Question about Bosch Classixx WFC 2465 Front Load Washer
Bosch Classixx 1200 Washing machine won't drain & spin
This had been working flawlessly, but about 3 months ago, it started behaving interestingly....
It washes fine, but then stops before the drain & spin, leaving the door locked (as there's water in there). If you turn the dial to 'spin' and press start, it drains & spins fine. so that's what we've been doing, but it's getting annoying.
the rinse hold button is not on, I know this because the LED works on it - you can click it on & off.
I'm pretty handy, so can attempt any fix, but there's no point in taking it to bits unless I know what I'm aiming at & at the moment I don't have a clue!
Thanks in advance,
  • jheath Nov 30, 2008
    Thanks for that - I can't see how there can be anything wrong with the motor - it all works fine, you just have to manually make it do the drain & spin. Once you do all of that, it's OK, so most of the controls are working OK, it just refuses to complete the cycle automatically
    Thanks - I understand now - I'll see if I can find them cheap in the UK
  • 311 Answers
The motor and motor control unit need to be replaced.
Thanks, please leave feedback or contact me again for more info if you need it.
Posted on Nov 29, 2008
  • JEFF SIEGEL Nov 30, 2008
    I realize that, but Bosch always rec's replacing both. You can try new controller only to save a few bucks and see if that works. I have had this issue before and have never had a recall by repl both parts. If your machine is under 2 yrs old parts are under wty.
I have a Bosch clasixx 1200 s express washing machine, When I select a program the machine buzzes but the cycle doesn't begin. The drain cycle works and the spin works. if i select freshen and rinse the...
Bosch clasixx 1200 This video will show you How to find the fault on a Washing Machine that Won't Drain or empty the water away on Bosch
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Feb 26, 2011 | Bosch Classixx WFL 2066 Front Load Washer
The 03 error code is the drain. Disconnect the drain hoses and check for blockages. If no blockage "time" the drain interval. If it's more than 6 minutes it's the pump. Also make sure you're using the correct type of soap so the ball check valve on the bottom of the outer drum isn't getting fouled with excessive suds. Also disconnect the drain hose from your house plumbing and let it free flow on it's own. This will tell you if the block is in your plumbing, and not in the machine. Assuming that your filter is clean.
Pl rate me ‘very helpful’ for the free help!
May 31, 2010 | Bosch Classixx WFL 2066 Front Load Washer
Bosch classixx 1200 It take in water then stop. I can drain it but it will not spin.
It looks like there could be a problem with a belt, maybe it sliped off, or maybe it broke, i would look that first
Nov 04, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Classixx 6 1200 Express washing machine manual
whay may nero 9 serial number it das not working? ma old S.N invalid
Nov 01, 2009 | Bosch Washing Machines
Bosch 1200 classixx not spinning
bosch 1200 classixx not working properly. On 12 min spin cycle it starts then after 1 min timer reads 0:01 and it stops. washing cycles run but doesn't seem to be any spin action
Oct 12, 2009 | Bosch Washing Machines
Bosch classixx 1200 washing machine stalling mid-cycle
I`ve just spoken with Bosch Product Advice service about this problem. This could be happen when door is open after programme has been started. I didn`t check yet is working.
Thanks, roman
Mar 31, 2009 | Bosch Classixx WFL 2066 Front Load Washer
My bosch classixx 6, 1200 express washing machine keeps displayin
Bosch classixx 1200 express washing machine won't drain
Mar 29, 2009 | Bosch Washing Machines
Bosch Classixx 1200 Express wont spin!!!! HELP
Make sure that all the water has drained from the washer, if it has a filter, remove and clean, it is located behind a removable plastic panel at the front of the m/c, if it still does not spin, suggest you remove motor and check the brushes for wear, this is often the reason it won't spin, but will wash o/k.
Plz rate my solution.
Dec 22, 2008 | Bosch Classixx WFC 2465 Front Load Washer
My bosch classixx 1200 express
Close the door and turn the dial to drain
Jan 11, 2018 | Bosch Classixx WFC 2465 Front Load Washer
Bosch Classixx WFC 2465 Front Load Washer Logo
434 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
