Question about Canon Digital Rebel / EOS-300D Digital Camera with EF-S 18-55mm and EF 75-300mm Lenses
Digital rebel battery drain with flash only
Digital rebel aprox 5 yrs old. Two batteries same age. Freshly charged batteries immediately drain when either on camera or attached flash is used. Non flash operation does not show problem. Battery or camera problem?
    Problem Solver:
  • 5 Answers
I would suspect the batteries
Ive got an eos Rebel think its just over 4 years old
for the last year its been used every weekend for several hours 300+ pics per weekend between 2 nights I found that recently where one battery would last a night the battery was running out midway through & also taking longer to charge afterwards
2 after market replacements cost me about £10 and things are back to normal
5 years is a pretty good lifespan for a battery so its probably just getting old
Posted on Dec 16, 2008
I have a digital Canon Rebel XT. My camera was operating fine until I put an old memory card in. The view finder started flashing "CF error". I immediately removed the "old memory...
Try removing the battery and the memory card. After about a minute return them both back and try to turn it on again. Update me what will happen.
Sep 15, 2011 | Canon Rebel XT / EOS 350D Digital Camera
I have sx100 camera. when i am using to take a picture with flash i cannot take the next picture immediately. some times it take more than 30 sec. without flash no prob. this is not a memory card problem.
It depends on your battery condition, flash capacitor will charge faster if battery is freshly recharged. Or battery has larger current capacity. You can shoot pictures with flash faster if its fill-in or closer in distance. Which means capacitor recharge is not totally depleted for each flash duration.
Aug 26, 2010 | Canon Cameras
Error 5 on Canon eos 350D
Well first of all you can try a full reset, Pull both batteries out -the normal one, and the date/time one. If your camera is older (>2 yrs), it may be time to replace that battery..... anyway Put a new one in, and then put in the freshly-charged main battery, that might clear the error. If further you have the same problem then something is causing the flash to stick. Press the button and pull gently on the flash. Post comments for more help or information needed.....
Good Luck!!
Thanks for using FixYa!!
Jul 07, 2010 | Canon Rebel XT / EOS 350D Digital Camera
Camera drains charged batteries
Most likely your batteries are just not holding a charge. However, before you spend good money on new batteries, try charging them on another charger (friend or sympathetic photo shop?). Could be the charger also. Usually it's the batteries, though.
Mar 16, 2009 | Canon Rebel XT / EOS 350D Digital Camera
I have Canon EOS 300D digital Rebel. I have had intermittent problem with the camera display screen going blank even though I put a freshly charged battery in. Usually I can take a couple pictures then the...
Strange, intermittent problems with the EOS Digital Rebels can be caused by a defective shutter release switch. We charge about $85 to replace it.
Nov 12, 2008 | Canon Cameras
Battery problem
did you use comapny authorised battery if not go for it
Apr 24, 2007 | Canon PowerShot S1 IS Digital Camera
Help on P72
The recycle time using flash gets worse pretty quickly if you are using the onboard flash. The delay is pretty much inversly proportional to the remaining charge in the battery. I.E. the less charge, the longer the time. This happens with any camera. You might check the time with fresh batteries (or freshly charged) and then after maybe 20 shots or so. I would not find 5 seconds atypical, but 10 seconds sounds like you are pretty close to dead battery. If you get 10 seconds at the start of a fresh battery, then you may have a problem. Also, capacitor charge time can vary from capacitor to capacitor and a 1-2 second variation between camera flash units, either onboard or off board is probably normal. Age of capacitor can also have an effect.
Sep 13, 2005 | Sony Cyber-Shot DSC-P72 Digital Camera
Canon Digital Rebel / EOS-300D Digital Camera with EF-S 18-55mm and EF 75-300mm Lenses Logo
168 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
