Question about Whirlpool ED5FHEXMQ Side by Side Refrigerator
The water and ice both have a strong metal/mineral taste to them
Was bought still with a warranty, but someone else had returned to store because a problem. Not told what problem was. Discounted price. When delivered and 2 weeks later hooked up in new home, taste of water and ice metal/mineral taste is so stong, unable to drink or use ice.
Hope that can get some help with this.
    Sergeant:
    Champion:
  • 311 Answers
Remove filter and use dispenser a lot. Chlorine in water may help clean out system that filter is now removing. Not much else you can do other than replace all the water lines and tank. Thanks, please leave feedback or contact me again for more info if you need it.
Posted on Nov 29, 2008
GE fridge 1999 model. water started tasting funny. found black stuff in a peice of ice. Water in rest of house seems fine.
Hello there,
When your water starts tasting funny and you can see some kind of particles in the ice, then it means the water filter is dirty and needs to be changed. Try to get the water filter replaced and the funny taste will stop.
If you are having some kind of lime taste or mud taste, or lime deposits or mineral deposit, is simply means you will have to replace the water line and reservior.
Hope this helped. All the best Elect_Comp
Sep 23, 2011 | Refrigerators
I have an Amana refrigerator, model #ABB1922FEB2. The ice that is made by the automatic ice maker has a foul odor and taste. The water that comes out of our faucet tastes fine, and it's the same water...
Off-taste, odor or gray color in the ice New plumbing connections? New plumbing connections
can cause discolored or off-flavored ice.
Ice stored too long? Discard ice. Wash ice bin. Allow
24hours for ice maker to make new ice.
Odor transfer from food? Use airtight, moisture proof
packaging to store food.
Are there minerals (such as sulfur) in the water? A water
filter may need to be installed to remove the minerals.
Water filter installed on the refrigerator? Gray or dark
discoloration in ice indicates that the water filtration system
needs additional flushing. Flush the water system before
using a new water filter. Replace water filter when indicated.
See "Water Filtration System
To purchase a replacement water filter, model UFK8001AXX-750,
contact your dealer or call 1-877-232-6771 U.S.A. or
1-800-807-6777 Canada
Good luck Please rate FIXYA Thanks
Mar 28, 2011 | Refrigerators
Nasty tasting ice cubes
Change the supply line to the plastic tube line or copper. Do not use a braided plastic or metal braided line these will make the water taste bad. Changed mine to the plastic line and cured mine, no filters needed.
Jul 13, 2010 | Whirlpool 24.8 Cu. Ft. Side-by-Side...
My ice taste like metal and the filter does not need changing
I have a whirlpool refriderator that only makes ice. There is no filter in the fridge itself. The water line in the basement is copper, then it has a valve off of the main line. I originally had installed a stainless steel line running to the refriderator. The order of the ice can be described as a metal tasting taste. I purged the line prior to connecting it. I then replaced it with a pvc line, purging it all so. The taste of metal isn't there but it still has a small taste to it. Prior to having a ice maker, we made ice in ice trays with the sink water and had no issues. Can someone shed some light on this issue please.
Nov 09, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Ice smells/tastes like chemicals
discard ice keep making it till it goes away(dont eat ice) if doesnt go away-further investigate!!! :)
Jul 06, 2009 | Hotpoint HSS25GFP Side by Side...
Strange taste in ice cubes
Did you use new water lines? If you did then clear the icecubes from the tray and use an appliance store cleaning solution to wash it out with. their solution is designed for fridge use and wont leave an after taste......Rinse well...... Also for awsome Ice......Install a large in-line water filter.... Makes mine taste like frozen mountain spring water with no nasty taste or smell. Hope it works for ya!
Jan 04, 2009 | Jenn-Air JCB2388G Side by Side...
ICE CUBE MAKER SMELLY ICE CUBES
Hello margrek
Welcome,
YOU SAID, YOU HAVE KENMORE ELITE BOTTOM FREEZER WITH ICE MAKER THE ICE CUBES SMELL HORRIBLE ALWAYS, I EVEN TOSS THEM OUT EVERY FEW DAYS, STILL SAME PROBLEM
Ice has bad odor and taste.
1• Ice has picked up odor or
flavor from strong food stored
in refrigerator or freezer.
2• Water running to ice maker
has poor taste or odor.
3• Ice not used frequently enough.
4• Cover foods tightly. Discard stale ice. Ice maker will
produce fresh supply.
5• Add filter to water supply line. Consult a water purifying
company.
7• Discard stale ice.
Huuum
Please remember to leave a rating!
Oct 11, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Bad water & ice cube taste
Hello redwood City
Welcome
You said,
Your Kitchenaid Superba KSRG25FKBL15 has bad tasting water and ice cubes. You replaced the copper tubing which delivers the water to the fridge and that didn't help. You replaced the copper tubing again with plastic tubing...no better. Any suggestions? Your tap water doesn't taste this bad.You bought a Kenmore french door fridge with water dispenser in the door in July 2008. The fridge has a filter. A few weeks after the fridge came the water and ice started tasting really bad, unlike any bad water taste I have ever tasted. And your tap water is fine. The bad taste appears to be random. Sometimes you get a cup full of nasty water and sometimes it tastes fine.
First you must know you have a 1 year warranty and can have them come out to fix anything, no charge.If it persists. You will have to get tough and you , MUST INSIST THEY REPLACE YOUR FRIDGE
When installing the water line these were a part of the directions!
Did you do this before connecting the water line to your fridge?
"Place the free end of the tubing in a container or sink, and
turn ON the main water supply. Flush the tubing until water is
clear. Turn OFF the shutoff valve on the water pipe. Coil the
copper tubing."
Whirlpool remedy
1.Are the plumbing connections new, causing discolored or
off-flavored ice? Discard the first few batches of ice.
2.Have the ice cubes been stored too long? Throw old ice
away and make a new supply.
3.Does the freezer and ice storage bin need to be cleaned?
See “Cleaning” or “Ice Maker and Storage Bin.”
4.Has food in the freezer or refrigerator been wrapped
properly? Use airtight, moisture-proof packaging to help
prevent odor transfer to stored food.
5.Does the water contain minerals (such as sulfur)? A filter
6. Is there a water filter installed on the refrigerator? Gray or
dark discoloration in ice indicates that the water filtration
system needs additional flushing. Run additional water
through the water dispenser to flush the water filtration
system more thoroughly (at least 2 to 3 gal. [8 to 12 L] or 6 to
7 minutes initially). Discard discolored ice.
Let me know what works,
Thank You ,
HUUUM!!
Please remember to leave a rating.
Sep 25, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Our refridgerator has terrible tasting ice and water and we have tried everything to fix it. Is there a sure fire way to fix the problem. I would love to use the ice maker and water.
miracow
Mar 02, 2008 | KitchenAid Superba Architect KSCS25INSS...
Whirlpool ED5FHEXMQ Side by Side Refrigerator Logo
103 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
