I have a 425 gas tankless water heater. In 3 years in the winter (and sometimes warmer weather) I have never gotten a hot shower. The water starts out warm, and in the middle of the shower changes to freezing cold. It is much worse in the winter, almost unbearable. Help, before I rip it off the wall and go back to a tank.
  • 8 more comments
  • duckyb1 Nov 30, 2008
    It is a Bosch #425, and I believe the shower restricter has been removed. My son has another manufacturer, and loves his too. I heard it is the "venting", then I heard that this was a "bad model, loaded with problems", then someone said "it works on pressure and not flow". Apparently flow works better. Someone said "turn the faucet water on first in the sink, and then turn the shower on before turning off the faucet at the sink". I'm tired trying. Not sure what model you have that works for you.
    I b elieve the letters might beGWH 425 HN. Not sure about the alltitude. I am in Pa. right outside of Philly. The other thing they said it might be is the "single" faucet control in the shower. I was told a double faucet (1 hot, 1 cold) works better then the "single" knob. But the walls are closed up now, and the tile is installed (very expensive tile) so it would mean major repair if we were to change handles now. My son thinks it is in the diverter at the single shower. It doesn't always do it at the other faucets in the house. But who needs that shock when the temperature is well below freezing. :You don't even get a warning....................
    Well your good....................The water was very hot. It stayed hot for a long period of time, even when I made an adjustment, to a temperature that you would be able to stand under if I wanted to. It did not go ice cold. I felt I kept it on for a good deal of time. I have 2 1/2 baths, the kitchen too so it is 6 hot faucets in all. They all stayed hot, and then I turned them all off, but the main shower. I thought it stayed hot pretty long, even after the adjustment I made. Its not freezing in Philly today, but it is probably around 40 degrees outside now. Hopefully I did this right. Does that give you a clue as to the problem????????????????
    Yes the shower in the main bathroom did remain hot for what seemed like a longer time then it has before (once the problem starts happening in the cool weather) After running it for a while I shut it off, but up to that point it remained hot. This time it did not go cold. That being said "what do I have to do when I turn the shower on to get that result without turning on all the hot water faucets in the house, and why do you think it happens to begin with. any solutions that would work??????????????????
    by the way I do have just 1 knob.
  • duckyb1 Dec 01, 2008
    thank you. I hope I get a good result tomorrow morning.
    Hi, just wanted to let you know. The shower worked this morning. YA, AND HALLLELUYAH............................I turned on the hot water in the sink, brushed my teeth, and at the same time turned on the water (all the way to its hottest point) in the shower. Then turned off the sink water, adjusted the temperature in the shower, stepped in and prayed. The water never went "cold". I was even able to adjust it to warmer without the hot water cutting out. If this works everyday I can't thank you enough. Also my son since I rent this gorgeous home from him, and he was ready to throw in the towel after many tries. Again thank you, and you have a wonderful holiday.
    THANK YOU, THANK YOU, THANK YOU. THE SHOWER WORKED THIS MORNING. I CAN'T THANK YOU ENOUGH. IT ISN'T SUPER COLD HERE THIS MORNING, BUT HOPEFULLY THINGS WILL STAY THE SAME. AGAIN THANK YOU, AND YOU HAVE A WONDERFUL HOLIDAY. GENEVIEVE
    Can't thank you enough..........................It worked......................This morning I was able to get a shower without the water turning cold. This is what I did. I turned on the hot water fully at the faucet in the sink, and brushed my teeth, not to waste water, at the same time I turned the shower on full force "all hot", then turned the sink off when i was done, left the shower on, and adjusted it to a warm temperature. Stepped in, held my breath, prayed a prayer, and guess what. NO COLD WATER CHANGE. I can't thank 'you enough. My son also thanks you since I rent this gorgeous home from him, and he was ready to throw in the towel after many tries. The next one would have been costly. As I said "he has a tankless and it works perfect". Not the same model or manufacturer. He owns his own construction company, and had many trades at his disposal to give him advice, but everyone kept saying. "those systems stink", "you can only use them in warm climates", "its the venting", "its the single control". He got it all, even getting in touch with Bosch. They were no help at all. Sorry for the long winded comment, but I am so happy. Thank you again, and you have a wonderful holiday. Fix, Ya, is great. I will put this website among my Favorites. By the way I am a widow, and live in Springfield, Pa. I am 73, and my name is Genevieve. The nicknam
  • 65 Answers
Is it a bosch.What is the exact model number.I have one and i love it once you get it set.It seems that there are two flame levels low water flow and high water flow.If your shower has a water saving restricter in it it may not flow enough to let the flame get too high.So i would remove it.If there is a knob on the front turn it all the way clockwise and try it.There is also a screw on the inside that you can adjust the low water flow flame , it the brass one with a locking screw on it.Your manual should show it.If you need to adjust it turn on your shower and go check the flame and use that screw to increase the flame.Hope this helps and let me know how that works
Posted on Nov 30, 2008
  • 3 more comments
  • good wrench Nov 30, 2008
    I have an aq 125 frow the orange home supply store.Do you have a better model # any letters.Not sure on what you have but it should have a sensor that monitors the venting and if it is insufficient it will shut it down.Hot water tanks usually have a 3"vent and the tankless requires a larger one for the larger btu output.Try leaving the hot water on in the sink and the shower and see what kind of temp you get.If it gets hot then shuts down it is a vent problem backing up.I also had to get a better gas meter as the one i had could not flow enough gas for the furnace and the water heater at the same time and when the heat kicked on the water temp would drop from the restricted gas flow.Is there a dial on the unit beside the flame adjust.I had to turn my dial down if i didnt i had warm water not hot it seemed the water was flowing to fast through the unit to get hot and the flame wouldn;t come on unless i had two faucets on.If you turn on your hot water and adjust that knob back and forth(assuming you have one) you will see the water flow rate change.Turn it to slow the flow all the way and try that.Hope you get it working as there is nothing like a long hot shower or fresh hot water to cook in,not some water that has been sitting in the tank.Also what alltitude are you at.and is it nat gas or propane.
