Sony Grand WEGA KDF-55WF655 36" Rear Projection HDTV Logo
Jim Mattos Posted on Jan 18, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My sony tv will not stay on
Hello, my 2 year old Sony kdf-55wf655 rear projection 55? TV. will come on (pitcher and sound) 4 about a minute then shuts down, after about 10sec the then red power light(not the lamp light witch has not come on as of yet) turns green and flashes about 30 times\sec and the TV. Comes back on, then it starts cycling on of over and over. If it is the lamp time telling me to replace lamp then how do you reset the timer? Jim Mattos DAVIS CAL [email protected]
  • 2 more comments
  • Jim Mattos Jan 18, 2007
    Thanks henlopen i will try it....jim
    Hello, thanks, but about the powering down and up any thoughts on that?
  • Anonymous Apr 29, 2008
    my sony 55 inch will not stay on -- it goes on and off repeatedly
  • Anonymous Mar 13, 2014
    tyla1000 lamp brand new tv came on and before i could reset lamp timer it shut down wont come back on
Bill Heronemus
Level 2:
Sergeant:
  • Expert 308 Answers
  • Posted on Jan 18, 2007
Bill Heronemus
Expert
Level 2:
Sergeant:
Answers
308
Questions
7
Helped
129317
Points
612
If you replace the lamp and need to reset the Lamp Timer Reset procedure is: With The Set In Standby Press Display, 5, Vol Up, Power on the remote control Press Jump 3. Or, To Display The Lamp Time Press 2 Nine Times. To Reset Press 3, Mute, Enter. One of these should work on your model. Make sure you replace the bulb first. There is a possibility that the ballast could be damaged by a defective bulb as well.
5helpful
After turning on my sony kdf-55wf655 tv for 3-4 minutes it automatically fades out to a blk screen (also no sound) and the green power light starts to blink. the tv stays in this status for appox 2-3...
The projection lamp,the sign of it life is over.The projection lamp been in the tv about 1 1/2 or 2 years,used the tv on and watches at least 4 or 5 hours a day?It time,to replace it,with a new projection lamp.
When my sony grand waga 55 inch shuts off on its own what shoild i look at first
If this tv about is 1 1 1/2 years and used about 4 or 5 a day and the projection bulb had not been change,than the projection bulb life is over.First is to change the bulb.
1helpful
Picture will come on and then go off after a couple minutes
This usually means the Lamp is failing. Replacing the Lamp usually fixes it. I would only use a Sony Replacement.
You can order one from Sony at 1800-222-SONY or you may be able to pick one up from a local Sony Retailer.
Skyassoc
5helpful
3answers
Problem for Sony Grand WEGA KDF-55WF655. Hello,
5 times Red LED blinks means Lamp Driver Error. (KDF-55WF655)
2 possible reasons, either Lamp is gone or Ballast Supply got bad.
Replace lamp first, in most cases it solved the problem.
How old is this TV and did you replaced lamp recently?
Thanks.
Sony rear proj; kdf 55
If there is no picture but sound is audible then replacing the projection lamp will do otherwise, the TV requires to be diagnosed for any other hardware damages.
Sony KDF 55WF655 rear Project tv Power/standby light flashing
This would be an error code indicating a problem.  You didn't mention if anything else was going on with the TV as in no picture, or no sound.  If the TV is operating just fine, there could be a bug in the software causing this.  If there is a problem, the best thing would be to contact Sony and relay that error message and go from there.
KDF-55XS955
first reset direct tv box unplug for 5 minutes then plug back in because it could be direct tv
if this does not work replace the lamp anyways see the link below for part and how to do it
Sony Grand Wega Fixed Part 2 11 18 10 Amazon com Compatible Sony Replacement TV Lamp for KDF 55WF655 KDF...
1helpful
6answers
Sony 55" rear projection tv
TIGHTEN THE BULB --AFTER YOY CLEAN THE DUST OFF THE BULB VENTS ON THE BULB ITSELF. PROBLEM SOLVED. EASY--CHEAP. Hey it worked for me. My picture was turning off blinking 29 times for picture 37 times for audio. This was the first issue with my KDF-55WF655 since I unwrapped it almost 5 years ago......... ITS STILL ON!!! I hope this helps someone.
Sony TV Screen
Is you model listed below?
Sony wega blue dot or star pattern on screen
http://esupport.sony.com/perl/news-item.pl?news_id=206&mdl=KDF42WE655
Models: KDF-42WE655, KDF-50WE655, KDF-55WF655, KDF-60WF655, KDF-55XS955, KDF-60XS955, KF-42WE620, and KF-50WE620
3answers
Sony tv KDF55WF655
same problem... tv turns on and off repeadly while the green light flashes. seems as if the tv keeps restarting. please help.
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
