Question about GE 24 in. Profile PDW7800 Built-in Dishwasher
Hard specs of food on dishes, they come out dirtier
Tried cleaning the inside and problem still
  • nbanksb2q Dec 02, 2008
    The solution was good, what I did was changed the setting from Normal Wash to Anti Bacteri setting which I assume is a higher temperature.
  • 311 Answers
Make sure you are starting d/w with hot water by running faucet. If you are, then it may be time for a new d/w. Thanks, please leave feedback or contact me again for more info if you need it.
Posted on Nov 29, 2008
Dishes are always dirty, maybe even dirtier after running dishwasher. has hot water, lower arm moves.
Check the outlet holes on both spray arms for clogs. If necessary, remove the spray arms, clean out the holes and empty out any debris inside the spray arms. Verify that the upper arm is turning also.
If the machine does not drain completely at the end of the cycle, the pump drain outlet is partially blocked and you are retaining dirty water for the next load.
You may have a chemistry problem - inferior soap, empty rinse agent dispenser, or extremely hard water.
Improper arrangement of the dishes can prevent some from being washed. Make sure no dish blocks the spray to another.
Jul 23, 2011 | Dishwashers
Why is my dish washer leaving food on my dishes that i loaded rinsed off?some dishes come out dirtier than i put them in there.
It is almost always because you have blocked the hole where the sprayer goes up through the middle of the dishwasher. If it cannot pop up the dishes will not only not clean, but the food will just deposit onto the dishes especially the upper rack.
Sep 30, 2010 | GE Crock Pots & Slow Cookers
Brand new bosch dishwater does not get dishes clean - food residu
Try the cascade new soap they have been changing the ingredents due to state requirments for the water treatment. also make sure spray arms and jet are free from food particles,also clean soap dispencer,If you want run CLR through dish washer no dishes to clean machine.Thanks
Jul 26, 2010 | Bosch 24 in. SHU5305UC Built-in Dishwasher
We recently bought a LG 7920ST stainless steel dishwasher. It doesn't properly was the dishes. Leaves food stuck on and doesn't clean the top rack at all. In fact, the glasses are dirtier afterward then...
we had the same problem with a new dishwasher. The repair man told us that the liquid soap would froth too much and not fully rinse out of the system. So the food particles stayed in the trap and wouldn't rinse away. Also the drain hose needs to be looped up to the top of the dishwasher or ran directly down to drain so the wash water doesn't just drain back into the dishwasher. Also check you top rack water jets to see if there are food particles which move into the holes and block the water flow on that level. Hope this helps :-)
Jun 13, 2010 | Dishwashers
My dishes come out dirtier looking after washing in the machine.
check the water temperature is reach the desired setting,clean the rinse arm and check the rinse soaf if working at end of wash cycle.
Jun 05, 2010 | Whirlpool 24 in. GU3200XTP Built-in...
Dirty dishes coming out of dishwasher dirty
check your drain line it should go up from bottom of d/w and then go down to drain that is so water from sink wont back up into d/w
Oct 27, 2009 | Dishwashers
Dishes not clean
So I have a quite simple fix here for you and you will be happy that it won't cost you anymore money. On my profile I have a tip that includes this. What you will want to do is throw about a cup of white vinegar in the cavity and put it on a heavy wash. What the vinegar is going to do is clean out all the hard water deposits and anything else that may be stuck in there. You dishes will start coming out cleaner again. You can do this every few months or so and it will prevent this from happening. When I worked for Sears as a repair man I would always tell my customers this whether I was there to fix the dishwasher or not as it saved me a service call later. You can also do it in your washing machine.
Another thing you need to make sure you are doing is pre-heating your water before running the dishwasher. Just turn on your tap water and let it run till it is steaming then start the dishwasher. This could be contributing to the dirty dishes too. If you don't preheat the water first it takes the dishwashers heating element a long time to heat that water up. The result is washing your dishes with cold water for the first half of the wash. Let me know if you have any other questions and if this was helpful. This should work just fine for you, good luck and take care.
Jan 26, 2009 | Maytag Dishwashers
Maytag Jetclean problem
Hi!!! 10 years is alot for a dishwasher..You could have a plugged drain pump.Check your drain pump.All make sure that the water inside your dish water is hot inside it should read over 100 plus..Good luck..
Jan 03, 2009 | Maytag MDB9600A Jetclean II Built-in...
Not cleaning the dishes
You need to check your water temp after it enters the diswasher, it should be at least 120 deg when it get in the dishwasher. If it not then the detergent, food, and greese can't break down.
Jun 20, 2008 | GE 24 in. Profile PDW9880JSS Built-in...
Dishes dirtier after washing
start machine, do you hear water running in?? place 4 cups upright on all four corners of top rack, let it run for a few minutes ,open door are the cusp full?? or atleast filling???. if not you have a water issue
Feb 20, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
GE 24 in. Profile PDW7800 Built-in Dishwasher Logo
Top GE Dishwashers Experts
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
