Question about Plumbing
American Standard kitchen fawcett
I just installed a new kitchen fawcett. Whenever I turn the water on quickly, there is a knocking sound under the sink. Almost sounds like air in the line. When I turn the water on slowly, it is fine. Any solutions?
  • James Feragola
    James Feragola May 11, 2010
    Does it happen when you shut the water off as well?
    Is is a rhythmic knocking? Like a Tic....Tic.... Tic.
    Can you located the pipe it's coming from or is it in the wall?
    Feragola
Bleed the air from the sprayer hose by turning it on until water comes out. The knocking noise will be gone after you do this.
Posted on Jan 02, 2010
    Problem Solver:
  • 9 Answers
It could be air if you recently had the water off at the main and let the pipes drain, but this would go away after a short while. It is most likely either a feed line from the wall to the faucet flexing when the pressure and hitting something under the sink or a water line in the wall that may have not been strapped properly to the stud when installed. They bounce around sometimes if not secured. Hopefully the feed line as the second is a bit more work to correct.
Good Luck
Posted on Dec 04, 2008
I just installed an American Standard easy touch faucet 6310F. The pressure is very low. Anybody know what the problem may be?
At the base of the handle there is a flow regulating check valve. Shut off water supply and unscrew handle and look for debris. Many times the washers break down on the shutoffs under the sink and release "crumbs", these usually block aerators and sometimes the cartridges on certain faucets. Hope this was helpful.
Feb 16, 2011 | American Standard Kitchen Faucet 6310 020...
IF HAVE A AMERICAN STANDARD KITCHEN (6310) . I JUST READ THE PART TAKE FACTCET APART AND TURN ON WATER . I DID THIS AND GET WATER ON COLD SIADE BUT NOT ON HOT. THIS IS WITH CARTRIDGE OUT .DOES THIS TELL...
It says you have a problem with the hot water. First thing to do is to turn the hot water supply valve under the sink off, and then remove the line from the valve to the faucet at the valve. Then put a bucket underneath the valve and turn it on (carefully). If you don't get any flow, then the problem is in the valve or the pipes supplying the faucet. If you get flow there, then the problem is in the supply line or possibly at the faucet.
Jan 18, 2011 | American Standard Kitchen Faucet 6310 020...
Low water pressure
Remove the spray head and point the hose into the sink drain. Turn the faucet on. If you have good pressure, cal American Standard for a free replacement spray head.
If you still have low water pressure without the spray head, ask them for a new faucet cartridge.
After replacing the faucet cartridge, if you still have low water pressure you will need to ask for a new faucet, possibly free if yours is still under warranty.
Sep 07, 2010 | American Standard Kitchen Faucet 6310 020...
We purchased an American Standard kitchen faucet model 4040 an couple of years ago. Worked great after installation, but not long after water just started coming out, both hot and cold, at a trickle. We...
I had the same problem. You need a "diverter" (044264-0070A). It's available directly from American Standard at no charge. Lifetime guarantee! Phone: 1-800-442-1902.
Aug 15, 2010 | American Standard Kitchen Faucet 6310 020...
I just installed an american standard faucet Molel# 2808.222 Called SPREAD LAVATORY FAUCETS . The water does not come out. can you please help me?
Silly question, but did you turn the shut offs back on after installing? If so, the aerator is probably clogged (the screen on the faucet). Unscrew it and clean it out. Good luck
Dec 31, 2009 | American Standard Kitchen Faucet 6310 020...
Installed new faucet worked then all water stopped
If it has a side spray the diverter might be stuck. try flicking the spray handle on and off.
Jun 10, 2009 | Price Pfister Marielle Kitchen Faucet with...
American standard kitchen faucet roars when hot water turned on
Not the aerator at all as this part would act the same if hot or cold.
Have you checked the shut-off valves under the sink? Sometimes just turning them a bit in either direction will solve that problem (will only be the case if it have been shut off at the valve recently).
Also, maybe the supply line on the hot side have been kinked?
Hope this helps
Apr 11, 2009 | American Standard Plumbing
We are getting a metallic taste and smell
The metalic taste is coming from the the new faucet
I would call American Standard and ask them if they have any complaints for this particular model
I would run hot water through the faucet for 5 minute intervals
If it persists I would take it back and demand a refund or cal AS and demand a refund or replacement model
I am sure the local news would like to report something like this
Jan 05, 2009 | American Standard Kitchen Faucet 6310 020...
Plumbing Logo
549 people viewed this question
Top Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
