Question about Frigidaire FDE336RE Dryer
Need to know how to replace the belt on my dryer
The dryer is a frigidaire
model # fde336res2
can you tell me how to put the new belt on?
    Sergeant:
    Champion:
  • 311 Answers
Take off front and put belt over drum. Reinstall front. Take small access panel off back to install belt on motor. Idler pulley pushes against belt to tension it. Thanks, please leave feedback or contact me again for more info if you need it.
Posted on Nov 29, 2008
Frigidaire model FDE336RES2 makes a squealing noise and won't turn with a full load in dryer.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 03, 2011 | Frigidaire Dryers
Frigidaire dryer model FDE336RES2 won't run when you push the button. How to troubleshoot? I check power to unit and its OK. could it be the thermal limit part?
There can be many reasons why your dryer will not start orturn...
heatman101
Sep 21, 2010 | Frigidaire FDE336RE Dryer
Dryer vibrating with overheating smell
The vibrating is usually the blower wheel not being balanced or worn and not spinning, therefore it does not blow enough air and therefore the system overheats-----and so, the smell. Some models need to be serviced from the rear, others need to have the front face removed to access the blower wheel assembly. The blower wheel is approx. $25 part but you need the skill to access and replace it properly. Goodluck, Macgivor
Dec 27, 2009 | Frigidaire Dryers
Frideraire dryer model fde336res2 won't eat. The
Take a look at #36 in the breakdown I have attached. This part is called a thermal limiter and blows if the heat is restricted in any way to cause the dryer to get too hot. You need to make sure that you don't have a lint buildup around the motor and in your vent hose. The part number for this part is 530320912. Hope this helps.250
Nov 19, 2009 | Frigidaire Dryers
Frigidaire FDE336RES2 Dryer marking Clothes
Excessive lint on or near the heater coils will send smoldering lint onto the clothes. Use a flash light and go inside the drum to see the heating coils or lifting the top up who should be able to see the lint build-up on the coils. These need to be cleaned.
Nov 10, 2009 | Dryers
Frigidaire model # FDE336RES2 Wont turn on.
The fuse is located on the rear wall upper right hand corner. To get to it you must bust dat dryer down. HERES HOW
Jun 11, 2009 | Frigidaire FGR341AC Electric Dryer
Dryer will not heat up
check that you didnt disturb any wireing by mistake. then chec the contunity on your heating element. they are actually pretty fragile.
Apr 25, 2009 | Frigidaire FDE336RE Dryer
Loud thumping noise in Frigidaire model # FDE336RES2
You have to remove the top lid. Then remove the front panel. Then remove the belt and drum.
Your problem is a bad rear drum support assembly.
Remember to unplug the dryer.
Mar 27, 2009 | Frigidaire FGR341AC Electric Dryer
Broken tumbler belt
Slide a putty knife or other thin object between the top and front panels a couple inches in from either side. Press in and release the two spring clips holding the top panel and at the same time lift it up and lean it back. Remove the screws inside the front corners holding the front panel on. Place the new belt around the drum in about the same position as the old one was. Remove the lower rear panel to access pulleys. place belt around the motor pulley. Stretch the idler arm over and place belt around pulley. Reassemble.
Jan 03, 2008 | Frigidaire FDE336RE Dryer
Wiring diagram
check this and see if this helps you out http://www3.sears.com/imaging/ImagePageJava.shtml?productTypeID=0151200&brandID=1428&modelDesc=FRIGIDAIRE/FS%20DRYER%20-%20P5995326211&modelNumber=FDE336RES2&documentID=Y2705791&documentTypeID=PLDM&documentClassCode=PM&titleType=131850300%20WIRING%20DIAGRAM&titleID=00006&
Oct 08, 2007 | Frigidaire FDE336RE Dryer
Dryers Logo
239 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
