Question about Samsung V20 XVC 2400 Notebook
Samsung v20 display keeps going i have changed the screen cable
  • reddevil55 Dec 02, 2008
    yes I did mean the internal screen cable, I have bought a replacement cable and fitted it but where it plugs to the motherboard is still giving problems. I just need to know if it is the Motherboard that the screen cable plugs in to
  • Chester Harvards
    Chester Harvards May 11, 2010
    Do you mean NEW external monitor cable or New LCD screen panel cable, which must plug in motherboard of inside laptop; That's totally different, for the external cable you can plug it by your self, but for the internal LCD pane cable, you can't DIY.
The plug on the screen ribbon cable which connects to the motherboard has dry solder joints. Closing the screen and typing hard on the keyboard can break these joints very easily. All you need to do is re-solder the joints. This is a very delicate job and requires a lot of patience.
Posted on Dec 02, 2008
How to fix my screen?
check and make sure your video card is seated properly if it is my best guess without doing any testing is that your video graphic card is broken
Jan 08, 2015 | Samsung 700Z COREI7-2675 15.6 8GB 750GB...
Samsung sens v20 laptop power on but no display
Any sound? Does the HDD led blink during start-up? Can you hook it up to a external display? If so, what is on the screen?
Nov 27, 2013 | Samsung V20 XVC 2400 Notebook
Screen flickering
Display Configuration
A flickering screen may be caused by the computer detecting incorrect display settings as it starts or returns from sleep.
It can also come from changes to the screen resolution settings caused by a new program or update installation.
Verify screen resolution before assuming the issue is hardware related.
Faulty Inverter
Next to the display screen behind the plastic screen bezel is a small component called the inverter, which supplies power to the screen backlight.
The flickering indicates the power is not reaching the backlight.
To fix the issue, replace the inverter.
Faulty Connectors
The wires and cables traveling from the display around the hinges and into the motherboard tend to wear at the hinge area.
Over time, the opening and closing of the screen causes this wear.
The solution is to disassemble the plastic casing of the laptop, reorganize the cables so they have no interference from hinges, or replace the cables and connectors with new ones made specifically for the computer make and model experiencing the issue.
hope this helps
Sep 13, 2012 | Acer New Aspire TimelineX 5830TG 5830G DC...
Laptop screen flickering diffrent colours
Hook a spare monitor to the video ouput usually on the back, if picture okay! the problem is the new LCD screen or video cable which you replaced, if both show the same symptom it is the video graphics card normally built into the motherboard.
Apr 02, 2012 | Samsung R519-53S Notebook
I start samsung v20 up and all I get is a blank screen. I can hear sound. Please can anyone help
This problem could be caused by a number of issues.
First of all you will have to trouble shoot the GPU (graphics processing unit). To do this you will need to hook up an external monitor to the laptop and use the keyboard to switch from the laptop screen to the external monitor. If you can see the information on the screen then there is nothing wrong with GPU.
If that is the case then you need to be looking at the cables that lead from the laptop motherboard to the inverter and also the ribbon cable that runs up behind the the screen itself. This means you will have to disassemble the laptop.
If the laptop is still under any warranty then i recommend that you arrange to send the laptop in to Asus as disassembling the laptop will certainly void the warranty.
If the laptop has run out of warranty and you are prepared to have a go at it yourself then click on the link that i have provided below for a short guide with pictures explaining what i have told you regarding the cables >>>>>>>
Please note that if you feel that your unable to check the cables or disassemble the laptop then i recommend that you take the laptop to a reputable PC repair store and have them check on the cables and the LCD screen itself.
Good luck and please post back if you require anymore assistance.
Jan 06, 2010 | Samsung V20 XVC 2400 Notebook
Blinking toshiba satellite A 05-54547 problem
A blinking monitor just might be a loose connection of the main display cable that runs up the left side of the display and connects to the motherboard. Also check the two wire cable attaching the inverter to the screen. The bezel of the screen will have to be removed as well as the power strip and keyboard to check the display cable. Remove the lcd screen from its hinges and look behind the display, there is a flat cable that plugs into the top edge of the screen. This cable has a habit of getting loose and falling out of the socket.
Now there is a chance that the BIOS of the laptop needs to be updated. There are many instances where the display starts acting up and a BIOS update is the correct action to take. Go to the Toshiba support site, put in the model number and then put in your operating system. Scroll down to where the BIOS is listed under downloads/drivers. Download and install the new BIOS, reboot.
Nov 08, 2009 | Computers & Internet
sounds like your new screen cable is either loose or faulty.i had same problem and was only after i had removed keyboard and ensured cable was tightly connected did i solve the seems to be a design fault in the samsung v20
Jan 24, 2009 | Samsung V20 XVC 2400 Notebook
I opened my samsung v20 laptop and now my mouse pad dont work. There is a cable loose but i dont no where it goes.
hello.. You have to put the ribbon cable back on to the mouse pad. there will be a socket under the deck lid where you need to reconnect the ribbon cable. there might be 2 little tabs on each side of the socket if there is, pull the tabs away from the socket carefully, slide the cable in the slot, and then slide the tabs back. that will lock the ribbon cable in. be careful. those sockets can get damaged easily. good luck !
Jan 19, 2009 | Computers & Internet
Screen Keeps dimming and contrast function does not work
This is possibly, a loose cable or the screens inverter board is overheating. the inverter is similar to a booster in a flourescant light fitting. which converts power from DC To AC and boosts up the panels Light Tube. CFL if it,s faulty or overheating. this will cause the panel to dim.
also check the plunger at the underside of the screen, isn,t sticking down. designed to cut off the panel when the lid is closed. Finally some model laptops, only boost the brightness running on A/C Power. the battery would run-out fast with screen at full brightness. if theres an fn key on the keyboard, press fn and the brightness button to adjust screen brightness.
Mike @ Compurepair.
Jul 31, 2008 | Samsung V20 XVC 2400 Notebook
Screen fault on samsung v20
screen tube or inverter board faulty.
change the inverter board, then replace the CFL tube.
Or replace the whole tft screen.
Mike @ Compurepair.
Jul 09, 2008 | Samsung V20 XVC 2400 Notebook
Samsung V20 XVC 2400 Notebook Logo
347 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
