Question about ASUS Eee 4G Notebook
All i see is a black desktop.
Hi i am running the Linux OS and was updating software and i got an error, which i couldn't say what it was because i have never used linux b4. I rebooted and now it seems to work but i no longer see the desktop, i see the mouse arrow and the bottom bar. It sems to work i just lost the desktop, HELP!
  • Brian Perry
    Brian Perry May 11, 2010
    What linux are you using?
  • JDTec
    JDTec May 11, 2010
    Ctrl h
    or
    Drop to a terminal (Alt+F2, gnome-terminal) and run
    /etc/rc.d/dbus
    or
    $nautilus -q
    or
    sudo killall nautilus
5 Suggested Answers
SOURCE: CANT USE THE BUILT IN WEBCAM
i have the same problem!!
Posted on Sep 17, 2008
davemitch
  • 16 Answers
SOURCE: the os is to frustrating linux is not for me ..xp is what I want .need to get linux out then install xp.
The particular model of Asus is apparently pre-loaded with Xandros Linux operating system.
It appears that you are not familiar with Linux and hence the apprehension and feeling that a shift to XP would be easier.
Why not give Linux a try ? There are a good many websites out there which go through the basics of using a Linux PC. Try them out, by spending some time in learning - you will get far more satisfaction and become more productive in using your laptop.
Some websites which might be of assistance to you are listed below:-
http://www.xandros.com/
http://forum.eeeuser.com/
Posted on May 19, 2009
  • 256 Answers
SOURCE: eeepc has no icons, just blue screen, can't access anything! Linux
When I was using Linux, there were 4 screens. On the bottom an icon showed which screen I was on. If you have that Icon, click the main screen (upper left) and you should be OK. Let me know if this works.
Posted on May 25, 2009
  • 12 Answers
SOURCE: asus EEE PC 900A Linux- boot problem after downloading updates
Consider downloading a specific release of Ubuntu; eeebuntu. Download the ISO and then conenct an external DVD device to it, during the BIOS screen, choose the ESC button and boot from the external device.
This Ubuntu-specific group offers three kinds of ISO's (simple, super basic, and a loaded release), all of which allow all parts to work out of the box:
http://www.eeebuntu.org/
If this does not work, check the informal eeepc forums
Posted on Jul 01, 2009
ohms
  • 1879 Answers
SOURCE: Updating Linux Skype on EEEPC
get the latest from skype's website
Posted on Sep 07, 2009
How can I fix the problem of not being able to use Synaptic Package Manager or Update Manager in Linux Mint 1i KDE?
Did you run sudo dpkg --configure -a in terminal? Can you reinstall the update manager? Sounds like everything needs to be removed and reinstalled from terminal, and maybe a sudo apt-get autoremove followed by an update? It seems like the only reason synaptic and software manager wouldn't work is you've over tinkered with your os, and maybe accidentally removed something you needed for those things to run. I'm new to Linux myself, so beyond that idk. If all else fails, backup and do a fresh install to get your system back to it's original state.
Sep 17, 2014 | Computers & Internet
Tip
Linux System not Booting: A Troubleshooting Session
<span>In a recent days in our lab I've got a with Linux file system. <span> </span>Our lab used Redhat Linux 5.3 Enterprise version. Redhat Linux is an Unix based Operating System and It based on Ext3 file system</span><br /> <span></span> <br /> <span><span>Problem of Linux:<span> The systen cannot access internet. It shows the license expiry error notification. Some</span></span><span>time it doesn't detect the hard drive. Some time the pc can detect hard drive but the Linux started with some errors of file system. Finally the file system of the OS getting crashed and can't boot. At GRUB loading stage it become restarted.</span></span><br /> <span><span></span></span> <br /> <span><span><span>Solution or Troubleshooting: </span><span>If I replace the hard drive cable It detect well and start OS also. Then the pc can detect hard drive but the Linux started with some errors of file system. Then I discovered that there is a problem with OS.<span> </span>Though formatting can solve the problem but that needs a backup of important data. This is time consuming and risky. So I thought to repair the file system</span>.</span></span><br /> <span><span><span></span></span></span> <br /> <span><span><span>At first I'm trying to login in single user mode and repair the file system. I have tried to login by pressing "s" beside kernel at startup in single user mode. But the system doesn't boot. Then I'm trying to repair the OS by RedHat Linux CD. I <span> </span>Insert the CD and select rescue mode by pressing "F5" key. Then I got the single user mode. After that I check all file system sequentially. </span></span></span><span><span><span>/etc /passwd, /etc/shadow, /etc/securetty, /etc/pam.d/login. Those file was wrong. I updated those file by correcting. Then I update the auth config file. After that I boot the system again. But now also it don't get start. Then I rescue the grub by grub-rescue and also update the kernel. After the total process I'm tried again to login from single user mode in root and It get logged. After that I reboot the system and tried to login. Finally it logged in successfully and run properly.<img src="alokerdas.jpg" /></span></span></span>
on Jan 15, 2011 | Computers & Internet
How to turn the Radio Frequency Kill Switch off when running Linux
Hi Antti,
From one LINUX OS user to another, welcome.
