Question about Canon CanoScan FB320P Flatbed Scanner
ScanCraft CS-P always says there isn't a scanner connected or that there might be something in the parallel port
But the scanner is connected and I don't know what a parallel port even is. All the plugs are connected and everything, so I'm confused.
  • 4 more comments
  • Frankie Strada
    Frankie Strada Jan 18, 2007
    -I am using a USB cable
    -And no I haven't
  • Frankie Strada
    How do I uninstall everything?? Am I somehow supposed to uninstall the scanner?
  • Frankie Strada
    After I uninstall it all what am I supposed to install back??
  • Frankie Strada
    Yes I installed scanner software..ScanGear or ScanCraft..
  • Frankie Strada
    Yes I got it recently and it is used
  • Frankie Strada
    Frankie Strada Jan 20, 2007
    Um the outcome was that it wouldn't work. The program said there was no scanner connected even though there was. It also said something about a TWAIN source, like a problem with the connection, but I don't know how to set that up and I think I might be supposed to.
  • 624 Answers
Evening MCRmyFranKIE, A parallel port is commonly known as a printer port or LPT1 port. Before USB ports existed scanners frequently used them to connect to computers. The connector on the PC is typically *D* shaped and contains two rows of 25 pins, about 1 ¾ inches wide. Questions for you: -Are you using that kind of cable or a USB cable? -Have you tried uninstalling and reinstalling the software following the instructions yet? Once you give us some more information we can continue.
Posted on Jan 18, 2007
  • 3 more comments
  • tomj23 Jan 18, 2007
    Wow, that was the quickest anyone has ever responded ? live time!
    OK, USB is far easier to install than parallel port. I forgot to ask if you are using Windows XP but for now I?ll just assume that is the case. Unplug the USB cable from your computer and uninstall the software. Reinstall the software from scratch following the instructions exactly. One thing to note is that the scanner should stay unplugged from the PCs USB port until prompted by the software or the instructions. Once you are you should see a series of pop-up detecting the hardware unless we have a problem.
    -If nothing happens test to make sure your scanner is getting power. There should be an LED to indicate that.
    -If still nothing try unplugging the USB cable from your scanner and insert it into another USB port on your PC. Make sure you are plugging directly into your PCs USB port not a USB hub.
    -If still nothing try another USB cable, preferably one you know works.
    If you get this far and still nothing let us know what happened at each step, what operating system you have, what kind of PC (Dell, HP, etc.) and any other information or history that seems pertinent.
    OK, again assuming you?re using XP click on Start, settings, and control panel. Find and double click on the icon that?s labeled *Add or Remove Programs*. When the Add or Remove Programs box appears it will list all the programs installed on your computer. Now this is the tricky and potentially dangerous part, you have to go through the list and one by one highlight the canon scanner programs (there may be one or a couple) and click the Change/remove button to the right. Chances are the right one will contain the words Canon and/or scanner.
    Once you?ve done this go ahead and try what I suggested previously. Its getting late here so I?ll be off-line for about nine hours.
    the original software that came with the scanner. Did you in fact install scanner software?
    OK, if that is the original install CD it should say Canon scanner installation CD on it. If it does then all you have to do is unplug the USB cable from the PC, pop the CD in the PC and follow the installation instructions.
    If the CD doesn?t say Canon scanner installation CD (or something thereabouts) it may be an extras CD in which case you?ll need to download software from the Canon site.
    I take it this scanner is something you just recently got, probably used correct?
  • tomj23 Jan 19, 2007
    What was the outcome?
No parallel port on my computer. USB -parallel
This scanner is an old one so it has only parallel port. You can connect it to any USB with the converter you mentioned and should be working. Did you connect the power supply at the scanner too? It is nesessary for the scanner in order to take power.
Stelios.
Feb 22, 2010 | Canon CanoScan N640P Flatbed Scanner
Usb 1.0 or usb 2,flatbed scanner compatability
Find a USB device, such as a memory-stick, that is "USB 2.0" and connect it to a USB port. If Windows XP pops-up a window ("this device will perform better when connected to a USB 2.0 port"), then you have connected it to a USB 1.1 port.
Yes, you can connect a scanner, if it has a USB connection. Not all laptops have a parallel-port ("old-style" printer) port, but some scanners require a parallel-port.
