Question about Frigidaire Affinity ATF7000E Front Load Washer
Washer My washer is making a buzzing sound the whole time it is running.
  • onthethejob1
    onthethejob1 May 11, 2010
    i need you to press on the door at door swich push in does it stop...pull door handle out do it get louder..keep me posted..onthejob
  • 640 Answers
Check your door switch
Posted on Feb 01, 2009
My portable top load kenmore washer model 110.42722200 won't spin. It drains water and all the light functions work, but it only makes a humming sound like it is stuck when it gets to a spin cycle and does...
I just repaired this exact model this weekend. If the machine will drain but doesn't agitate or spin (you have to put a screwdriver in the lid switch to see), it's usually a loose belt. This time I replaced the belt, but it still would not agitate or spin, and the motor was not turning, just a "buzz, buzz, buzz" when the washer attempted to supply power to the motor. The start capacitor for the motor was bad. Part number 3429938 which runs about $60. Not hard to access once you tip the washer over slightly, just DISCHARGE THE OLD CAPACITOR so you don't get a nasty shock.
Aug 05, 2010 | Washing Machines
Loud buzzing noise
Mine is loud also when playing games. When playing DVD's it is not. I think it is a factory defect on some of the systems. I would not attempt to pull apart the DVD drive and try and fix it. It is working and on an XBOX 360 you should feel lucky that it is.
Aug 18, 2009 | Microsoft Xbox 360 Console
I have a affinity Frigidaire dryer and it won't run on, it makes
A buzzing when you start the dryer sounds like a motor is faulty or something is stopping the blower wheel from turning.
Feb 19, 2009 | Frigidaire Affinity ATF7000E Front Load...
Whirlpool gas dryer makes buzzing sound when started, stops mid-c
Maybe something fell down into the filter housing. Get the back off and inspect it with the power disconnected.
Feb 17, 2009 | Kenmore 62602 Electric Dryer
Washer will not start and is making a buzzing sound.
did the belt fall off in the back of the washer. Mine was overlaoded and the belt came off somehow- it went back on fine.
Apr 17, 2008 | GE WSXH208A Front Load Washer
Washing machine
if you take the clip down to your local hard ware shop they will find you a pair of pliers that will help you put it back on
Dec 16, 2007 | Frigidaire GLTF2940ES Front Load Washer
Can't wash -
the motor is buzzing i presume did you take the cabinet off?? Check the motor connector look at the red wire make sure it isnt burned.
Sep 28, 2007 | Kenmore 3.2 cu. ft. Top Load Washer
Does not drain & makes a loud buzzing sound(KENMORE 44042)
this sounds like something has gone into the pump, coins or whatever, the objects need to be removed, also check the hoses, remove the plug to work on any appliance the buzzing is the pump trying to work but unable to go round, start there and see how you go if i have helped rate me please
Sep 12, 2007 | Kenmore 44042 Front Load Washer
Frigidaire Affinity ATF7000E Front Load Washer Logo
89 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