Have you checked that the software you are using is that for the card, if it isn't, that will be the culprit.
If it is the correct software, then it may be and obsolete version, anyway, with LINUX OS, you do not need the software, LINUX will automagically detect your card and install the apropriate drivers for it to work. I have never had to manually install software for anything to access the internet, that's because LINUX OS is designed to do that awfull task for you, all you need to do is plug & play, LINUX by design, is a fully fledged Plug & Play OS.
If for some reason it isn't able to run your card, this is basically due to it being so out of date, that it is no longer supported, even by INTEL.
I don't know which flavour of LINUX you're running, but I've been running 5 on my day to day machine, and not a single problem have I encounted since 1997, when I started using LINUX.
So, throw away your software driver discs when using LINUX, the're not required at all.
I hope that has resolved your query and keep on using the worlds best OS.... LINUX4EVER!!!
Cheers,
Peter
Feb 25, 2013 | Fujitsu Siemens Amilo L1310G Laptop...
Hi there, i have linux mint on my computer, and i have recently bought the samsung wave and i need to get a software update, When i download the kies software its an exe. file and as that only works with...
Go to the samsung support page and click software and click the download then when it asks to save or run hit run then leave it do do the rest when it has loaded don't plug ya phone in you need to update it top left
http://www.fixya.com/support/t6124648-samsung_wave_not_getting_conneccted_kies
Sep 13, 2010 | Samsung Wave S8500 Smartphone
I can not update it. it is complaining about my personal firewall!!! tx in adv
you need to disable your personal firewall, or add a exception to it so you can gain updates. If you have linux desktop on it it would bipass that and give you updates. no one targets linux, os it is for free and, it comes built in with better firewall, it is harder to crack linux because everyone targets windows os
Dec 25, 2009 | Trend Micro Internet Security Pro 2009 for...
Ubuntu wont boot after mobo replacement
You have to repair the installion, When you change the mobo you need to reinstall or repair the os, even with windows, well of course with windows because windows sucks, Try updating from the shell sudo apt-get install update
Nov 16, 2009 | Gateway GT5453E Refurbished AMD Desktop...
I m not able to update my packages can any one help me out E: system-tools-backends: subprocess post-installation script returned error exit status 1
You may be able to get a more useful error message by updating your pacakges from the command line with:
sudo apt-get update
and seeing what errors you get.
Mar 26, 2009 | ValuSoft Ubuntu Linux for PC, Mac, Linux
My pc
Usually when it gets caught in a restart loop it means the Operating System is corrupt. Sometimes an .ini file is missing or corrupt, sometimes a hardware/software update causes a stop error. If the data on the hard drive is not critical use the e-machines recovery dvd and reload the OS. If you need all data on the hard drive I would suggest downloading a "Live CD" like the Linux distribution of "Puppy"
this will load an os into ram and you can then "mount' the hard drive and back up all data on the hard drive to cd/dvd.
Dec 05, 2008 | E-Machines eMachines Desktop PC
ASUS Eee 4G Notebook Logo
Top ASUS Computers & Internet Experts
Brian Sullivan
Brian Sullivan
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
