Question about Amana Microwave Ovens
Our microwave completly shuts down when on for more than 4 minutes. I was baking potatos and it seems to do this when it overheats
  • Amana Master
  • 9,098 Answers
If it is going dead as if someone unplugged it, it sounds like the magnetron is overheating and opening the thermostat.
This can be caused when the internal cooling fan is not running or by a magnetron that is failing.
When I say internal cooling fan, I do not mean the hood vent exhaust fan which you can turn on and off manually.
I'm instead talking about the internal fan which comes on automatically whenever you microwave.
It is vital that the cooling fan runs, or the magnetron will be destroyed.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
It's a pretty common failure.
Posted on Dec 02, 2008
Microwave won't restart after baking potatoes.
If your microwave is not a convection then the moisture most probably is somehow getting to the controls as potatoes has quite a bit.
Oct 27, 2017 | Emerson MWG9111SL Microwave Oven With...
I microwaved something while leaving chinese (metal) container in kenmore 665.61612100 microwave, and it stopped working. What do I do?
The magnetron may have been damaged, the thermal fuse will shut down the microwave to stop further damage and reset itself in 20 to 30 minutes, since that has not happened I recommend a professional at this point.
May 30, 2012 | Kenmore 68361 Microwave Oven
I have a 3-year old Amana microwave installed above my stove. Last night I was baking two potatoes in the microwave. I noticed that the microwave sounded "louder" than normal. After about 13...
No! But it will need to be repaired. Did you wrap the potatoes in tin foil? The reason for the smoke needs to be found and repaired. Smoking means a short or a part shorted, failed, or wires touching another wire that did not blow any fuss.That is not good.
Trained technicians can help the mfg improve their products if they find the problem and report it to the Mfg.
Jan 28, 2011 | Amana MVH210W Microwave Oven
Shuts down on potato button only
Not much info to go on here. Are you putting in the number of potatoes vs.the cook time? Most microwave potato functions would not read "5 minutes." It would be read as a request to cook 500 hundred potatoes.
Oct 15, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
I was cooking 4 potatoes for 14 minutes then put in frozen corn, started the microwave oven again and everything shut there an internal fuse or breaker? or is it time for a new one.
Many of these ovens have either a humidity sensor or oven cavity sensor that will shut the oven down if the internal oven cavity humidity or temperature exceed a certain level. Baked potatoes are often a culprit as they retain a good amount of heat and generate humidity when they cook. In most cases, allowing the oven to cool down with the door open for about half an hour will restore operation.
However, there is also a thermal cut-out (TCO) on some models that will trip if the internal temperature of the oven cavity gets too hot. If the TCO trips, it must be replaced.
Since you posted no Brand Name of Model Number, I do not know how your oven is configured. If you post back with this information, I can verify and may be able to diagnose a cause of your problem.
Sep 16, 2009 | Microwave Ovens
Magic chef over the oven microwave shuts off.
Is not normal for a microwave to shutdown after 4 minutes of operation.
From the info you are providing, It looks like the magnetron might be overheating causing the thermal fuse to shut it down until it cools down. There may also be a loose connection in one of the switches or a cold solder joint in the low voltage power supply.
I would suggest to check and make sure that the fans are functional, If always did; it could be that there isn't much air circulation where the appliance was installed.
Mar 03, 2008 | Microwave Ovens
Manufacturers will note that they warn in their owner manuals to never leave a microwave running unattended, so they won't help you any further, I'm sure.
Mmost modern microwaves have a flame sensor inside that will shut the microwave down completely in case flames get too high.
Then the cooling fan and power will shut off, and the fire will almost certainly be smothered pretty quickly due to a lack of air inside the oven.
Also, the inside is metal, thus the only fuel for the fire would have been the potato, which would not have lasted long.
So as scary and disturbing as this event was, I would say the real danger of a fire outside of the oven was miniscule.
The fire probably occured due to a dry or irregular spot in the skin of the potato. Once it's dry, it will of course burn much easier.
So now to the smell...
You should do a Google search on "odor microwave" or "microwave smell" where you can find tips on boiling water & baking soda, then vinegar and water in the microwave to neutralize the smell.
If your microwave does not work, then it may have blown the flame sensor (thermal fuse) and that would have to be replaced.
Please let us know if we can help further.
Nov 15, 2007 | Kenmore 62702 Microwave Oven
Magic chef microwave shuts down
We had the same problem with our brand new Magic Chef. Before going through the trouble of taking it back I called Home Depot. After talking to a Home Depot Rep I am told that the overheat sensor is under the glass plate directly beneath the popcorn bag. Popcorn gets very hot and the heat of the popcorn causes the sensor to shut the machine down. I would imagine this would be the same for a baked potato.
Very poor design.
I was told to put a microwave safe plate down and put the popcorn bag on it. This should help to reduce the heat and not trip the sensor.
A safety sensor is great, but not if it keeps tripping the machine and shutting down!
Sep 02, 2007 | Microwave Ovens
Microwave's Power goes off after 3 minutes running..
If the time from START to shut off were EXACTLY 3 minutes, then I would suspect a sensor problem or corrupted code in the microprocesor. But since that time sounds more random, it sounds heat-related, and I would suspect a failing magnetron or a failure in the cooling system. If the cooling fan is not running while the oven is cooking, this failure can occur, and can destroy the magnetron in short order. A cracked magnet (has the oven been dropped?) or other problem can cause a magnetron to go bad and overheat. If it's under warranty, I would definitely contact the manufacturer (see your manual) to find an authorized local servicer. If it's out of warranty, I would balance the cost of a new microwave versus a bench diagnosis fee of $25 or more or an in-shop repair cost of maybe $80 or more.
Oct 15, 2006 | Westinghouse WST3504 Microwave Oven
Microwave Ovens Logo
140 people viewed this question
Top Amana Microwave Ovens Experts
William Miller
William Miller
Shehu Pro
Shehu Pro
Are you an Amana Microwave Oven Expert? Answer questions, earn points and help others
