Question about Estate TEDX640JQ Electric Dryer
Takes a long time to dry one load
Dryer takes three+ cycles to dry one load. Worst dryer I've ever owned!!! Has done this since day one. We've had it for three+ years now...
  • 2 more comments
  • zombiedon Nov 29, 2008
    Will do, I forgot to that the venting tube had fallen off the dryer. I found lint laying under, behind the dryer! The only problem I could see was the tube had ben dry rotten at the end near the hose clamp. I taped it untill i buy a new one.
    Ok, here is what I found....the exhuast tube that runs throught the foundation is not connected to the vent tube. The air is blowing into the crawl space. Tomorrow I guess I'll have to crawl under there with a new vent tube.
    Even though the the air is venting into the crawlspace, wouldn't this be enough?
    Thanks for the help
    We clean the lint trap ever load and I'll remove the duct fromt the dryer and check the air flow. I can only imagine how long this has been going on. I hope there isn't damage under there. :( really not looking forward to crawling under there, but it's important that it gets done! I understand fully what could happen.
    The only problem is, in order for me to get behind the dryer, I need to pull the washer out. Previous owners had a water heater installed in the laundry room and the space is limited. No time today, but will do tomorrow.
  • zombiedon Nov 30, 2008
    Ok, here is what I found...the plastic duct work looked very old, most likely original with the house(35 yrs). The other end was laying on the ground filled with damp lint. There was no air flow! I have a load of cloths in the wash now and will find out how well the dryer works in an hour or so.
    Thanks for all the help!!! :)
    Problem Solver:
  • 8 Answers
The fact that the dryer takes so long to dry indicates either an air flow problem or a "heating" problem. You don't say weather the units gets hot or not but you do say that it has been giving you this problem for 3 years so I'll assume that it does heat. You should make sure that there is air flowing through the dryer by just going to where the dryer is exhausted to the outside after turning on the unit and see if it is blowing hot air out. If there is good airflow but it is not hot you may have a bad element or thermostate and you should contact a professional to diagnose the exact problem and repair it. If there is not a strong warm airflow from the exhaust then you probably have an airflow restriction of some type. The first thing to check is the lint filter. Every dryer has a lint filter that should be cleaned out after each load. Check you owners manual to find the location of yours and make sure it's clean. If it is plugged, clean it and check the airfow again. If that does't solve the problem, you need to determine if the dryer vent hose is kinked or plugged. The vent hose is usually located at the bottom of the back of the dryer and are usually only attached with a clamp of some type. Just disconnect the dryer vent hose from the back of the dryer, turn the dryer on and check the air flow at the dryer exhaust. The there is little or no air blowing out of the dryer it could be a defective fan. This is a complicated repair and should be done by a professional. If the exhaust coming out of the dryer is strong you know the problem is with the exhaust hose so check for kinks, crushed duct or blockage and repair it then re-connect the exhaust duct to the dryer, turn on the dryer and go back out to the outside exhaust and see if it is now blowing strong. GOOD LUCK. I hope this resolves your problem.
Posted on Nov 29, 2008
  • Michael Leahy Nov 29, 2008
    Hey Zombiedon,
    If the dryer is in fact exhausting into the crawl space, that should be enough exaust to dry the clothes so I would double check that lint trap and also make sure that the exhaust coming directly out of the dryer is strong, warm and moist (if there are clothes in the drum). Also I would repair the fact that the exhaust is going into the crawl space and get that warm moist air outside of the house "cause it could cause you some nasty problems, (ie. rot and or mold) if you let the exaust continue to be dumped into the crawl space.
  • Michael Leahy Nov 30, 2008
    Well Zombiedon,
    Sounds to as though you've solved the problem. Well done.
    Sergeant:
    Champion:
  • 311 Answers
Try running dryer with venting disconnected to eliminate that as the problem. Thanks, please leave feedback or contact me again for more info if you need it.
LG Dryer takes too long to dry clothes
Sure the outside vent is not clogged up? If so it will overheat and turn it self off and do a poor job of drying the clothes.
Also check and make sure that all of the heating elements are working properly.
Jul 09, 2017 | Dryers
Dryer gets low heat takes three cycles to dry a small load, I checked the gas flow and it comes on and burns blue but must not cycle right because the clothes are not drying. I have never repaired a...
If a dryer is heating but takes to long to dry you can bet the dryer has a air flow problem. I would check the dryer vent first for restrictions due to lint build up or kinks. Remove the dryer vent and clean the lint out. Also check the outside flapper on the end of the dryer vent to make sure it's free of lint and able to open all the way.
It also a good idea to take the dryer apart and check around the blower/fan housing for lint build up.
Aug 07, 2011 | Dryers
I have a Kenmore 67834 electric dryer, and it takes three drying cycles to dry a load of clothes, it just not heating.
your vent could poss be clogged up and needs cleaned. that could cause this problem 9 times out of 10.
Jan 27, 2011 | Kenmore 67841 Electric Dryer
The dryer does not heat most of the time, and it takes forever to dry one load,i.e., all day. Occasionly it heats...Most of the time, not.
You either have a clogged vent hose or a bad cycling thermostat. I would check the hose. If it's clean, change the cycling thermostat. It's located inside the dryer attached to the vent housing close to the element.
Nov 17, 2009 | Whirlpool LER5636P Electric Dryer
My Dryer not that old, takes all day to dry a small load.
Check the following areas thoroughly to address this issue.
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
Aug 31, 2009 | Whirlpool LER5636P Electric Dryer
Laundry not getting dry
It normally takes about 45 minutes for a dryer to dry a full load. If your dryer is taking more than an hour, check these.
Vent
Heating element
Internal ductwork
Cycling thermostat
Vent Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance.
Heating element Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it.
Internal ductwork Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum, contact a qualified appliance repair technician.
Jul 18, 2009 | Dryers
THE DRYER TAKES TWO TO THREE HOURS TO DRY ONE LOAD
Vent
Heating element
Internal ductwork
Cycling thermostat
Cycling thermostat Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork with two screws.
May 20, 2009 | Dryers
Dryer takes 3 times to dry
My tumbler won't turn on my front load Kenmore dryer
Mar 07, 2009 | GE Dryers
Maytag LDE412 Dryer
the vent that takes the air from the dryer out of the house is clogged. not the part right behind the dryer but from where it goes into the wall to where it leaves the house needs to be cleaned. when the air cant leave the dryer at normal speed it takes for ever to dry a load of clothes
Nov 26, 2007 | Maytag MDG7600AW Gas Dryer
Estate TEDX640JQ Electric Dryer Logo
171 people viewed this question
Top Estate Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Terry Schneider
Are you an Estate Dryer Expert? Answer questions, earn points and help others
