Question about Pioneer SD-P50A5-K 50" Rear Projection Television
Convergence problem? Our 50" rear projection Pioneer TV will be ok when first turned on but soon after the three color ghosting will start, soon after you will hear a POP noise and turns off. You can't re-start it for a while then same sequence. I talked to someone and they said it was the convergence board and would cost $450.00 + taxes. Any thoughts?
  • mario goyette Jan 18, 2007
    Thanks for your input. Since I am a bit of a layman with respect to TV's how do I identify the convergence board?
    Sergeant:
  • 308 Answers
If it's OK when first turned on, I would suspect either bad solder connections on the convergence or power supply board, or capicators on either board heating up and breaking down. Pioneer parts are expensive, so I would look for a shop that can do component level repair. You may save about $100 or so.
Posted on Jan 18, 2007
SOURCE:
Colors on tv are seperating. looks like double images.
Hi, Try the auto convergence or auto focus to eliminate the problem, if this does not work, you may have to get the TV repaired, the common problem are the power amplifiers that correct the color convergence, that is why you get color shades or ghosts in the images.
Nov 29, 2010 | Hitachi 50UX57B 50" Rear Projection...
The tv image is showing in three colors....Almost ghost like but in three colors. I checked my connections and tried my blue ray player and the image is still messed up....I did press the magic focus...
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
You can get a repair kit with parts and instructions from www.TvRepairKits.com
Sep 23, 2010 | Hitachi 53FDX20B 53" Rear Projection...
Sony KP-51WS520 51" Rear Projection Colors have been over saturated for awhile...selecting vivid seemed to help. But now I am getting a ghosting effect on most words, always to the right.If I go to...
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 09, 2010 | Sony KP-51WS520 51" Rear Projection...
Tv turns on but the screen is black. Before it went black we were haveing bands of color on the top and bottom and everthing was kind of like in three D they were all three colors and like 3 of them there.
Ur tv have convergence problems,now the 2 STK convergence ICS are completely dead,U lucky u tell it was 3D screen,before it go completely dead,went black screen.Or ur problems it will very hard to diagnose.U now how to do soldering?Must replaced 2 STK convergence ICS,some or all it resistors.Tries Websites Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for parts and labors.
Apr 03, 2010 | Pioneer SD-P50A5-K 50" Rear Projection...
Ghosting and bad color, sound is fine.
*Screen Looks 3-D
*Colors wont align
Problem #2
Feb 15, 2010 | Sony KP-57WS510 57" Rear Projection HDTV
Ghosting
*Screen Looks 3-D
*Colors wont align
Problem #2
Oct 06, 2009 | Mitsubishi VS-45605 50" Rear Projection...
Red and blue ghosting,
*Screen Looks 3-D
*Colors wont align
Problem #2
Jul 12, 2009 | LG RU-52SZ51D 52" Rear Projection...
I have a samsung rear projection tv and has ghosting on picture? what could be wrong and is it easy to repair?
*Screen Looks 3-D
*Colors wont align
Problem #2
Jun 17, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Color ghosting or shadows
*Screen Looks 3-D
*Colors wont align
Problem #2
Jan 19, 2009 | Pioneer SD-532HD5 53" Rear Projection...
PLEASE HELP (Three Ghost Images)
You will need to have or change the convergence correction driver IC's. There are two of them in this TV set. Not a fix for a novice I'm afraid. If you have no solid state repair experience, play it safe and call out a pro to assist you in this repair.
Jul 12, 2007 | Pioneer PRO-510HD 53" Rear Projection...
Pioneer SD-P50A5-K 50" Rear Projection Television Logo
71 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