Jan 29, 2010 | Computers & Internet
My new computer doesn`t have a parallel connection for my Canoscan N640P. Can I get something to convert to USB. Thankyou
yes, there are cables the will convert a parallel connection to usb. do a search in google for "parallel port to usb" and there will be some links to some stores that sell them.
Nov 24, 2009 | Canon CanoScan N640P Flatbed Scanner
Connecting old IBM color flatbed scanner to new computer
Not likely to work reliably if you get it to work.
The parallel port must be set to communicate in both directions. The SUB to Parallel adapter may be a ONE-WAY communications device.
Get a new (or used) Epson scanner or Epson all-in-one ($50) which includes a scanner and printer! Your new computer may not have the proper drivers for your old IBM scanner, anyway. If you purchase an Epson all-in-one, get a "WorkForce" model - that's their latest product line.
Sep 28, 2009 | IBM Color Scanner Flatbed Scanner
Cable connectivity with my laptop through a "parallel to usb cable". My laptop has no parallel port but only usb ports.
make sure you follow this step :
1. install driver USB to Paralel port (LPT1) before the cable connected to PC
2. After the driver installed, install the cable - and it supposed to be detected
3. the last think u have to do is install the scanner/printer driver
if it is not work, i guess the problem is on the USB to paralel adapter, or the driver not installed correctly
Jun 01, 2009 | Acer ScanPrisa 640P Flatbed Scanner
No port for printer connection
It has usb ports... if your printer is Parallel you should purchase a parallel to usb adapter.
here is an example of an ebay auction for one...
http://cgi.ebay.com/USB-to-PARALLEL-PRINTER-ADAPTER-1284-CABLE-36-PIN-IEEE_W0QQitemZ250463737409QQcmdZViewItemQQptZPCA_Cables_Adapters?hash=item3a50cd5641&_trksid=p3286.c0.m14
They are cheap
Hope this helps.. remember if the cable is not long enough on the adapter you can always buy a usb extender.
Apr 12, 2009 | Compaq Presario S200
Cannot detect scanner
There is going to be issues with connecting it in this fashion. The usb adapters are not addressed the same as a real parallel port. This means that the drivers probably do not have a chance at working. The other issue is usb ports on laptops rarely have the power to drive devices larger than a mouse or keyboard. This means that the usb adaptor may not have enough power to function. Try plugging it into a powered usb hub then to the laptop. This may give it enough power to do what you want if the drivers are compatible of course.
Good Luck.
If all else fails goto goodwill and get a usb scanner. I always see stacks of them. Most are the usb type.
Feb 20, 2009 | Canon CanoScan N340P Flatbed Scanner
INSTALL AN UMAX ASTRA 1220P TO AN USB PORT ON A LAPTOP USING XP
The 1220P (P = Parallel) does not have a USB port and Windows XP does not support it.
Jun 16, 2008 | Umax Astra 1220P Flatbed Scanner
Canon i350 printer
download the driver from some of these sites and try:
www.opendrivers.com/categorycompany/13/129/printers-canon-free-driver-download-page6.html
printers.free-driver-download.com/canon.html
multifunction.free-driver-download.com/Canon/33451/Canon-imageCLASS-MF5730-MF5750-MF5770-Firmware-Update
www.fixyourownprinter.com/forums/inkjet/21129
scanner.free-driver-download.com/Canon/29335/Canon-CanoScan-D660U-Scanner-Driver-ScanCraft-CS-P-v5.8.2-Wi
cameras-and-mp3-player.free-driver-download.com/.../Canon-PowerShot-A60-Firmware-2.0.0.0-For-Windows.html
www.softpedia.com/?tag=dir
Feb 09, 2008 | Canon i350 InkJet Printer
Printer Port is used by another device
Just only check and delete error print task queue in all of printers.
Start->settings->printers and faxes.
Right click and open each printer on your machine to find which printer remain error queue and delete it.
Good luck...
sUPERTUYZ
Jun 18, 2006 | Canon CanoScan N340P Flatbed Scanner
Canon CanoScan FB320P Flatbed Scanner Logo
241 people viewed this question
Clive
Clive
old marine
old marine
