Question about Microsoft Xbox Console
Disc holder won't open
Xbox will not open disc holder and power keeps for a couple of seconds after hitting off button
  • dscent95 Dec 31, 2007
    xbox will not open disc holder and power keeps for a couple of seconds after hitting off button please help
  • electronicma Jan 27, 2009
    this problem is caused by power supply units that have been overloaded.your motherboard has permintut damage by this.if you leave it pluged up it overheats and messes up the harddrive.disk tray wont open because of bad gears.
    President:
  • 2,961 Answers
Go to this solution, xbox 360, but same thing applies http://www.fixya.com/support/t129094-will_not_open
Posted on Jan 18, 2007
Yes when I try to open the Xbox 360 disc tray the power button in the center flashes as if the disc tray is opening, but doesnt open. it flashes even when i havnt pressed a button for it to open the d
Try turning off the 360 then turning the xbox on its side, turn the machine back on holding the eject button and the power button together for about 30 secs then the machine should function normally
Jun 19, 2014 | Microsoft Xbox 360 Console
What do I do it will not Except my games it just kicks them out
It looks like something is keeping the tray from closing all the way or the eject button is somehow being pressed when it closes. Open the tray and get a flash light to look inside to see if there is anything in there that shouldnt be (like maybe a disc that came loose from the tray and is still inside the xbox). If it looks all clear try holding down the eject button when putting the disc in. If that doesnt work try opening and closing it without a disc in. If it stays closed without a disc open and close it a couple times to be sure then try putting the disc in again. If that doesnt work try standing the xbox up on its side and putting the disc in.
The next step I would try is replacing the disc drive. This of course will void your warranty if you do it yourself I would suggest requesting repair from Microsoft if it is in warranty (http://support.xbox.com/en-US/xbox-360/repair/repair-process)
If it is not in warranty try replacing the disc drive (This is pretty complicated. I have done it and honestly wouldnt suggest doing it yourself unless you are very familiar with disassembling and resembling electronics.) Here are instructions http://hardandsoftgaming.wordpress.com/2011/03/12/replacing-a-faulty-xbox-360-dvd-drive-firmware-flash-or-circuit-board-transplant/
If you are not comfortably with doing this yourself find a local repair shop.
May 07, 2013 | Video Game Consoles & Games
My xbox 360 disc drawer wont open
if it doesnt open this is what i do to mine cause i have your problem ok 1st step:lift up the the front of your xbox360 console gently then step 2:drop the front of the xbox360 softly back down not hard or to violent step 3:if that doesnt work keep on hitting the open and close button were you enter the disc but not too fast ohkay well thats all my info hope it works
Mar 26, 2013 | Microsoft Xbox 360 Console
When i load a disc open tray keeps coming up, it says reading disc for a couple of seconds then says open tray. how can i fix this myself
This problem can not be fixed yourself. The lens has either become scratched or dirty, and can not read discs. Send the console in to Microsoft support and they can fix it under the terms of your warranty.
Feb 27, 2011 | Microsoft Xbox 360 Console
Draw won,t open cant get my game out xbox360
If the tray does not open when you press the eject button, try to manually open it. To do this:
  1. Unplug your Xbox console from the power source.
  2. Locate the manual release button on your Xbox console.
    For most Xbox consoles, the manual release button is located in a small pinhole to the left of the eject button under the disc tray.
    For some Xbox consoles, the manual release button is located under the disc tray. It can be under the "O" or the "B" in the word "XBOX" that appears on the tray.
  3. Insert a straightened paper clip or other small tool in the hole at an angle to the left. Gently push the paper clip to try to press the manual release button and partially open the disc tray. This may take several tries. Typically, a thin paper clip works better than a thick paper clip.
    If you insert the paperclip in the hole and find an obstacle, this indicates that your Xbox console's manual release button is located in a different area of the console. Look under the "O" or the "B" in the word "XBOX" that appears on the tray. If this is the case, insert the paperclip under the "O" as outlined in step C. If you find an obstacle, insert the paperclip under the letter "B”. The manual release button is located in one of these three locations.
  4. After the disc tray partially opens, pull the tray with your fingers to fully open the tray.
Hope this will help u.
Sep 22, 2009 | Microsoft Premium System for Xbox 360
Disc keeps ejecting
Sounds like your disc drive is malfunctioning. Honestly the only thing i could possibly think of is that the button for the disc drive could've gotten stuck and opens the 360 by any sudden movements.
Jul 01, 2009 | Microsoft Xbox 360 Console
Power symbol on power button keeps blinking green and doesnt stop and doesnt open the tray or read discs
You might want to ask Xbox directly for this one.
Call them at (800)-469-9262
Email them here
Or use Ask Xbox
May 21, 2009 | Microsoft Xbox 360 Pro System Console
XBOX 360 DISC CARTRIDGE STUCK OPEN
pull it all way out manaual then hit shut button
Oct 07, 2008 | Microsoft Xbox 360 Console
Repair
if it won't open, turn off the console and remove the faceplate and try to eject the button. if it still won't open get a paper clip and straighten it out. you need to locate a small hole that exactly fits a straightened paper clip. it's located just below the silver lining of the disc tray about one and a half (1 1/2") inch from the left side of the disc tray. insert the paper clip into that hole and it should pop up the disc tray enough for you to be able to pull the disc tray all the way.
if it doesn't work there are still 2 more small holes that you can locate. the 2nd one is just beside the first hole and the 3rd one is just under the second X on the XBOX 360 text on the disc tray. try those two holes if the first hole doesn't work.
Jan 17, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox Console Logo
276 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
