Iball speakers making irritating noise
1 yr old iball speakers make a very irritating humming type of noise when i switch on the loudspeaker when the volume is at minimum. then, when i increase the volume say for example when i'm seeing a video/ movie the noise increases and becomes somewhat crackling type. due to which i cannot hear what is being said. thats the best i can explain. i'm not well versed with the technical terms. pls help
I faced the same problem getting the same set of speakers. The solution is simple, go to your speaker settings and mute the "line-in" and the "aux" tab and the humming sound will disappear. If that does not work, then try muting the other tabs one by one. I hope this should solve your problem.
Posted on Jun 05, 2013
  • 43 Answers
Please try better speakers better ohms orhigher wattage. improper speakers not for pc's or laptop will cause the hum..
Posted on Nov 30, 2008
Radio no sound
Is there not a loose loudspeaker wire or disconnect the speakers from the radio and check the speakers with a AA battery if okay when connected it should make a clicking noise if okay if the speakers are high power the click from them will be soft but even portable radio speaker will not get damaged with this test if you are scared of damaging it This is a standard test for checking loudspeakers
Mar 13, 2014 | Ford Car Audio & Video
CHANGE LOUDSPEAKER
go to your retailer and ask for a cell phone headset converter which plugs into yr phone and your home surround system. in the back where you see white and red,jacks. this will allow you to hear songs,poeple. over your, home speaker system.one side should hv yellow,white,red,plugs the other a metal insert which goes into yr headset. bring yr phone to the store.
Apr 06, 2013 | Kyocera Duramax E4255 Sprint black Good...
We have a 3 yr old 2hp waterway pool pump that is making a very loud noise. It is still working but the noise is constant.
I have a 3 year old pool pump, waterway. I can hear the motor humming but the fan wont kick on. I pulled all hosed to make sure they were cleaned out. Any ideas why it would be froze up?
May 08, 2011 | Sport & Outdoor - Others
I have a pair of JM lab Electra 905 speakers, running through a DNM amp and power amps. When powered up, the left speaker makes a very loud humming noise. This has happened recently. I haven't changed...
Hello
Switch on your amp, keep its volue down to extreme low, and listen if there is still hum through the left channel or not. If still there is hum, the left side power amplifier section inside the amp;ifier is faulty. If htere is no hum at this state, hum enters thorugh the audio input terminal, and the input wires must be checked for open sheild connection. OK.
Apr 10, 2011 | Jmlab Electra 905 Speaker
Two speakers hum noise
Very doubtful that hum issue is ground potential difference from multiple power outlets as power cord is not grounding type (it is transformer isolated). I do agree that it is good practice to connect all audio equipment to common power strip though, especially with pro sound. Check the audio cords connecting your speakers to the coumputer sound card: 1) Make sure they are connected to the correct jacks and plugged in all the way, 2) wipe the connectors off with a clean paper towel wetted with a smidge of WD-40, 3) replace cords if all else fails. I have also seen solder joints fail on the power supply capacitors (due to vibration) causing hum -- but leave this repair to an electronics technician due to dangerous voltages.
Sep 25, 2010 | Altec Lansing AVS 500 Computer Speakers
Constant hum from speakers
It sounds like you might have a grounding issue. Try connecting to the wall outlet with a ground prong lifting adapter. Not just the speakers but the source plugged into the speakers also. Good luck.
Oct 09, 2009 | Logitech Z-10 Computer Speakers
Humming noise
If you are using a dimmer switch to operate the fan instead of a fan speed controller, that is the cause of the humming. If you turn down the speed to the lowest setting and the hum gets louder, then your controller needs to be replaced.
Sep 13, 2009 | Hampton Bay 24750 Huntington III Ceiling...
Hum and left channel doesnt work
Are these new speakers? My sub hummed when I had it in plugged in to the wall outlet with a light switch connected. As for the speker not working maybe a wire is loose inside the speaker cabinet. If it was dropped or something.
Sep 25, 2007 | Boka 2000 Computer Speakers
502 people viewed this question
 Grubhead
Grubhead
