Delay function in 'C'
Source code for the Delay function in 'C'
  • Teis Thomsen
    Teis Thomsen May 11, 2010
    Could you bee a bit more specific?
    OS?
    How?
    President:
  • 2,110 Answers
First #include <dos.h>
then use delay("millisecond")
Posted on Nov 29, 2008
My Westinghouse dishwasher is displaying HO2 what does it mean.?
H01-H24 Delay has been selected.so H02 means you have selected two hours delay.
Cancel delay setting if you don't need it.
Time Indicator and delay display:
The time indicator displays the program time and time
remaining for the program
In addition, you can delay the start of the program by
pressing the "+" and "-" buttons before the program is
commenced The delay function is indicated by the letter
"H" followed by the number of hours selected
If you want to change the delay time, you can reset it by
pressing START/PAUSE and then using the "+" and "-"
buttons to select the new delay time, then press START/
PAUSE to activate
Westinghouse WSF6606 User Manual Failure Codes And What To Do In Case Of...
Oct 25, 2017 | Westinghouse Dishwashers
How to set the rain delay time when it is set to active
Are you talking about the windscreen wipers?. If so a censer causes the wipers to operate when it starts to rain. the delay controls the speed of the wipers . The drivers manual will explain all the functions if you read it.
May 28, 2015 | Cars & Trucks
What does IH MEAN ON MY DISHWASHER G.E.
Instead of IH, could it be 1H (as in "one hour")? Sounds like you activated the 1 hour delay function. If so, press the "Delay" button a few more times to turn off the delay feature.
Oct 05, 2014 | GE Dishwashers
I have a 87 relient that is experiencing wiper problems. low and high speed work ok, delay does not function is stays in low. when switched from delay to either low or high wiper quit functioning. a click...
To the best of my knowledge, no parts are available for this problem.
This will be a big hunt for you to try to get the help you need.
Try car parts stores, car dealer ships, then go to Amazon and finally e-bay.
Feel free to take any side trips you wish in the looking.
I have had similar problems myself with malfunctioning delay circuits.
Perhaps your best bet its to try to find an older mechanic who knows how to by-pass the problem and cut the delay out of the circuit.
God bless your search.
Sep 08, 2017 | 1987 Plymouth Reliant
My 2270 jambs paper from tray one every time. I changed the pickup rollers still no help. All my other trays feed properly even the stack bypass
Hi mate,
Prior to your issue i may enlighten you with this source.
Technical Infomation 0105/0101/0102/0103/0201/0202/0203/0204 Jam Code: Paper lint adheres to surface of vertical path roller
Description
Since a type of paper that can easily generate lint was used, the paper lint adhered to the surface of the vertical path roller and decreased the paper feed performance of the roller, causing the jam code "0105."
Depending on paper sources, the following jams occur.
- Cassette 1: 0105 (registration sensor PS9 delay)/0201(cassette1 retry sensor PS10 stationary)
- Cassette 2: 0101 (cassette 1 retry sensor PS10 delay)/0202(cassette 2 retry sensor PS11 (cassette pedestal) delay)
- Cassette 3: 0102 (cassette 2 retry sensor PS11 delay)/0203 (cassette 3 retry sensor PS1 (cassette pedestal) delay)
- Cassette 4: 0103 (cassette 3 retry sensor PS1 (cassette pedestal) delay)/0204 (cassette 4 retry sensor PS2 (cassette pedestal) delay jam)
To prevent this, a vertical path roller to which paper is hart do adhere was used for the following machines (the color of the roller was changed from black to gray).
- iR2230 120V THF03592 and later/120V TW SHD00033 and later /220V CN SHC01553 and later/230V EUR THG02606 and later /230V THH00339 and later
- iR2270 120V SLH28893 and later/120V TW KJN00097 and later/ 220V CN KJL00763 and later/230V EUR KGL54733 and later/230V KGM03613 and later/230V CA SLF02281 and later
- iR2830 120V THK01045 and later/220V CN SHE01035 and later
- iR2870 120V SLG13303 and later/120V TW KJR00054 and later/220V CN KJP00589 and later/230V EUR KGD13135 and later/230V KGE00333 and late/230V CA SLD00411 and later
- iR3530 120V THL01319 and later/120V TW SHK00085 and later/220V CN SHH00829 and later/230V EUR THM01596 and later/230V THN00209 and later
- iR3570 120V SKV61037 and later/120V TW KJU00760 and later/220V CN KJS00928 and later/230V EUR KFW21901 and later/230V KFX02555 and later/230V CA SKT01761 and later
- iR4570 120V SKU23728 and later/120V TW KJX00122 and later/220V CN KJV00690 and later/230V EUR KFQ15439 and later/230V KFR02186 and later/230V CA SKQ01030 and later Field Remedy
When the symptom occurs with the machine without the foregoing serial numbers, replace the vertical path roller.
Kindly rate me !!!!!!!!thank mate.
Sep 23, 2009 | Canon imageRUNNER 2270 Copier
Delay between the actual TV volume and the sound from the Speaker
The time delay is likely caused by taking the audio signal from the TV rather than the source. I would need to know more about the components in your system and how you have them currently connected to be of further assistance.
Feb 28, 2009 | Sony BRAVIA® DAV-HDX576WF Theater System...
We have a Dishlex Global 500 dishwasher, electronic. How do you get the delay start to function?
You select "delay' and as you keep pressing the delay key the hours of delay will increase by the hour.
May 26, 2008 | Dishwashers
Delay print
I found the answer to this situation: To turn off delay print function, Push the print mode button on the upper right hand control keyboard.
Thanks for the help!
Kathy
Nov 26, 2007 | IBM Wheelwriter 30 Typewriter
Computers & Internet Logo
David Payne
David Payne
