Question about Dell Dimension 4600 PC Desktop
Very slow boot up!
My desktop has become unbearably slow upon boot up and I have tried to eliminate every application or file that I don't need to aid in solving this problem with no appreciable gain. My central question, however, concerns whether my most recent Norton Anti-Virus annual download might be the culprit in this issue? It seemed to me that immediately after I purchased this annual service to be downloaded onto my desktop this problem emerged. I have written to Norton to ask about this matter and they have not given me a response - which in and of itself makes their business suspect to me.
At any rate, it typically takes 7-10 minutes to boot up and that is just unacceptable!
As a sidebar I would add that this machine operates with a Pentium 4 processor. Also, when I look at the Device Manager it reports that I typically have 47 or 48 processes running at once and I cannot determine how many of those I really need to keep because that would seem to be one possible area contributing to this issue. Hey, but what do I know about it?
Anyway, thanks for your help!
  • gshep54 Nov 30, 2008
    How might I determine which of the many processes that are shown on my Device Manager are even needed and could be eliminated without creating another issue with Windows, etc.? Can I find out with what program each one was originally installed in some way?
  • 20 Answers
Something else to try,
Do a complete disk defrag, several times if you must. And run a registry cleanup program readily found on Magazine forums such as PC World who have several listed in their downloads section. You will also find a processes info program there that explains what each process you are running is so you know what is currently running on your PC. Be careful though, many proccesses are needed by Windows!! You may still find some Norton junk floating around in the registry. Run an antispy and malware program to eliminate a chance of a Trogan. This list is of course used to support the suggestions of the others that have posted recommendations.
Posted on Nov 30, 2008
  • Frank Doll
    Frank Doll Dec 01, 2008
    I'm not talking about the device manager exactly though you should see if you have any conflicts with anything there. The NT OS uses a processes system to manage what things need to be running to provide you with the services you require to do your tasking in Windows. This list is located in the Task Manager area and can be accessed by right clicking on the task bar at the bottom of the screen. Then select "Task Manager" and click on the "processes" tab. The applications tab shows what programs are currently running on your OS. Like Outlook,IE, Word,Access,etc...The fewer applications, the faster the machine. The same holds true for the "Processes" list. It should say what is "running" and which is not. Turning off any unused or unneccessary porcesses will increase your PC speed. the utilities I mentioned on the PC World are also available at www.downloads.com also. There at least a couple that address the processes list and explain the meaning of all the little things running all the time on your PC. Or just Google the request for the software and Google will give you tons of sites to obtain this valuable software.
  • Frank Doll
    Try not to confuse Device Manager and Task Manager. They are 2 different things altogether. Device manager checks to see if there is a problem with a device ie; mouse,keyboard sound card etc... and if there is conflict with each one and that their appropriate drivers are working together.
    Task Manager lists what resident processes are installed and if the're running or not. An example is the program that searches for wireless networks in the area. If this is running but you don't use a wireless connection, you can turn off this process. The software I have mentioned can assist you in determineing this and help you decide to turn it off and open up memory. Thus increasing speed.
  • 55 Answers
You may want to make sure that you dont have 2 applications of Norton running. Two antivirus programs will tremendously slow down your system
  • 37 Answers
Another common reason for this is dust behind th heatsink fan that tends to clog up fast..if u do undertake this make sure b4 u go inside th tower to ground ur static electricity by touchin a radiator or summing metal.. remove th 4 screws attaching th fan to th heatsink.. no need to remove th heatsink itself (th square metal block with slots covering th processor) jus dislodge all th dust after uv removed th fan then with a small hoover or hoover attachments get rid of it all..careful not to touch components.. good luck chuck.!! xx
Posted on Nov 29, 2008
  • 55 Answers
firstly you boot the pc in safe mode by press f8 at booting time. then you remove norton antivirus from it and then go to command prompt and type msconfig and remove all the item from startup. then boot it.
i think it will solve your problem
ramesh
Why is my computer so slow??? It is only 2 years old
One of the most common reasons for a slow computer are programs running in the background. Remove or disable any TSRs and startup programs that automatically start each time the computer boots. Tip: To see what programs are running in the background and how much memory and CPU they are using, open Task Manager.12 Jul 2017
My computer is running slow, what steps can I do to fix it?,,
or try removing stuff you dont need anymore.like music or pictures.
try doing a disc clean up or a defragment.
Oct 23, 2017 | Computers & Internet
Why is my OS is very very slow working???
Here's a few tips you can try to fix your slow startup problem. First of all you want to disable any programs that are in the startup menu that you do not absolutely need. There is no sense in waiting for programs to load that you don't use on a regular basis. Or if you are not sure which one is slowing your startup. You can disable them one at a time.
If that did not help, you can disable your Windows sidebar. You'll also want to remove any icons from your desktop that you do not absolutely need. The same goes for your task bar and quick start menu. All of these will slow down your boot time.
Check to make sure your anti virus program is not scanning at startup. Some programs are set to scan. When windows boots, by default. You will also want to do a full anti virus scan to make sure you don't have a worm or any other type of virus that is working in the background slowing your operations down.
