Question about Linksys WVC54G Network Camera
In trying to setup a wvc54gca for the first time, i get a "fail to activate wireless connection" error
  • Anonymous Jan 04, 2009
    the problem appears when I disconect the cable beetwen the camera and the router
    Problem Solver:
  • 10 Answers
Well I have (4) of these cams but solved this problem after Cam #1. Linksys' instruction manual really stinks and fails to mention a few important things. The initial configuration requires you to temporarily make a wired connection to your wireless router. Run the installation CD. The camera will need to setup an IP and "shake hands" with your network. Use the default, 192.168.1.115, as your camera IP address.
Disconnect the camera from the router. Go to your router admin panel at 192.168.1.1. You need to enable port forwarding. Set for TCP and UDP. I believe Linkys recommends port 1024. Should work.
Based on your description....sounds like an initial configuration problem and/or your port forwarding isn't enabled.
Good Luck
Posted on Feb 21, 2009
    President:
  • 8,637 Answers
Normal 0 Try disconnecting the Camera from the USB port and reinstall the CD or Downloaded software program. When the program asks you to connect the camera to the USB port, do so and it should work.
Then to use it on the Web do this.
Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/ ) set it up as follows:
  1. Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
  2. Then click on the Video Settings.
  3. The camera if Installed Properly will come up and show a video picture.
  4. Then, on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now be able to see and her to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger (http://www.soft32.com/download_30.html ) set it up as follows:
  1. Go to Messenger at the top left and click on it.
  2. Next go down to Preferences and click on it.
  3. Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
  4. Next go to the Test Audio section and (in blue writing) click on “Open the call setup assistant” and follow the instructions on the left window.
C. Windows Live Messenger:
  1. After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X.
  2. Then on the Windows Live messenger window on the right side, click on “ “Show Menus.” And then click on “Show the Menu Bar”.
  3. Next go to the Menu Bar on right side, click on “ “Action.”
  4. Go to “TOOLS” and click “Audio and Video Setting” and follow the instructions.
NOTE: Your audio and video should work. Enjoy.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
Hope this helps. Bud
Posted on Feb 01, 2009
Unable to browse to cisco access point
'192.168.0.116' is the wrong range for the router. The Cisco manager allocates the ranges the router will use.
See this page on the setup.
Getting Started Guide Cisco 3700 Series Access Points
May 28, 2014 | Cisco Computers & Internet
Error 8001000A IN MY PS3
hi,
you don't need to connect the router to ps3 configure it one one pc/laptop then activate the wireless on the router,then setup the wireless connection on ps3.
Apr 07, 2014 | Zyxel Computers & Internet
I cannot get the TV to connect to the internet any more. One day it was working and the next it was not. I have rebooted the entire system to factory settings, taken out the power cord, rebooted the...
Error 1106 is an indication that the Domain Name System (DNS) was unable to resolve. Follow the steps to check the Internet connection: 1. Check the Network Connection. 1. Using the supplied remote, press the Home or Menu button. 2. Select Network Setup . 3. Select View Network Status . 4. Select Check Connection . If any of the connection settings fail, verify that the TV is properly connected to an active Internet connection. Follow these steps, if the error continues to appear: 2. Unplug the TV and wait 60 seconds. 3. Power on and off all of the networking equipment, including the modem and router. 4. Allow the Networking equipment to reset after powering them of and on. Test that the connection is active by using a computer. 5. If the issue continues, wait and try viewing the content later.
Sep 18, 2011 | Televison & Video
How i can to setup WVC54GCA without CD
Ok First... Go on Google (Type Exemple) Download Linksys WVC54GCA drivers for XP then follow the instruction..
Oct 06, 2010 | Linksys WVC54GCA Network Camera
Linksys WRT160 router doesn't work
Wi-Fi Protected Setup Button
If you have client devices, such as wireless adapters, that
support Wi-Fi Protected Setup, then you can
use Wi-Fi Protected Setup to automatically
configure wireless security for your wireless
network(s).
To use Wi-Fi Protected Setup, run the Setup
Wizard, or refer to the “Wireless > Basic Wireless
Settings” section of “Chapter 3: Advanced
Configuration".
Wi-Fi Protected Setup LED (Blue/Amber) It
lights up blue when wireless security is
enabled. The LED flashes blue for two
minutes during Wi-Fi Protected Setup.
The LED lights up amber if there is an error
during the Wi‑Fi Protected Setup process. Make
sure the client device supports Wi‑Fi Protected
Setup. Wait until the LED is off, and then try again.
The LED flashes amber when a Wi‑Fi Protected
Setup session is active, and a second session
begins. The Router supports one session at a
time. Wait until the LED is off before starting the
next Wi-Fi Protected Setup session.
Jan 01, 2010 | Linksys WRT160N Wireless Router
Software will not verify wireless connection for Linksys WVC54GCA
1st You download Webcam Driver.
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Sep 27, 2009 | Linksys WVC54GCA Network Camera
WVC54GCA camera - setup is ok with cable install but once going to wireless, no go using Belkin N1 router
May 16, 2009 | Linksys WVC54GCA Network Camera
MTU fail
ok well I found a fix but it may not be simple. anyway, i got my xbox360 to work off of my girlfriends laptop by feeding internet to the laptop from the cable modem via usb and then from the laptop to the xbox360 via ethernet. just right click usb connection in network connections and click sharing tab, then activate sharing and tell it to share connection with lan connection... you can also share through wireless if your xbox is wireless. I tried running all this through a dsl wireless router and a basic hub and both of them gave ip address and mtu errors... good luck
Nov 10, 2008 | Microsoft Xbox 360 Console
Linksys WVC54G Network Camera Logo
204 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
