Question about RCA 24F501TDV 24" TV
DVD Tray won't open.
Hello, actually I have two problems with my RCA 24F501TDV; The first problem was with foldover which I see can be easily repaired. Not a problem. The second problem, is the DVD player, the tray will not open with the remote or manually. The TV with intermittently try to open it no matter what I do, so it seems to think the tray needs to be open/closed at all times. Maybe I am wrong on that theory... The tray motor does work, but that tray wont move, and the DVD inside it wont play.
    President:
  • 1,284 Answers
Replace the DVD unit part#265278. It shows as NLA but do some searching.
Posted on Feb 01, 2007
DVD ' s tray won't open when pres OPEN, DVD is inside
There are little gears to open the tray with a little rubber belt that drives it you should be able to open door and pull on tray to get disk out if not unplug it take top off push tray out Cheapper to replace player than to fix but little flap should pull down grab tray and pull
Feb 21, 2013 | RCA DRC247N DVD Player
DVD/CD disc opener won't workGetting
Usually the tray has to be opened and inspected and if lucky it can be realigned--if not parts may be hard to find as they usually do not sell individual parts for the mechanism.
Nov 05, 2012 | Televison & Video
It won't open
i bet t is the belt for the tray motor, mine hs the same issue, i took it apart ad found the broken belt, jut have to find the replacement
if you remove the steel cover from the top of the unit you will see the disc, there is a bracket above it which can be removed with two screws and take the dvd out easily
May 19, 2012 | RCA RTD315 Theater System
CAN'T EJECT, IS BLOCKED
I had the same "Blocked" problem and solved it - by using a rubber band! Unplug the machine and take off the outer cover. Remove the DVD reader and take off the cover to the reader - you can now easily recover the DVD that was stuck in the machine. Now slide out the actual DVD tray, you will have to bend back a couple of restraining bars to get the tray out completely. You should now see a small white wheel which is actually the end of a concealed electric motor. There will also be a larger black pulley which controls the movement of the DVD tray. If there is no band connecting the pulley and the white wheel, that is your problem and I solved it with a small elastic band. Put everything back and turn on, wait for all the messages to clear and press the eject button - the tray opens simples. It has taught me never to force the tray in manually, but to always use the eject/open button.
Oct 26, 2010 | Philips DVDR3380/05 DVD Recorder
Dvd tray will not open or play
The reason your player keeps reading a disc and do not play is because the the disc tray is not sitting the disc properly on the lens.
The disc tray is faulty, the mechanism that controls the opening and closing of the tray is damaged and needs repair.
To fix this, you have to get the appropriate screwdriver, open the cover of the player.
You will see a mechanism by the opening of the tray that controls the disc tray.
Get a replacement mechanism and change it. Mostly the rubber slacks and does not control the tray properly.
Changing the mechanism will solve the problem.
Take care
Jun 15, 2010 | RCA DRC8295 DVD Recorder/VCR Combo
MY DVDR3380 TRAY WILL NOT OPEN, SAYS ITS BLOCKED
Aug 22, 2009 | Philips Televison & Video
Picture rolls continually, works ok with DVD or GameCube
Hi
Check the system of your tv! maybe the settings of system is wrong! check the system PAL SECAM NTSC. put the settings in to auto mode.
Thanks!
Dec 26, 2008 | RCA 24F501TDV 24" TV
Hoizontal Bar across RCA Model 24F501TDV Color TV
you may need to change your resolution on tv settings as well as cable or satelite settings if you have one of those
Dec 12, 2008 | RCA 24F501TDV 24" TV
DVD problems
the driver system may have got faulty.. if you know how to open the player open it and see what is stopping it from opening. else take it to some tech. he will do it for u
Jan 21, 2008 | RCA DRC255N DVD Player
LG DVD+RW door won´t close
Deliverance
this problem can happen if tray-in sensor not sense. their r a small liver which press tray in sensor automaticly when tray stay inside. liver and sensor location is near emergency exit hole (when u use a pin for emargency exit actually u press this liver then it release try-in sensor). check this liver and its path any pice of cd is their or not. (to check open ur drive cover. to open it at first use emeargency exit hole to open tray then open cover)
Dec 19, 2006 | LG (GSA-4120BK) DVD±RW Burner
RCA 24F501TDV 24" TV Logo
256 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
