Question about Acer Aspire 3680 Laptop
My Back and Forward sign!!
My backwards sign,my forward sign, my refresh sign and my stop sign are not able to be clicked on. How can I fix this?
  • 93 Answers
Check any virus or HDD too full or memory not enough...
Posted on Dec 01, 2008
Can not back up or even push it backwards in neutral running or not.
The right rear brake on my Granddaughters car was so worn that the pad jammed when turning backwards stopping any backwards motion. When going forward it did not jam and could be pushed or driven forward. Tell everyone that if you hear scraping noises when applying brakes to get them checked right away.
Dec 28, 2015 | 2005 Chevrolet Chevrolet TrailBlazer EXT...
My caterpillar D7F was shifting forward and backward one day we came to start the machine it wouldn't engage in reverse after sometime it stop engage forward. what could possibly be the problem?
This could be a very simple fix to an oh my god. First check your fluid levels. My initial thought is how it slowly started to stop shifting is that you need to fill your transmission fluid. If that is the case after it is full then you will be able to shift fine. Second part of your problem then is finding out where it is leaking and get that fixed. If it is just a leak count your blessings, fix it before using it again and always check your fluid levels often.
Nov 12, 2012 | Mitsubishi WD-62528 62" LCD HDTV
I deleted my forward and backward bar by accident and now i cant find it
You must have deleted the internet explorer forward and backward bar,You have not mentioned the operating system and type of internet explorer you are using.
Try this step
click on start> go to accessories>click on system tools> click on system restore> choose a date when internet explorer had forward and back ward button.
Sep 26, 2010 | Computers & Internet
No forward, only backward
Hi. If the light flashes 7 times, it has a speed controll fault. It might be the throttle lever ( wig wag ), or it might be the speed pot that controls your top speed.
Try moving the throttle lever ends up and down while you are driving the machine. Doing this wont fix it, but it will highlight the problem, if the throttle lever is faulty. Also try moving the speed pot back and forward a few times.
Good luck. Neil.
Jul 17, 2010 | Pride Mobility Products Hurricane PMV...
1996 Mercedes SL Power seat problem
hi,seat motor are in maximum length,try to seat,then apply force backward also the switch in backward mode.
Feb 16, 2009 | 1999 Mercedes-Benz E-Class
Ilo will not go forward it will only scroll music backwards.
This player (it's not the only one) is "sticky" - it is slow to move forward and back - best bet is to stop song play completely, and THEN move forward and back
Mar 30, 2008 | iLO (2 GB) MP3 Player
Agitator stops when sweeper is pulled backward
If you have made no changes to the vacuum's setup and are using it on same carpet you have previously used it on with no problem, then the most likely cause is the agitator/beater bar's drive belt is worn or on some models may have a tension adjustment which is set too loosely. This can also be caused by having the vacuums height adjustment set to low for the carpet or flooring you are using it on, causing to much drag when the vacuum is pulled backwards for the agitator to overcome.
The vast majority of agitators turn in a forward direction, as if it would pull the vacuum forward, when you pull the vacuum backwards the drag is increased.
So...First check height adjustment (a no cost fix), then check out the tension adjustment (if present on you model, some engage when top of vacuum is tilted back after stepping on the release pedal) Lastly, consider changing belt especially if you have had the vacuum awhile or if it gets a fair amount of use or it you seem to need to use it on a low height setting all the time to vacuum up debris.
Hope this helps!
Dec 19, 2007 | Kenmore 34923 / 34925 Progressive Bagged...
Acer Aspire 3680 Laptop Logo
60 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
