanks
Apr 09, 2011 | Brother MFC-5460CN InkJet Printer
My HP 3100 series always prints a test page on startup. How do I make it stop???
there is a similar problem described on this site.
Try here:
http://www.fixya.com/support/t317689-hp_photosmart_c3100_series
I also found this on the internet which apparently works:
Please follow exactly and IN ORDER.
1. Turn off the printer and wait 10 seconds. Turn it on again
2. Let the printer print the test page.
3. After the test page is printed, disconnect the USB cable connecting the printer to your computer. DO NOT turn off the printer while disconnecting the USB cable.
4. Place the test page on the scanner glass and press the SCAN button on the printer. The ON light will flash as the page is being scanned.
5. Remove the test page when the ON light is steady.
6. Finally, turn off the printer and wait another 10 seconds. Then turn it on again. No more printing test pages! Yay!
(You may now reconnect the printer to your computer via the USB cable.)
Regards,
Steve
PS Feel free to vote for my answer or give a testimonial if I have helped.
Oct 21, 2010 | Office Equipment & Supplies
Printer prints test pages but will con print from
Has this printer ever worked? If so, what changed between its working and failing
What is your method of connection, parallel port, serial port, USB 1 or 2 ports?
Are you running stand-alone tests to it or are you printing the test page from the operating system? What operating system do you have installed and is the printer and its related software approved for this operating system?
Do you have the correct driver for this printer and operating system?
Can your PC see (identify) that it has a printer attached to it?
Don
Oct 17, 2009 | HP PhotoSmart P1000 InkJet Printer
PRINTER WILL PRINT COPY OF SOMETHING BUT WANT PRINT SOMETHING OFF COMPUTER.
This problem sounds like the printer is not set up properly on the computer. Have you installed the software that came with it? If so, look for the printer under control panel and then try a test page. If the test page doesnt work, how is the printer connected to the computer, by USB cable? If it is connected by usb, try shutting the computer down, unplugging the usb cable, restarting the computer and once it is fully started, plug the usb cable for the printer back in. Do you hear a tone after the printer is plugged in? If so try to print again.
Aug 11, 2009 | Office Equipment & Supplies
Only test pages print perfectly!!
If when you print a test page it comes out perfectly, that means that the printer works, and the problem is communication between the printer and Mac.
Try the following:
Start testing a different USB cable and a different port.
Unplug Mac, and eventually remove the battery.
Unplug the printer power cable and USB.
Put the mac back toghether and restart it with printer usb not connected.
When mac is on, reinstall printer software driver, with Mac still not connected to printer, using printer disk or download.
Connect printer to Mac when asked by software.
If that still does not work, test the printer on a different computer, even if it is not common, the printer may have a faulty USB port.
Feb 28, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Printer not working
Hello Kathi1603,
Please try these few things to see if they will get your printer running again. First off, check to make sure your USB cable is properly connected at both the computer end and printer end. If that's OK..then power cycle the printer.. try to print a test page by going to the control panel from your start button and then select Printers and Faxes.. using the right mouse button for your printer, selcet Properties then pick 'print a test page' see if that works.. If that fails, then transfer the USB can;e to another USB port on your computer and retry all the previous things.. When all else fails, restart your computer and see if you can print a test page to your printer.. Hope this helps get you going..
Sep 28, 2008 | HP Photosmart C4280 Aio Printer
I need your help please!!!
unplug the printer from your computer. turn power off. see if printer goes through it's start sequence, and will print a test page(from menu)...then, connect to computer, and see if you can print test page from computer.
got backup for your computer?
Feb 12, 2008 | HP Photosmart C5180 All-In-One InkJet...
553 people viewed this question
Ben Johnson
