Question about Nikon D100 Digital Camera
Nikon D100 Hi. Out of the clear blue my af lens doesn't work. No motor sound. Can use manually. Is there a motor in the lens that needs replacing? I think its only 4 years old (inhered camera). Nikon AF 70-300mm. I don't really have the money to go to camera store without indications of what I need. How costly is the motor? Also there is no light on the internal view box. Can you help? Thanks, Mary Louisville, KY
    Scholar:
  • 48 Answers
If the lens is AF (not AF-S) there is no motor in the lens. A motor in the camera turns a screw in the lens mount to focus it. If it is easy to turn it manually, my first recommendation would be to check that you didn't accidentally bump the focus selector switch to M. The focus selector is the rotary switch below the lens lock button. If it's on M, switch it back to S (for single-frame) or C (for continuous focusing).
Posted on Feb 28, 2009
    Novelist:
  • 121 Answers
Izzy41,
make sure the lens is properly connected and aligned, if it has been remove recently it may not of been put completely back to the right position causing the contacts to not align. Turn off the camera and remove and then remount the lens. The motors and the cost to replace/repair are almost as much as a new lens. Your lens can and should last a long time unless it has recently been dropped or tried on a camera (forced) the wrong way and the contacts were bent or damaged.
randy320sgi
Posted on Jan 08, 2009
Does the Nikon AF 70-300mm f4-5.6G Lens work with the Nikon D3100?
Yes, as long sa the lens can fit the bayonet. But it can't focus, because there are no AF motors in Nikon D3100 and AF 70-300mm f / 4-5.6 - G. And Nikon lens with AF is without AF motor. Lens marked with AF-S have focusing motor
Jul 23, 2013 | Nikon Cameras
Autofocus on Nikkor 18-55mm lens doesn't work
probably you have problem with the focus motor, i ever have same problem and need to replaced the focus motor.
Jun 08, 2013 | Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX...
My focus will not work on my tamron aspherical 18-200mm
Hi Missy - certain Nikon bodies lack the built in auto focus motor as a way to hold costs down and make them affordable. The problem is that any lens purchased for these bodies will need to include the motor - and adds the expense to the lens. Instead of paying for the motor once in the body, the owner will need to buy it in every lens purchased for that body. As of this writing, the Nikon bodies that lack an AF motor are: D5100, D5000, D3100, D3000, D60, D40X, D40.
When selecting a lens for one of the cameras listed above, you must choose the model for a Nikon that needs the AF motor built into the lens. Tamron sells lenses for these camera bodies and states they have "BIM" or "built in AF motor" and similar. In any case, regardless of lens manufacturer, you must purchases lenses that have the AF motor built into the lens, otherwise it will not be able to auto focus. Here is a site with a list of all lenses known to to have the AF motor built into the lens.
I hope this helps & good luck!
Apr 29, 2012 | Nikon Cameras
What digital nikon cam works autofocus in a nikkor micro AF 105mm f/2.8D?
This lens lacks the autofocus motor, so it will only autofocus on cameras with the motor. This lens will autofocus on every Nikon digital SLR except for the D40, D40x, D60, D3000, D3100, D5000, and D5100. It will autofocus with the D1 family, D2 family, D3 family, D50, D70, D70s, D80, D90, D100, D200, D300, D300s, and D700 (I hope I haven't left any out).
Jul 03, 2011 | Nikon Cameras
My friends father recently stumbled upon a 100-300mm quantaray. It connects Nikon 3000 and my d5000 but the af doesn't work. We've looked it up and down for a button to switch to AF but there's...
That lens has a coupling on the lens mount which you'll see rotating when you alter the focus ring and look at the back of the lens. it does not have an in-built focus motor and so will only autofocus with Nikon bodies which incorporate a mechanical AF coupling on the lens mounting flage.
May 17, 2011 | Quantaray Cameras
I have been given a 100-300mmF4.5-6.7DL Sigma lens but it will only work in manual focas AF but does work on a friends Nikon is that because my D40X has no AF motor.
That is exactly why the auto-focus (AF) does not work with that lens on this camera. The D40, D40X, D60, D3000, D3100 and D5000 lack an AF motor built into the camera. These cameras will require that the lens have the AF motor to work as expected.
You can review a complete list of lenses (as of 8/2010) that have a built in AF motor here.
Please rate this reply - thanks!
Dec 03, 2010 | Nikon D40x Digital Camera
Nikon 70-200mm f/2.8D VR G-AFS ED-IF Lens this will work for d3000
This lens and ANY Nikon lens that has AF-S (built-in lens motor) in it will work with the D3000. In addition, some of the newer Tamron, Sigma and Tokina lenses that have the motor built in will work.
Be careful though in holding the heavy lens simply by the DSLR grip. The lens mount may not be able to support the strain.
Hope this helps, Andrew
Apr 17, 2010 | Nikon 70-200mm f/2.8D VR G-AFS ED-IF Lens
Nikon D50 with Nikon DX 18-55 lens will not focus
Sorry to hear about your lens. If you are able to autofocus and take pictures with any other lens, then it means that your problem lies with the kit lens. If you can take picture in manual mode, but not in autofocus mode, then the AF motor in the lens in not functioning. I had the same thing happen to my 50mm 1.4 lens.
Depending on your location, there are Nikon repair centers in Melville, NY and Torrance, CA.
Hope this helps,
Andrew
Apr 16, 2010 | Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX...
My Nikon D60 wont auto focus on any of my lenses. Could it be a problem with the body?
The d60 needs Auto focus lenses(Ones with motors inside the lense) it doesn`t autofocus on other lenses. this was done to reduce the price of the camera body
Hope this helps
Aug 04, 2009 | Nikon D60 Digital Camera with 18-55mm lens
Low light no focus
The Nikon D100 custom settings option 22 - AF Assist, controls the AF Assist light.
Check if this has been turned off.
This option controls whether the auto-focus assist light comes on in low light to help autofocus
latch onto the subject.
Jul 15, 2009 | Nikon D100 Digital Camera
Nikon D100 Digital Camera Logo
91 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
