Question about Philips 46PP9302 46" Rear Projection Television
Phillips 46" projectio TV. No picture, no sound
My phillips model # 46PP930217F does not show picture, nor sound after my 2 year old turned it on/off once too many times. In the months prior to this, I was having difficulty to turn it off, as the screen would remain lit (very dim, barely noticeable) and the power light would also stay on, but very dim. I used to press the off button again in order to get the TV to turn off, at times had to press the powr button a couple times before the set would turn off. One day it would not turn on anymore. When the power button is pressed, the light comes on and a click sound comes from the back of the TV, but that's it, nothing else happens. Any help would be appreciated.
Fred
SOURCE: Adjusting colors on a magnavox 46" projection TV
Replace the CRT fluid. It grows algea in the blue and green only. 9.99 from MCM electronics.
Posted on Nov 16, 2007
  • 4 Answers
SOURCE: NO POWER, PICTURE, OR SOUND, power button flashes green 2-3 times
had same problem. update tv software with a usb drive. do not take the tv apart. its easy download to computer unzip to usb drive and put drive in right side of tvs usb slot with power off, then turn power on, you should get an update screen.
did not work for me the first time i had to format usb drive to fat (not fat32) and then unziped to the drive took 10 minutes to update. I have tv 60PP9200D/37
Posted on Apr 28, 2008
SOURCE: Phillips 60pp935217
I have the same problem. During an AT&T U-verse install, the tech was unable to get the HD picture to work, but was able to get sound. The tech suggested that there was a problem with the tv.
Posted on Jan 30, 2009
  • 1121 Answers
SOURCE: When I turn it on the screen stays blank and there
this a defective power supply, normaly the HV circuit is burned, needs to be repaired. send to repair shop
Posted on Jan 29, 2010
  • 8457 Answers
SOURCE: i need help my phillips
The tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B are mis alignments,have colors shadows pictures or 3D picture look alike?The tv convergence board is dead,the tv convergence board,must be requiring to replaced 2 STK convergence ICS and some or all of it resistors too.U have all the tools and can do ICS soldering and electronic componnents soldering.Tries websites like Tvrepairworld.com,Tvreparkits.com to buy a Convergence kit to do the repair ur self.Or the shop,will cost u like $300-350 for parts and labors.
Posted on Dec 15, 2010
Phillips 409fl7505d/f7
I once had a problem with a Phillips tv.It was less than one year old and one day ,all of a suddenm a black screen came up.I elarned it was called the "black screen of death" and that other people had gone through the same thing.Someone online had actually written to Phillips and they had gotten a new TV form them,so I tried the same thing and amazingly,Phillips gave us a new TV and came and took the old one.The enw worked fine. So you may have a lemon on your hands.Unfortunately, I do not have the letter I sent to them but the replacement they sent me was part of their "Rapid Replacement" program.This wa sin 2008 so I'm not sure if they still ahve it but it may be worth a try.
Apr 09, 2013 | Philips 40PFL3705D 40 in LCD TV
Sceen is on, sound is on,but imegen is not, this is a phillips 47' lcd tv can someone help me is like 4 years old
That could be a Tcon or a main board issue. Can you post a picture of the screen? also will need the model number. Please respond to this same post for further assistance.
Jan 01, 2013 | Televison & Video
I bought a phillips 32 flat screen 5month ago,and it has gone wrong,it works for 20 mins then the picture goes off the sound stays on
Tv is less than a year old call Phillips for warrenty repair.This tv have a 1 or 2 long boards,call the LCD inverter boards,it have problems,about to died.These 1 or 2 long LCD inverter boards are to help the LCD screen to have a backlight to produced a picture.That why u have dead pictures,but still have sound.Tries websites like Shopjimmy.com,Ebay.com to buy those 1 or 2 long LCD inverter boards for the replacement.
Sep 20, 2010 | Philips Televison & Video
Slow to turn on Phillips flat screen tube big screen
That is a common issue with the last generation of the phillips big screens, the best answer for this is one that i got at a meeting with phillips service several years ago. On philips the tv will not show a picture till the tubes are balanced out, simular to sony, but in a phillips if the white balance is not correct the picture and sound will be muted till all three tubes have warmed up enough to produce a good white balance. As the set ages the tubes become weaker and this procesess takes longer.
May 07, 2010 | Philips 43PP9202 43" Rear Projection...
Phillips hdtv model 30pw9110d/37 won't turn on
Common short the cover cap over the video & sound boards short out if you remove it the cap only (shield metal) it usually will fix this
Apr 28, 2009 | Mitsubishi WT-46805 46" Rear Projection...
Phillips TV Sometimes Come's On No problem and Then Not sometimes with Green blinking light
I HAVE LOST THE TOP PORTION OF MY SCREEN, APPROX 2 1/2". IS THERE AN EASY WAY OF REPAIRING?
Oct 13, 2008 | Philips 32PT6441/37 32" TV
Phillips 60pp935217
I have a phillips HDTV monitor model 60pp935217, i don't get an hd picture but i do have sound. Please help.
Apr 08, 2008 | Philips 60PP9352 60" Rear Projection...
TV turns itself off after a few seconds, no picture at all
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Mar 28, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Picture color - it is a blue and green picture- no other color- looks artificial
update your tv with a usb drive. worked on my phillips 60PP9200D/37. get update at phillips web site. solves many problems
Jan 18, 2008 | Philips 60PP9200D Television
No picture shows
HI THERE, I HAVE A PHILLIPS 42 INCH PLASMA SCREEN TV ITS ABOUT 2 YEARS OLD THE SOUND IS PERFECT BUT THE PICTURE IS DEAD MODEL NO IS 42PF55200/10 I HAVE HAD IT GIVEN TO ME TO SEE IF I CAN REPAIR IT BUT AT THE MOMENT NO SUCH LUCK THANKS JOHN
Dec 30, 2007 | Pioneer PRO-1009W 57" Rear Projection...
Philips 46PP9302 46" Rear Projection Television Logo
43 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
