Question about Estate TAWS800JQ Top Load Washer
My washer spins but doesnt spin very well,because when washer finishes clothes are still wet. help me
  • 641 Answers
Check that drain line and filter are not blocked. Good luck !
Posted on Jul 26, 2007
SOURCE:
The heat is there but it doesnt dry the clothes
You have one of 2 problems. Your clothes are getting put into the machine too wet because the washer isn't spinning them out all the way. Or you have a clogged vent causing the unit to take too long to dry properly because it can't remove the moisture properly. Check your vent outside to see how hard the dryer is blowing the air.
Nov 27, 2013 | Zanussi TC7114W Electric Dryer
Washer sometimes doesnt finish I go to put clothes in dryer and they are still dripping wet but washer is off
Do you get a error code on the machine? There can be many problems that cause the machine not to go into spin mode. Need more info
Dec 05, 2011 | LG WM-2277HW Front Load Washer
Clothes are too wet when finished washing. water drips from clothes.The spin cycle seems to be spinning as the clothes are against the outside wall of the tub. we have the extra spin cycle used aslo and it...
Transmission is bad. Buy new washer. Best brands are (Kenmore, Whirlpool, Maytag).
Thanks and Please Rate me! Tips provided by www.HoustonRefrigeratorRepair.com Brian Gillespie (GOFAR Services, LLC)
Aug 26, 2011 | GE WPRE6150HWT
Clothes are to wet after spin cycle
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these: Motor coupler Spin cycle Siphoning Water-inlet valve Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning: If it's spinning when you lift the lid, the coupler is fine. If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely. Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component. Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician. Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess. Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Jan 24, 2010 | Kenmore Washing Machines
My zanussi washing machine fj1033 finishes normal wash progam but doesnt go into hihg spin therefore clothes are wet rather than damp.if i turn dial to spin cycle only it works that way.please advise.
If you have not already done so, then check and clean the pump filter, this is usually located at the bottom right front of washer, behind a drop down cover or flap.
Unscrew anti-clockwise to remove and clean.
Jan 08, 2010 | Washing Machines
Wet clothes
the reason the clothes are wet is the washer is not shifting to high spin,does the washer have a speed switch(normal wash spin,high wash spin)if its not the speed switch than the clutch is bad,how old is the washer?mike
Apr 19, 2009 | Kenmore 24032\24036 Top Load Washer
Clothes wet at program finish
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
  • If it's spinning when you lift the lid, the coupler is fine.
  • If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Apr 01, 2009 | Bosch Washing Machines
Model 110 washer will not go into a final high speed spin.
hi, i would suggest the timer/programmer is faultyas it is ok on the other cycles, the noises you have described may have caused some damage,
Feb 10, 2009 | Washing Machines
Estate TAWS800JQ Top Load Washer Logo
Top Estate Washing Machines Experts
Marvin
Marvin
Bobby G
Bobby G
Steve Allison
Steve Allison
Are you an Estate Washing Machine Expert? Answer questions, earn points and help others
