Question about Hitachi 43FDX01B TV
Hitachi skips over commercials & flickers
Hitachi 43fds01b has recently started turning off and flickering during commercials.. aspect ratio changes.. Have gone through manual and found a "commercial skip" button, but no way to reset it to zero. all the settings are from 30 to 180 for this feature. Any suggestions?
    Sergeant:
  • 308 Answers
If by saying the "aspect ratio changes" you mean the picture shrinks from top and bottom, I would suspect an intermittent short inside one of your picture tubes. The commercial skip function is not causing a problem here. It is the rapid change from dark to light that I believe is putting an extra strain on a weak or defective picture tube.
Posted on Jan 18, 2007
How do you set cable to 16:9 output?
Different channels are broadcast in different aspect ratios, depending on the network and the show(s) being broadcast. Many older show are still broadcast in the 4:3 ratio to avoid distortion. Currently, there is nothing in the broadcast signal that tells the TV what aspect ratio to use. Therefore, TV remotes have a selection button (mine says "P.SIZE") that allows the user to change the aspect ratio to optimize the viewing experience.
Sep 05, 2014 | Hitachi Televison & Video
When watching sports with the score in the right or left corner it is always cut off
the aspect ratio is wrong. there is a button on the remote that says aspect or size or ratio. keep pushing it till the screen is correct size. also there is the same function on most cable and satillite recievers. most of the time the # button changes the aspect ratio. your problem is one of these.
Aug 19, 2011 | Hitachi Televison & Video
I have a 50" Plasma
Hi, the aspect ratio is set incorrectly for the source material or the screen is simply set to 4:3 aspect (old TV size) manually. There will be a menu function or an aspect button on the remote for doing this. Set it to auto which is usually good enough for most viewing though the ratio may change during adverts and back again for the film on tv watching. This can be annoying so when on tv mode observe the ratio set when the film is on and manually set this ratio, usually 16:9. The display will normally tell you the ratio setting at the point of change so you can do this. I hope this helps.
Steve at Olive Country Computers in Spain
Feb 19, 2011 | LG 50PX5D 50 in. Plasma HDTV
Is there a way to change the aspect ratio without the remote control?
Not to my knowledge. That feature is only accessible for the tv on it's own remote control. Most
cable or satellite remotes only control the aspect ratio for it's own equipment.
I hope this helps,
Skyassoc
Dec 08, 2010 | Hitachi 57G500 57" TV
Aspect ratio problem
enter in the menu and change background to black.
Apr 24, 2010 | Hitachi 53FDX01B 53" Rear Projection...
How can I make the picture size fit the screen? I loose picture around the edges. Seems like it is displaying at a larger size
The issue your having is aspect ratio. Some programs and commercials are broadcasting in a higher resolution so some fill the screen and some have black bars top and bottom. I suggest searching "aspect ratio for video". It would take me all night to type it out. But you need to know how the different resolutions change the size of your image. Also in the TV's menu you should see an aspect ratio option. Try the different settings to see if you can find the best.
Aug 19, 2009 | Zenith A25A23W 25" TV
Aspect Ratio or Input Issue
Not sure but you might be confusing your aspect selection on your DVR with aspect selections on the tv itself. Make sure you use your hitachi remote & check all available aspect ratios. Find one that suits u best
Apr 06, 2009 | Hitachi 51F500 51" Rear Projection...
Aspect Ratio not responding/always in "Full" mode
Normally, when I see this problem in the customer's home, I find the main culprit to be the cable box. The remote for the cable box may have a button on it to change the format or picture size. You may have to go into the menu of the cable box to change the format setting. Hope this helps.
Apr 22, 2007 | Panasonic TH-42PWD8UK 42 in. EDTV-Ready...
Commercial skip/blackouts
Sounds like you're blessed to have a tv like that! Seriously: Some sets have settings that will cut down the sound during a commercial. Haveyou looked at your owner's manual? This tv may have setting to cut out the picture also when commercials come on. From a technical view point generally commercials have stronger signals than regular programming. This may be overloading your set. If this is the case, then you need to have it checked by good technician. A poorly operating power supply (not regulating properly) could possibly cause a problem like this. Also automatic gain control circuits could be not working properly. Stargazer
Jan 19, 2007 | Hitachi 43FDX01B TV
Hitachi 43FDX01B TV Logo
129 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
