That means that something is wrong with the hardware or the CMOS battery is dead. Look at the date and time, if it is wrong then you need to replace the battery. If the date and time and are ok, then start checking the bios to see if it lists the hard drives and the RAM. If it does not list them or lists them incorrectly, change them.
If you fixed the Date and Time in the BIOS and when you boot up the laptop next time the Date and Time is wrong, then most like the BIOS battery is flat and needs replacing. After the BIOS battery has been replaced go to the Bios and set the Date and Time.
When you boot up and the Date & Time is wrong then you correct the
Date & Time, then when you shut down and boot up again the Date and
Time has changed. This is an indication that the BIOS battery is flat
and you need to replace the BIOS battery. Install a new BIOS battery, go
into the BIOS setting and set the Date & Time etc. and the new
battery will keep your settings stored in the BIOS.
If this error message comes up when you boot up the computer, it means the BIOS requires configuration, usually the Time and Date is wrong. If this occurs every time you boot up your computer and have changed the Date and Time then this could be caused by a flat BIOS battery. If so, replace the BIOS battery and then configure the Date and Time and you won't get this error again.
