Question about Toshiba CX35F70 35" TV
Toshiba cx35f70 35"
T.v is about ten yr. old the problem i am having is that set go's fromcolor to green then swithes back from time to time but does not stay in color like it should. please tell me it's not major is it somthing i can fix?
    Sergeant:
  • 308 Answers
It could be a bad solder connection on either the crt drive board that attaches to the neck of the picture tube, the video processing circuits on the main printed circuit board or the picture tube itself. If you can lightly bang the sides or top of the set to get the symptom to come/go, then it is most likely a bad connectiion. If, when the screen goes green, you see fine white lines diagnonally across the screen about a half inch apart, then it is likely the picture tube.
Posted on Jan 18, 2007
DLP 65 in. wont turn on. Lights flash . Red light first followed by 9 green lights flashing-then shuts off.Repeats this pattern.My lamp is foggy but not blown. Is it the lamp? Lamp is 1 yr old.
While i don't recall that particular pro lemme alot of Toshiba sets had an issue with the ballast boars. Basically over time the solder connection s get hot and cool so much that the joints Crack and breal. The ballast board may need to be resoldered. If you choose to try this yourself...be advised there are very high voltages inside a tv that can seriously hurt or kill you.
Jul 07, 2016 | Toshiba Televison & Video
When i swith on the computer, the led light of the monitor doesnt go green nor orange. when i press the swith continuously for many times, at some point the light goes green and unaware when it goes green....
It would be more economical to purchase a new or used LED/LCD monitor very cheaply than it would be to repair a very old CRT monitor.
This has been stated many times now, but the monitor is faulty.
Sep 12, 2012 | HP COMPAQ 7540 CRT Monitor
My 3 yr old Toshiba - A135-S2386 - Vista - has
Just a suggestion................I have seen the RAM cause these problems in many laptops try your old RAM that came with it see if the problems persist....Good Luck
Jul 23, 2010 | Toshiba Satellite A135-S2386 Notebook
I have a ten yr. old Sub Zero model 642. The
maybe a re-gas will last another ten years...if the leak is that small a re-gas will probably last it days out....ask the service man to re-gas it so the food does not spoil until you can save up for replacement...then just see how it goes.
Jul 21, 2010 | Sub-Zero 690 Side by Side Refrigerator
Setting up used VCR
did you check the channel select swith on the toshiba?
Sep 06, 2009 | Toshiba W612 VCR
10 yr old toshiba tv 36
If this TV is 36" it does not use the coolant. This condition could be related to a defective video amplifier transistor that is mounted on the assembly that is attach to the CRT or a dry/cristalized solder joint on that same assembly.
It could also be a defective picture tube(CRT) as well.
Mar 31, 2008 | Televison & Video
Plasma tv
have 42in Magnavox plasma just over 1 yr old picture freezes
for about a minute still have sound then flashes off then comes back on does this about every ten minutes after the tv is on for
a while used to take hours before problem occured has always
done this
Jan 06, 2008 | Televison & Video
Green picture
How old is this TV?
It either has an unrepairable problem in the tube itself, or the circuit driving the green gun has a problem. If the TV is at least ten years old, I wouldn't spend any money on getting this fixed.
Jan 06, 2008 | Toshiba 19A25 19" TV
Toshiba 50h81 turn it self off then back on
Did you check the supply fuses to the convergence ICs? Did you check the output resistors
then i would start by replace the convergence ic first.
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 01, 2007 | Toshiba 50H81 50" Rear Projection...
Televison & Video Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
