Home | Hitachi | 42EDT41 42 in. HDTV-Ready Plasma Television | Black line in center of ...
Hitachi 42EDT41 42 in. HDTV-Ready Plasma Television
Problem for Hitachi 42EDT41 42 in. HDTV-Ready Plasma Television
Black line in center of screen
By dougied on Jan 18, 2007
My 42" plasma tv has a 2" wide black line in the center of the screen. It comes and goes.
Same Problem
May 22, 2009
-   Hey thanks tomp2000470 This solved my problem Thanks a million !!!-   Guest
May 17, 2009
-   HITACHI 42EDT41 HDTV PLASMA
Problem:
2 - 2" black stripes from top to bottom
at first only one
now 2
at first they would come and go
now present most of the time
-   clisterman
Feb 26, 2009
-   I also have a black line about 2 inches wide vertical down middle of tv it comes & goes but mostly it stays on now. going to buy a new tv it is 4 yrs old only & paid like $2,500. What a bummer any sugestions? ill fix if not to expensive or too complicated. -   bdp0456
Feb 01, 2008
-   We have 2 lines that come and go and we can't get them off!!! I called to see how much the repair shops charege to fix it and they quoted $70.00 just to come and look! Then they said it was probably the back panel and if that was the case, they said I might as well buy a new t.v. That's crap if you ask us!!!
-   jenlon
Jan 08, 2008
-   There is not really any steps you can take because the black line off center of the screen comes and goes.-   Guest
Best Solution
posted on Jan 02, 2008
Very Helpful)
JohnMalovic
Rank: Apprentice
Rating: 100%, 12 votes
Depending on where exactly the line is, its most probably a bad logic buffer board, if its in the middle then its your F board. Its really not hard at all to fix it yourself, will be more than happy to help any of you guys.
take care
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #2
posted on Jan 03, 2008
Very Helpful)
bkrice12
Rank: Apprentice
Rating: 96%, 7 votes
I have a solid black vertical line going down the middle of mine, too. I called Hitachi and they referred me to a tv repair place. The repair guy came to my house, took a look at it and came back to replace one of the circuit boards. The new part didn't help so Hitachi is going to replace my television instead. Thankfully after all this, I am still under warranty. I've been really impressed with Hitachi's customer service so far. Good luck with your TVs!
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #3
posted on Jan 27, 2008
Very Helpful)
revrenhex
Rank: Guide
Rating: 96%, 6 votes
I had the same vertical black line on my TV. I identified an capacitor on the PDP board that had come unsoldered, so I fixed that, and the black line went away. But that created a whole host of new problems. I had blue shadow lines on the TV and couldnt use any of the digital inputs.
I replaced the PDP board with a refurb unit and all was well, until the black line reappeared. So instead of just throwing another PDP at it, im looking for ideas.
Comments:
Jan 27, 2008
- I do had (have) the black line. I found a capacitor on the PDP board had come unsoldered. I fixed that and the black line went away, but a few new problems arose. I had blue shadow lines all over the screen, and could not use any of the digital inputs.
I put a refurb PDP board in it and fixed all problems, for about 2 months, now the black line is back, and im not sure where to go from here. Would love any suggestions on this.
Was this helpful?
Yes
No
Solution #4
posted on Jan 18, 2007
Somewhat Helpful)
henlopen
Rank: Wiz
Rating: 84%, 649 votes
You likely have a bad connection on one of the circuit boards. I'm assuming that it is a horizontal line, and not a vertical line you are talking about here.
Was this helpful?
Yes
No
Solution #5
posted on Apr 27, 2009
Helpful)
tomp2000470
Rank: Master
Rating: 84%, 16 votes
These black lines on the plasma screens are very fixable.  There is a dry solder joint on a circuit board at the bottom of the plasma that needs resoldered.  There are 6 or 7 "ribbons" along the bottom of the screen that correspond to vertical sections of the display, so you just follow the black vertical line down to figure out which one is faulty.  I just performed this fix successfully on my first attempt on a Gateway plasma, but it will work on most plasma's, specifically Hitachi, gateway, LG, Hyundai, & Akai. I think they may all have LG boards, my gateway did.
I can't really describe very well what to do, but I assure you it is fixable.  If anyone is near nashville, I might be able to help you out.  My email is tomp2000@juno.com.
thanks,
ST
Was this helpful?
Yes
No
3 people thought this was helpful
Popular Solutions for Hitachi 42EDT41 42 in.
Questions and Unsolved Problems for Hitachi 42EDT41 42 in.
Do you recommend Hitachi 42EDT41 42 in. HDTV-Ready Plasma Television?
Answer
Answer
i have a rolling picture with lines through the picture all of a sudden though can play dvds fine?
Answer
i have a plasma flat screen but the glass on the front cracked. i'm wondering if its replaceable
Answer
my hitatchi plasma tele comes on and viewing is fine but for no reason the screen then goes black... (More)
Answer
I have a Hitachi 42EDT41A Plasma. TV power up but the picture is very faint. Not much color Image... (More)
12 Other Users Have The Same Problem - Continued
Comment by walteru, posted on Jan 03, 2008
I have just noticed a similar problem in the past few weeks. I bought the TV last Jan., 25th. I'll be contacting Hitachi service before my year end warranty.
Comment by LVOpus, posted on Jan 02, 2008
my black lines are about 2", one is just about center, and the other is to the left. the center one seems to make the image just to the right of the line fuzzy, while the left line does not. The left one seems to disappear more than the center line. Hopefully that can narrow down which board, and where can I find these boards to buy?
I have the same model, I have 2 lines that come and go, mostly come =/ Have not looked into repairs yet, I fear the worst.
Comment by fozzir, posted on Dec 21, 2007
Same TV. I've had it almost 4 years. I'm still pissed. Paid 3 grand for it!. Love to see a solution! What's a repair cost?
Comment by taskmanbb, posted on Dec 17, 2007
I am having the same problem with the same model, if you find a resolution, please shere it. ThisTV is less then two years old, it pisses me off.
Thanks
Comment by Mike 2342, posted on Dec 15, 2007
2" vertical line on my plasma TV
Comment by Guest, posted on Dec 15, 2007
There is a vertical black line on my TV
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Hitachi 42EDT41 42 in....:
Top Flat Panel Television Experts
Rank: Guru Guru
Solutions: 1493
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Flat Panel Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
