Question about Maxi-Cosi Priori
Can't lock the hinge on the maxi cosi easyfix base - any tips?
I have followed all the instructions except one - It says "make sure the support leg is fully folded out and locked at he hinge point" - mine doesn't seem to lock and so the seat seems slightly unstable unless the leg is fully extended. Is it faulty or am I missing something obvious?
3 Suggested Answers
  • 419 Answers
SOURCE: what's the difference between Easybase (non
The Easy Fix Base is used for cars which have isofix points in their car. The Easy Base fits into your car using the seatbelt.
Both of these bases can be used ONLY for the CabrioFix Carseat and cannot be used for the next stage seat (Group 1).
I hope this helps.
Posted on Oct 12, 2009
SOURCE: Is Maxi-Cosi Mico Base compatible with CabrioFix?
No, they are not interchangeable.
Posted on Jan 05, 2010
Dorel UK
  • 1611 Answers
SOURCE: i cannot get the support
The support leg on the base cannot be detatched. It is part of the safety feature on the base and should not be removed.
Posted on Dec 13, 2011
Maxi cosi easyfix base stuck in car. The button will not turn red or release the isofix points. Help please!
Hi
If you're in the UK please contact us directly for further instructions on removal of the product.
If you're not in the UK please visit www.maxi-cosi.com and select the country you're in, then choose the Contact Us tab on the right side of the screen for your enquiry to go through to the customer care department who can assist you.
Dorel UK Customer Service
Sep 08, 2013 | Maxi-Cosi Priori
We have just had our 2nd Child and strated using our current Maxi Cosi Cabrio Fix Seat with Iso Fix base. However, it has stopped clicking into the base! We know it previously worked, but the small
Hi
The Maxi Cosi CabrioFix carseat can be used with the EasyFix or the FamilyFix base (both fitted with IsoFix)
In the event that the seat will not click into position on the base it will need inspection / repair work.
If you're in the UK and the product is under 2 years old, please contact your retailer with your proof of purchase and they can arrange for it to be sent to our engineers for inspection / repair work required under warranty.
If you're in the UK and the product is over 2 years old or you no longer have proof of purchase please contact the customer care team on 01284 413 141 Mon-Thur 8.30-6.30 / Fri 8.30-4.30 (Excluding Bank Holidays) to discuss booking it in for chargeable inspection / repair work required.
If you're outside the UK please visit www.maxi-cosi.com and select the country you're in, then use the "Contact Us" tab on the right side for your enquiry to be sent through to the customer care team in your country.
Jan 01, 2013 | Maxi-Cosi Cabrio Red Flame Reflection...
Indicator lights on easyfix base cabriofix not clicking in to place
Hi
This would indicate that the carseat is not correctly installed onto the base or that the base is not correctly installed into the car on the IsoFix points.
Oct 30, 2011 | Maxi-Cosi Cabrio Red Flame Reflection...
I cannot get the support leg for my maxi cosi base detached. Any ideas
Nov 07, 2010 | Maxi-Cosi CabrioFix (Black Reflection)...
I have a maxi cosi cabriofix and need a base to go with it. Which base fits this model? What is the difference between the easy base and easy fix? My car does not have the iso fix adaptors so that will...
The Maxi Cosi CabrioFix can be fitted using the EasyFix base (IsoFix or seatbelt fitted) the EasyBase and EasyBase 2 (fitted with seatbelt only) or the FamilyFix base (IsoFix only). If you do not have IsoFix points you need either an EasyBase or EasyBase 2 to be fitted with seatbelt.
Sep 25, 2010 | Maxi-Cosi CabrioFix (Black Reflection)...
What's the difference between Easybase (non isofix) and Easyfix base (isofix)? can I use the second one for both maxi cosi cabriofix and car seat up to 3.5 year?
I hope this helps.
Sep 25, 2009 | Maxi-Cosi Baby Gear
Have purchased Maxi Cosi baby restraint with Easy Base - Iso fix,
The Maxi Cosi CabrioFix and EasyFix can only be used with IsoFix or the seat belt on (preferrably) the back seat. Please don't alter the mounting system of the seat as it will give unpredicable results!
The Commodore name has been around since 1978 so it is possible when you own an older Commodore you won't have any means to fix the Maxi Cosi seat.
If you do have IsoFix and/or seat belts in the back seat then please elaborate on the exact nature of the problem.
With kind regards,
Babycare.nl
Erwin de Raad
Jun 17, 2009 | Maxi-Cosi CabrioFix (Black Reflection)...
Maxi-Cosi Priori Logo
207 people viewed this question
Top Maxi-Cosi Baby Gear Experts
Iron
Iron
Kristy Richie
Kristy Richie
Level 1 Expert
Are you a Maxi-Cosi Baby Gear Expert? Answer questions, earn points and help others
