I need to find a pdf user manual for my asus motherboard all i no is its number EP-8K5AE . i need to no how to attach he case usb portd to the mother board and what pins to use
  • 341 Answers
From the number you show the board is a EPOX board not an ASUS board. EPOX went out of business in 2007.I checked on the internet and even though their home page is still there all the site links are dead.I googled the model number and there is not much out there relating to this board. You may find it if you put some time on the internet. Check out this forum http://forums.pcper.com/. There are many other forums that may help you too.
Posted on Nov 29, 2008
Manual needed
Paul,
http://www.asus.com/Motherboards/Intel_Socket_478/P4VPMX/
Download> Select OS (I just clicked on WinXP) > Click on the + sign next to Manual (5)
Version 1877
P4VP-MX user's manual English version E1877
2.5 MBytes
Click on the blue -> Global
Or copy this,
http://dlcdnet.asus.com/pub/ASUS/mb/sock478/p4vp-mx/e1877_p4vp-mx.pdf
Paste it in your address bar, and press the Enter key.
(May take up to 30 seconds before the first page comes up)
Page 17 - Motherboard Layout
(PDF file page. 1-7 for the actual manual page)
Page 28 - Front Panel Audio Connector (1-18)
Page 30 - USB Header (10-1 pin USB56) (1-20)
Page 32 - System panel connector (10-1 pin PANEL1) (1-22)
The front of your computer is the Front Panel.
The area of pins on the motherboard, that the main cables, (Wires), go to, is the Front Panel header.
Motherboard as installed in computer case;
Processor to the top, Ram Memory slots to the right, white PCI slots to the bottom;
The Front Panel header is located at the Bottom/Right corner.
PANEL1.
Two rows of pins.
(To the left of it is the front panel USB header. USB56. Looks very similar)
Doesn't show numbering for the pins. (Contact pins)
I'm going to number them for easier orientation
The pins across the TOP are numbered ODD.
Starting on the LEFT side going towards the Right;
Pins 1, 3, 5, and 7. There is NO Pin 9.
The pins across the BOTTOM are numbered EVEN.
Pins 2, 4, 6, 8, and 10.
A) Pins 1 and 3 are for the Power On LED (Light)
Pin 1 is for the Positive ( + ) wire.
If the LED is dim when the computer is on, switch the wires around.
B) Pins 5 and 7 are for the Power On switch.
C) Pins 2 and 4 are for the HarDDrive activity LED (Light)
May be marked on the wires as HDD, or IDE.
Pin 2 is for the Positive ( + ) wire.
If the harddrive activity LED is dim when the harddrive is active, switch the wires around.
D) Pins 6 and 8 are for a Reset switch, IF a Reset switch is used.
E) Pin 10 is N/C
Not Connected. (Probably a +5 Volt point for the factory to use)
Have problems downloading, or saving the PDF manual, post back in a Comment.
For additional questions post back in a Comment.
Regards,
joecoolvette
[Motherboard chipset;
Northbridge -> VIA VT8751A (Also known as VIA P4M266A)
Southbridge -> VIA VT8235
http://en.wikipedia.org/wiki/List_of_VIA_chipsets#Socket_478
http://en.wikipedia.org/wiki/File:Motherboard_diagram.svg
[CPU = Central Processing Unit. Another term used is Microprocessor, or simply -> Processor, for short ]
Jul 09, 2012 | ASUS Computers & Internet
I don't know what motherboard it is that i have to download the users manual can you please.....please help me
Turn off the PC. Remove the side panel from the case. Get a flashlight and inspect the mother board. You're looking for a number to identify the type of mother board. ASUS mother boards usually place this number just to the left of the memory slots. It's usually 5 or 6 digit long and made up of both letters and numbers. One of my computers with a ASUS mother board is a P5LD2. Once you know this number you can go to http://support.asus.com/ and download updated drivers for *********** board. You may need to identify what type of socket *********** has. If you have a fairly recent Intel microprocessor you probably have a socket 775 mother board. If it's an AMD microprocessor it's probably a SocketAM2 or AM3. You might have to do some searching if these choices don't work. I hope this advice helps you out.
Jan 28, 2011 | ASUS Computers & Internet
What are the motherboard usb header pin codes for
Found the location for the Manual... the PDF Manual won't download. Safest bet is to get the layout from them... I'd make a call and get the Manual... couldn't find it on Google either...at least in the first 5 pages.
http://www.epox.com/product.asp?id=EP-8KMMplus
Jan 02, 2010 | EPoX EP-8KMM+ Motherboard
No manual for conecting mother board
http://dlsvr03.asus.com/pub/ASUS/mb/sock478/p4sp-mx%20se/e1676a.pdf
CLICK ON THIS LINK AND DOWNLOAD THE USER GUIDE IN PDF FORMAT WHICH U CAN READ ON A ADOBE READER
RAHUL
Feb 22, 2009 | ASUS P4SP-MX Motherboard
Pluging in extra usb ports/Mic and headphone jacks from the tower
Answer me this. You're case is an Antec tower? The motherboard is the Asus P4P800 SE ? Is this correct?
If you have you're manual you can see what goes where on the board for front panel connector page. 2-31. (This diagram shows you how to connect the front mic & speaker).
To connect the Antec's front USB ports plug the case USB front connectors onto USB56 & USB78 shown on page. 2-30. Most case wires are already set within their USB connectors & the Antec's front USB connector should fit right on the mother board's pin's. If you need you're user manual, download from Asus by clicking on this link. http://support.asus.com/download/download.aspx?modelname=P4P800%20SE&SLanguage=en-us
Good Luck!
Mike
May 19, 2008 | ASUS P4P800SE Motherboard
User's manual for epox mother board ep-8k9a7i
Download from this link for EPoX EP-8K9A7I.
Fill in (File type & Model).
http://www.epox.com/usA/downloads.asp
Enjoy!
Mike
May 02, 2008 | EPoX EP-8K9AI Motherboard
AMD, ASUS K8V-MX MOTHER BOARD SOCKET 754 AMD
hello my friend here it is the link
http://support.asus.com/download/download.aspx?SLanguage=en-us&model=K8V-MX
to find and to download what you need
it is from asus official site so its secure,its from your mainboard,so just find exactly what tipe of downlaod you need..I suggest the user manual.youll find there the diagram for the case wires.
good luck.talk again if you need something
oh..rank my answer please..;)
thanks..
bye bye
Feb 05, 2008 | AMD Asus K8V-MX Socket...
Motherboard
What motherboard do you have?
Aug 28, 2007 | Biostar K8M800-M7A Motherboard
Computers & Internet Logo
360 people viewed this question
David Payne
David Payne
