Question about Agri-Fab Agri - Fab Incorporated No. 45 - 0315 85lb Tow Spreader
Flow control level broke
The flow control lever is broke, can this be replaced and where do I find parts?
  • rmcrafts1222 Mar 05, 2009
    the rod from the control handle to the gate is missing, is there someway to solve this problem? thamks, Ray.
  • 163 Answers
Fresh air-flow controller broken
the FSM covers HVAC. buy /barrow one.
or at alldata.com, log in ,see it.
you will have to gain access to the cables. and levers and to the
damper levers....
how to remove all those parts and not break very old plastic takes some skill , some parts just pull off others have hidden screws.
here is a quote on control panel.
  1. Disconnect the negative battery cable.
  2. Pull the control knobs from the levers.
  3. Release the latches at the rear of the bezel. Remove the control assembly lens and disconnect the bulb.
  4. Disconnect the control cables at the blower and heater assembly.
  5. Remove the control assembly fasteners.
  6. Pull the control assembly out and disconnect the electrical connections.
  7. Disconnect the control cables from the levers.
  8. Remove the blower, air conditioning and heater switch
Jan 30, 2014 | 1997 Suzuki Swift
Bike has been sitting up for a year or two. I squeezed the front brake lever, which was really tight. It broke free but now there is no pressure at all. Not sure where to start.
Open your brake reservoir and check fluid level. Add fluid to proper level and slowly squeeze the lever, watching for bubbles or fluid flow in the reservoir. Check the brake calipers to ensure there is not a leak in that area. If no leaks, continue squeezing the brake until it is fully operational. May have to add fluid while doing this. Close reservoir.
Apr 13, 2011 | 2003 Suzuki GSX-R 600
The gear shifter broke off my 02 Mountaineer, the metal part that attaches the shifter lever to the steering column broke.
Shift lever collar is what is broke on our 2002 Mountaineer. It isn't difficult to replace, just time consuming. Look up part number 905-104 at Oreilly's
Oct 27, 2010 | 2002 Mercury Mountaineer
My Kohler single lever pull-out faucet stopped working. Raising up does not start water flow. Turning left sometimes starts some hot water, but raisinglever up and down does not start or stop water flow as...
Fix a kohler faucet
most likely the gasket broke inside the lever, you have to replace it.
shut the water off from the angle stop (valve under the sink) both hot and cold.
use an allen wrench ("L" wrench) to remove the tiny screw around the lever, >>>>before you do that place a rag covering the drain for if you drop it<<<< after that pull the lever out, that will show the inside of the faucet. use an adjustable wrench to remove the actuator from the base. when you get that part out you should be able to see the damage to the gasket. At that point you need a phillips screwdriver to get the gasket out and back in >>>>take the damaged gasket to the hardware store<<<< and get a replacement you may have to change more than one. after you get all the gaskets in place, reinsert the actuator and don't forget to tight it up with the adjustable wrench. center it so it would dispense the same amount of hot and cold water, replace the lever reinsert the tiny screw with the "L" wrench. turn on water from angle valves and test faucet.
that should do it and save you about 300 bucks
if it works for you don't forget to rate me
Apr 28, 2010 | Kohler Model 10433: Fort® Single-control...
How do i replace the turn signal for a 1980 vet?.. the old one broke off.
Are you saying the lever broke off or the actual swiich is broken inside the steering column? if it is just lever you can buy the lever, it just screws out counter clockwise. If you have cruise control you can buy the lever here.
http://www.ecklers.com/product.asp?pf_id=A8648&dept_id=1718
If it is not the lever you will need to remove the steering wheel and the lock plate under the wheel, this will require special tools, these are a GM locking steering wheel spring compressor and a steering wheel puller, these tools can be purchase at upscale auto parts stores like NAPA and Carquest, they are made by KD Tools.
Aug 23, 2009 | 1980 Chevrolet Corvette
The small red lever control broke off (in half)
Yes it can be replaced. Just go to the nearest place that sells and services this item and either buy the part or have them install it for you.
please mark this as a fixya! thanks
Mar 18, 2009 | Homelite 'Yard Broom' Leaf Blower
The film advance lever on my ricoh kr-5 broke
plenty of these cameras are on ebay sold for parts
Jan 05, 2009 | Pentax ME Super 35mm SLR Camera
2005 Dodge RAm 2500....shifter linkage broke
there is a recall for that problem dealer fixes for free
Dec 06, 2008 | 2005 Dodge Ram 3500
1994 saturn no air flow to front defroster
I bet that the slider control is not working properly, look on the drivers floor under the dash by the center console, you should see a diverter lever that moves when you select the air flow position. The cable may be disengaged or the lever can sometimes stick, or it just may need adjustment. you can manually detatch the cable and move the diverter control lever to see if the baffle inside the housing is functioning correctly to direct the air flow to the windshield. If any of the above do not function, a trip to your local junk yard may help with replacement parts for a reasonable price, assuming your a hands on type person. Good luck
Sep 13, 2008 | 1996 Saturn SL
Agri-Fab Agri - Fab Incorporated No. 45 - 0315 85lb Tow Spreader Logo
480 people viewed this question
Top Agri-Fab Garden Experts
Roland W VanLue
Roland W VanLue
Paul Sikkema
Paul Sikkema
Joseph Mueller
Joseph Mueller
Are you an Agri-Fab Garden Expert? Answer questions, earn points and help others