The biggest reason for a slow boot time is a corrupt or damaged Registry. The registry will become corrupted from installing and uninstalling programs. Perhaps you have loaded programs onto your new Vista computer and were not compatible and then uninstall them. They leave behind files, which Windows tries to reference on startup. Since they are no longer on your computer. Your system goes through a long search trying to find them. You need to clean and optimize your Windows registry to eliminate any bad or orphaned files.
You can do this manually if you are an experienced computer technician. It is not recommended for most users. Windows does not have a built-in tool for repairing, cleaning, or optimizing your registry. You will need to download and run a third-party registry repair program to do this.
A good piece of software that will do this for you with a click of the mouse is a wise investment for any computer. You will have it for years to come, and can schedule it to do weekly maintenance. This will keep your PC fully optimize and running fast. It's like giving your computer a tuneup.
Jun 17, 2011 | Microsoft Windows Vista Ultimate Edition
My nokia E61i is very slow.....why?
Maybe you can have a try with LEO Privacy. Cause my phone always hang and it makes my phone fly: goo.gl/BCKwGq
Jun 12, 2011 | Nokia E61i Cellular Phone
MC70: the scanners are becoming slow, not loading and no...
You could try and blank the Application folder. This would require installing any software and settings you require:-
Clean Boot Files for WM5
http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=11744&sliceId=&dialogID=175898313&stateId=1%200%20175894231
Clean Boot Files for WM6
http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=12268&sliceId=&dialogID=175898313&stateId=1%200%20175894231
Also there is a firmware update for the Siemens MC75 v2 GSM card. That may help your SIM issues.
http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=12351&sliceId=&dialogID=175898529&stateId=1%200%20175894293
If its not that try and clean you SIM card and contacts.
Hopethis helps.
Ifyou need any more help then please do not hesitate to contact us:-
helpdesk@biastechnology.comor TEL 01202 620955
http://www.biastechnology.com/
May 17, 2010 | Symbol MC70
My computer has become very slow. Particularly, if I highlight a website in an e-mail, it takes "forever" to load. Is there a free download that can speed up my computer? I have downloaded things in the...
Hi
Here's the order in which things should happen. First download and run these programs AVGFREE.exe, MALWAREBYTES.exe and SUPERANTISPYWARE.exe. This will eliminate all the virus'e and spyware. Now you can download and run CCLEANER.exe. This will eliminate all the garbage in the file system and the registry. Now if need be you can download and run PC_DECRAPIFIER-2.0.0.exe. All these files you can get fro free at www.download.com. Good luck
Mar 02, 2010 | Dell Dimension 3100 PC Desktop
Computer is slow while booting
So many resion for system slowness,firsly depends on your system configuration,
booting depends upon your system RAM,how much RAM you user in system,min 1GB RAM require for smoth booting.second one is overload (tmp,recent,temparary internet files,cooks),delete all the files and restart the system.
check it issue will be fix,otherwise there was a problem with OS.
backup all the C drive data on anohter drive and reinstall OS in C drive.
Surly issue will be fix.
Thanks,
Nov 19, 2009 | Dell Dimension 2400 PC Desktop
Computer slowed down considerabily.
Check whether this is not a viral slow down. If not i suggest this
1. Give enough space to the hard drive.
2. Uninstall unused application for a long time and not needed anymore.
3. Install Ccleaner, this can clean your registry, cookies, and other junk files.
4. Defragment your drive. If you have enough space already.
May 03, 2009 | Computers & Internet
Slow startup and overall operation
Well, there are a variety of reasons that can consequently drag down the performance of your Mac. Meanwhile, there are certain ways through which you can considerably speed up your Mac machine. For example, you can reset the browser settings to regularly clear useless caches and history, get rid of all unwanted widgets from the dashboard through the Dashboard control panel, remove unnecessary applications, find out & delete those duplicated files. However, if you prefer a more efficient way to speed up your Mac, try the following all-in-one Mac speedup tool as it can help resolve all issues in just a few clicks.
Read more from: http://www.howtospeedupmac.com/
Hope this helps!
Apr 13, 2009 | Apple iMac G4 Desktop
Installed new windows xp home but still have xp professional installed aswell
u dint formatt it then boot from xp cd fdel all partions then format it quick then rebot xp on k
Oct 07, 2008 | HP Pavilion a810n (PP164AA) PC Desktop
Acer Aspire 5580 suddenly slowed down
Your acer is infected with virus that current antivirus cannot detect. uninstall new application programs that make your computer slower. however if non of those causes; please try to check the memory maybe is not function well. if it is not the cause then; You should reinstall your system to fixed all error on it. ( note: reinstalling will remove some important files and you should back up) Further more; the best thing to do is format the HDD and install the new windows.
Harry: take note: that other causes of the computer slower is the HDD , I encountered 50 times problems that computer become slower bcoz of the hard drive mulfunction. If this is the case you should replace hard drive that is covered with warranty.
Jan 09, 2008 | Acer Aspire 5500 5570-2609 Laptop
Dell Dimension 4600 PC Desktop Logo
131 people viewed this question
Alun Cox