    Do you have one or two nobs on the unit.If it has two turn the one on the right all the way clockwise.If it is one turn it all the way clockwise.then turn on as many hot water outlets you have,kitchen bath shower and tell me if the water gets hot.It should get very hot.If it gets hot then turn off everything except the shower and let it run and see if it stays hot.Let me know
    Did the shower stay hot?The knob on the right or the single knob decreases the flow through the unit and lowers the flame on per water flow.If the shower stays hot you can tweak it up if it is too hot or you need more flow for two showers.But if it went cold then there is some kind of restricter in the water supply that doesn't allow enough flow for a higher flame.Let me know if you need some more help
    You should be set.When you turn on the shower you slowed the flow by turning thet knob and that lets the water get hotter and also lets the flame come on with less flow.
Bosch gwh 425 hn
Fix problem immediately same day, yourself, for $385, by replacing whole thing:
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Bosch posts some service manuals: or contact Bosch. Lack of error code indicates failed PC board? or bad single-handle faucet cartridge?
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
Check for crossover where bad faucet cartridge allows cold water to enter hot pipe, so hot water is not drawn through tankless and burner does not activate... but this might not be problem since you hear the tankless clicking
http://waterheatertimer.org/Crossover.html
Call local service technician to catch up on required yearly maintenance.
Jun 09, 2013 | Water Heaters
Tankless water heater doesn't produce hot water in the winter when tempetures are below 32 degrees. I tried a water saver shower head and this worked for a little while. Anything else I can do ?
1) Tempering tank might help:
http://waterheatertimer.org/Tempering-tank.html
2) Reduce temperature setting on tankless unit so there is less differential between incoming cold water and thermostat set point.
3) Absolutely any tankless problem can be solved same day by installing tank-type gas water heater:
4) Add comment and say what you do to solve problem.
Jan 31, 2013 | Bosch AquaStar 2400ES-NG
I have a Bosch GWH 425 HNO propane Tankless Water Heater which began intermittently exploding when demand for hot water occurs.
Call a qualified service tech immediately.
Gas explosion indicates dirty combustion parts, and gas is not fully igniting when tankless turns on the gas. So gas builds up and then explodes causing serious damage to tankless, and serious risk to homeowner.
Aug 14, 2012 | Bosch & Tankless LP Hot Water Heater
It turns on ,starts to get warm.Then turns off
Sounds like you have a problem with water flow. Since your ground water is warmer in the summer, you mix less hot and more cold in order to get the same warm temperature. If your hot water flow gets low enough, your tankless will start to "short cycle" in order to prevent scalding. Use one of these three methods to increase your water flow at the shower:
1) Clean your shower head and descale
2) Widen the hole in the showerhead's flow restrictor
3) Remove your flow restrictor entirely
Aug 02, 2010 | Noritz 6.3 Gallon Residential Tankless...
Water turns cold very quickly
I had the EXACT same problem (installed my tankless last winter and worked fine, now this summer it fluctuates, have to turn the shower completely off and then on again to get any hot water and then it only lasts for a couple of minutes!) Argh - it is frustrating!
Here's what I found: the demand for hot water is lower during the summer (hot) months because the "cold" water coming in is already quite warm. You don't need as much hot water to make the shower temp comfortable. SO, my tankless was shutting off due to low flow demand. I've removed the flow restrictor from my shower head and it helped alot but didn't completely solve the prob. Next step is what has been recommended to me by several people but is much more expensive - change the pressure valve on your shower to a temperature valve. Or just wait til winter and it should work ok again :)
Jul 06, 2010 | Bosch & Tankless LP Hot Water Heater
Water becomes ice cold in the middle of a shower
Jan 24, 2010 | Noritz NORTIZ Outdoor Propane Tankless...
I had our 1600ng Bosch water heater installed a month ago during warmer weather. It is not providing very hot showers. I use all hot no cold. how can io get more heat
on the front of the water heater down at the bottom there is a thermostat (usualy a blue knob) turning it clockwise will increase the tempature of your water
(good Luck)
Oct 12, 2009 | Bosch 1600H-NG Natural Gas AquaStar...
Rinnai tankless water heater
where the pipes are laid out it may run along an outer wall and the cold weather is cooling the water before it gets to the shower try to track the pipe from your water heater to your shower and insulate it where it is coldest
Dec 11, 2008 | Water Heaters
Rinnai Tankless Water Heater
Question, is there any other equipment that uses propane? You indicate that the problem started after a delivery of propane after running out. If so, I suspect a blockage in either the gas train or the rinnai itself. If tou have the temperature control that regulates the water temperature, you can recall error codes to pinpoint the issue. They are optional equipment so if you can wire one in or ask your propane gas supplier if their service department has one, it will aide in the diagnosis.
Nov 22, 2007 | Heating & Cooling
Heating & Cooling Logo
127 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
