Question about Sony DAV-C900 System
Does not recognize/play DVD - shows "NO DISK"
It will still play CD but when I try a DVD (that has worked before) it will make sounds like it is starting to read but then you can hear head seeking and then it reports "NO DISK" on the display and the TV will show "Insert Disk".
If a CD is in one of the other slots, it will start playing the CD instead of the DVD that was inserted.
  • raustinort Dec 02, 2008
    I fear trying this because I do not possess the knowledge/tools to accomplish.  I don't know if you missed the point that the unit still plays CDs as it always has.  It is the DVDs that are not recognized.
If you are good at repairs.dismantle the Disk drive unit carefully from the main carriage and if the Optical lens reading unit has got a drive P C B ,then desolder the PCB so that you have only the CD mechanism on your table,with a Digital Multimeter check the Ohmic values of both the Spindle motor and Sled motor. the resistance should read between 4.5 ohms and 8ohms any value beyond this means that the drive signal voltage is not enough to move /rotate the disc and optical-pickup in syncronisation.you can get the drive-motors replaced,or replace the CDM assly available off the shelf.
this should solve the problem.hundreds SONY DVD players are running with this remedy.
Posted on Dec 02, 2008
Asus dvd external player ... how do you play it by a note or tablet ??????? I keep tryn but it dosent work?...
windows 10?
post the model number of this player.
is the player connected to its power pack, plugged in?
try all USB ports? or is it using eSATA port, no port type stated.
USB, when plugged in does windows (is it windows) go BINGBONG
sound, telling you USB is not dead?
does it show up in device manager
does it show up in Disk manager?
last would be "This PC" local explorer working and see a disk there.
play what.
CD-DCA
Home burned, MP3 music on CD or DVD?
store bought DVD ,say starwars DVD real not a RIP.
always test with real CD/dVD first, not burned copies .
then last we check that DVD-R worrs or CD-r burned disks play.
what player are you using,? I use VLC , only.
Jun 03, 2018 | ASUS Computers & Internet
My cd drive does not recognise cds
Okay. First of all is it a cd drive in your computer as opposed to a DVD drive? If you put a dvd into a cd drive it cannot recognize the dvd. A dvd drive can recognize a cd, but a cd drive cannot recognise a dvd.
Does your computer actually recognize the drive as being present?
If the drive isn't recognized by the computer try:
power off the laptop
Physically remove the cd or dvd drive
power -up the laptop without the cd/dvd drive
power off the latop and refit the dvd/cd drive
power it up again and see if the drive is
recognized
If the drive IS recognized by the laptop but won't play any disk it's probably the drive itself at fault. You can try gently cleaning the inside of the drive - the optic that reads the disk. However, the usual cause is failure of that optic which read the disk information. It cannot be repaired.
The alternative to fitting a new drive is to buy a portable dvd drive. They connect via a usb cable. Have a look on Ebay
Dec 21, 2014 | Computers & Internet
Dvd drive not reading what it copied
is it playing on the pc. if so then you need to update your software. or make sure you finalise the disk
Mar 31, 2010 | Sony DW-U18A DVD±RW Burner
My TSST corp TS-H653R CD/DVD does not recognize that a
HP uses a method to determine if an optical drive has failed. Basically in a nutshell, if the drive will not read a disc, or if it will not write to one, then the drive is defective.
When the diag tool asked you to insert a "data disk" it's not asking for any particular disk, just one with data on it so that it can test itself.
if it does not recognize the disk in the machine, then try another disk. if the issues persist, the drive is definately failed.
hope this helps!
Aug 31, 2009 | HP Pavilion Elite e9180t PC - 3.00 GHz;...
Toshiba sd-r2002 - won't recognize blank CD when trying to write files to a CD
right click on the drive.... go to properties... under tab recording, remove tick "enable CD recording on this drive" and press apply... after that tick "enable CD recording on this drive" and press OK.
It should work.
Jun 01, 2009 | Toshiba SD R2002 CD-RW/DVD-ROM Burner
DELL laptop does not read blank DVDs
the combo drive you listed above is a cd-rw/ DVD-ROM....meaning that it will play and burn cd, cd-r, and cd-rw disks. the dvd rom will only be able to play dvd-rom and dvd-r disks providing they are in the proper format. check that the disk in question is not a dvd-rw or (+2) disk. the drive will not recognize that a disk is in the drive if the disk isnt compatable. try a dvd movie, if that works then a dvd-r, if that works then try a dvd-rw +1. if the last option doesnt work then you will have to stick with the dvd-rom and dvd-r, or purchase a dvd-rw drive to install.
GOOD LUCK AND DONT FORGET TO RATE MY POST!! :D
Mar 18, 2009 | Sony CRX835E CD-RW/DVD-ROM (Combo) Burner
Gateway 7322GZ's TSST corpCDW/DVD TS-L462A won't recognize disks
It looks like its your CD Rom itself.....have you tried cleaning the head with a head cleaning disc .....if this doesn't help replace the Rom
Nov 10, 2008 | Computers & Internet
DVD-RW not recognising blank disk
Did you try a DVD firmware update? Some dvds need new firmware to reconize some DVDs
May 30, 2008 | Computers & Internet
Will not read disk recorded on Samsung DVD digital Camcorder
The disk needs finalizing.
However this then will make the disk unusable for anything else
Switch to CR R or DVD R as appropriate
Dec 18, 2007 | Plextor PX-740A (00765075107763) DVD RW...
Won't recognize a blank dvd in drive
Clean the drive with a cd/dvd cleaner. Sounds like the read optics are a little drity.
Nov 07, 2007 | LG GSA-2166D DVD RW Dual Layer Burner
Open Questions:
Sony DAV-C900 Home Theater System: problems with speakers and dvd picture quality Hello all, I hope someone can help me here... The speakers have been going off and on intermittently for a while now. I have cleaned the connections, but it does no good. Sony has these stupid color coded connectors and I do not know how to go about upgrading the wires. If that is even the problem. I have switched the wires around, and when I switch one that works to a non-working connector it will not work. When I put a non-working speaker wire into one of the working connectors, it will work--it almost seems to me that it is either a problem internally, or with that specific connector that sticks out of the rear of the unit. After fooling around with them for a while, I can usually get it to work, but then it will go out for no apparent reason. Another problem has to do with the picture. It has developed these squiggly lines while watching dvd's. Sometimes they go away after a while, but it is certainly annoying. I have attempted to clean the laser with one of those dvd cleaning disc's and even replaced the s-video cable, but neither has resolved this problem. It used to have an excellent picture, even though I wasn't using component cables. Due to my TV set-up, I need to use the S-video hook-up, but like I said it has always worked well until recently... We really do not watch that many movies, so I wouldn't think the laser is going bad--hell, the kids have many more hours on their xbox than this unit has...If I had the money, I would just go out buy a new system--not an HTIB this time, but this year has not been too lucrative, so I am stuck with this for the time. Any help will be greatly appreciated. Thanks Dana
Feb 22, 2007 | Sony DAV-C900 System
Sony DAV-C900 System Logo
248 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
