Question about Makita 12V Cordless Impact Driver - 6980FDWDE
I have a makita 6095d makita 12 v drill and when u change the strength with the black round wheel to adjust the tork, it will not change. It needs to adust where there is more toque. Please help me. Thanks T Z Elinor
  • 22 Answers
Set it on the drill setting
Posted on Dec 13, 2008
  • 88a345e9
    88a345e9 Feb 11, 2014
    he still cant ajust the torque with that remedy
Problem taking batteries out of older Makita drill (6095D) to recharge/replace them.
there is a clamp on the bottom that has to be unlatched and the battery should just pull out of the bottom, unless it is stuck by corrosion and then you might have to "TAP" gently to remove. You can download a breakdown of this tool at makitausa.com to see what I am talking about.
Jun 26, 2011 | Makita Drills
Have followed instructions for my makita chuck change removed screw tuned anti clockwise but will still not come off
I have detailed instructions on my tip page that should remedy the problem. Let me know if you still need assistance.
Jun 04, 2011 | Makita 12 Volt Cordless Drill/Driver Kit
Can I buy a new motor for a 12 v Makita cordless? How much?
You need to contact Makita directly. But from experience, it's usually cheaper to purchase new drill than replace parts.
Mar 09, 2011 | Makita 12 Volt Cordless Drill/Driver Kit
Charger for makita 9.6volt 6095d not working
revisar las terminales del cargador que hasen contacto con las del taladro yestas tambien porque puede ser que esten oxidadas y linpiarlas con limpia contactos y con lija n400 o mas fina
Oct 05, 2010 | Makita 12 Volt Cordless Drill/Driver Kit
Charger doesn't charge anymore
If you are comfortable with removing the upper half of the housing, unplug charger and remove the screws, take a look at the circiut board for a "cold" solder joint or broken component, usually the round ceramic looking piece with the copper wire around it. but look at the whole board.
Jun 30, 2010 | Makita 12 Volt Cordless Drill/Driver Kit
How do I change the bit on makita 6095d The drill bit is on right now and I simply want to change it to the phillips screwdriver bit. Thanks
have you opened up the chuck to remove the drill ? If not then you need to by holding the chuck tightly with your hand and then run the drill in reverse. hope this helps you
Oct 05, 2009 | Makita Drills
What is the procedure for removing the chuck from a makita 6095D 9.6v drill?
Most chucks use a tapered shank that allows you to remove it with a good tap on the bottom. Other chucks have slots in the slots in the shaft that allows you to tao it off with a wedge type key. You could always use a dent puller and chusk on the screw.
Good luck, Jack
Aug 21, 2009 | Drills
How to replace forward and reverse switch on a Makita model 6095d cordless drilldriver
If you are mechanically inclined you should have no problems but if not this is involved. First I would recommend going to the Makitatools.com website and on the right side type in your model number and look at a breakdown for this unit. To start with you have to remove the chuck, then the collar with the 2 springs under it and then remove all screws from the housing separating it carefully so none of the parts jump out. The switch is polarity sensitive so make sure of the wiring. If you still want to tackle this let me know and I will go into more detail on this. Good luck
Apr 08, 2009 | Makita Drills
Makita BHP451 Question
Buy a hitachi li-ion 18 volt ds18dl.
All parts are repairable & replacebable should they breakdown. Ie gearbox.
Gearbox parts are not available on makita , only whole gearboix which can be expensive.
Cheers
Laurie
Aug 27, 2008 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Makita 12V Cordless Impact Driver - 6980FDWDE Logo
676 people viewed this question
Top Makita Drills Experts
John Trevino
epangan29
Mike
Are you a Makita Drill Expert? Answer questions, earn points and help others
