Question about Dryers
Hoover nextra hnc 160 condenser dryer filter light on ,blows cold
Hi,my hoover nextra condenser tumble dryer is blowing cold air only ,and the filter care light is always on.there are many posts online with the same problem but no definate finger on the problem .heeeelllllppppp
  • joshua_bethe Dec 20, 2008
    Hello we have same problem any ideas what to do....
  • Anonymous Mar 26, 2009
    as above
5 Suggested Answers
yalmer
  • 552 Answers
SOURCE: hoover nextra tumble dryer
Please first check if both fuses or the circuit breaker has not tripped.
If you are getting only 120v on one leg of the 140v power, you may get lights and no heat, otherwise please give the make and model.
Posted on Feb 27, 2008
hards327
  • 30 Answers
SOURCE: How do i replace belt on condenser tumble dryer
you need to remove the whole front of the machine by removing the : top by the 3 screws at the back,then unscrew the screws across the front of the top of the bezel then remove,then open the door,remove the circle of screws then put the machine on its back,remove the screws at the bottom front of the machine,then lift the front bottom of the machine and slide it upwards then you should be able replace the belt then refit in reverse order good luck.
Posted on Mar 17, 2008
SOURCE: Hoover nextra mega load 7.5kg
On the rear there is a Heating element hidden under the silver cover, on the top of this unit, there is 2 thermostat's, one is a auto-reset set (On the left) around the 100'c mark and one is a single use thermal trip set at 130'c (on the right, also denoted by a blue spot), the idea is when the heater reaches 100'c is powers off until the air temp drops, once it drops the auto-reset kicks in and forses the heater to power back up, however, in the intrests of safety, if the auto reset fails to power down then the 130'c thermostat will permenently remove power from the heater and will illuminate the filter care light, the only way to restore the power to the heater is to either have an engineer replace the whole heater as Hoover/candy do not sell on the thermal cut out to anyone.
you can usually find the heater unit for £30-40, an engineer may charge upto £140 for the same part and fitting.
Posted on Jan 05, 2009
  • 17 Answers
SOURCE: hoover tumble dryer filter light staying on and
if you have cleaned your filter at the door and checked the outlet is not blocked either then it will most likely be the heater element on the back of the machine, it has three parts to it, 1 thermal switch,2 is some sort of magnetic type switch and 3rd is the element its self,
problem is its only sold as one unit, but very easy to replace.
Posted on Mar 03, 2010
I have a hoover nextra dryer hnc 170. The drum will not turn, and both the lights for filter care are on. I assume the reason it is not turning is because of the filter care light. Is there anythin i...
the filter care light comes on when the machine is over heating so the "brain" thinks the lint trap is full , clean the entire venting system, including the outside vent cover and remove any debris , then unplug the machine for a few minutes and see if it resets
Jul 04, 2011 | Dryers
Hoover Nextra 6 1400 6+4kg - the tumble dryer
under top cover there are 2 thermal cut outs to reset.situated centre front
Sep 12, 2009 | Hoover Nextra HNWL 3136 Front Load Washer...
Hoover tumble dryer filter light staying on and blowing cold air
Jun 05, 2009 | Zanussi TC7102W Electric Dryer
Noisy when running need to check belt and bearings
i need the serial # to assist you better
thank you
May 14, 2009 | Dryers
Hi the my filter light keeps flashing and iv got no heat!
My guess is that the heater element has gone out. There could also be a lint clog in the exhaust vent...it takes air out through the filter...across the heater element....and back through the tumbler to heat the clothes. This is usually what causes heat elements to go out is the excess lint that gets on them and causes them to overheat and burn out!
Dec 14, 2008 | Whirlpool LEQ8000JQ Electric Dryer
Mar 14, 2008 | Dryers
Leaking condenser tumble dryer
i have the same problem i need help sick of putting towels down infront of it
Dec 28, 2007 | Washing Machines
Hoover Nextra HNWF 3137
this is a condenser washer dryer so water should evaporate to condenser then empty!
Oct 31, 2007 | Hoover Nextra 160 HNWF 3137 Front Load...
Dryers Logo
622 people viewed this question
Top Dryers Experts
Marvin
Marvin
