Question about Pioneer Car Audio & Video
Pioneer GEX-FM903XM, system works great, however it often drops out and has just static. The signal indicator is strong. I think there is a bad connection into the radio. Where should I start looking?? Thank you for you help John Dorshimer johnd1340@aol.com
  • 3 Answers
It may be possible that the FM frequency chosen during setup, is in use in your area by a strong signal from a local station. Change to another frequency and see if the situation improves.
The following is from the Operation's Manual:
FM Modulator Setting
You can adjust FM Modulator frequency and output level.
7 Frequency
If output from the FM Modulator is hard to hear due to interference from a strong broadcast
station transmission, you can switch to another frequency.
You can adjust frequency between 87.9 and 90.1MHz.
7 Level
If the output sound is too quiet, too loud or distorted, you can adjust FM Modulator output
level.
You can adjust level between “LEVEL–1” and “LEVEL–7”.
1. Press the POWER button for 2 seconds to enter the FM Modulator Setting
mode.
2. Select the desired frequency
with the left/right arrow buttons.
3. Increase or decrease the Level
with the up/down arrows (buttons).
4. To cancel the FM Modulator Setting mode, press the POWER button again
for 2 seconds.
Note:
• After entering the FM Modulator Setting mode, if you do not perform an operation within about 8 seconds, the FM Modulator Setting is automatically canceled.
Posted on Dec 13, 2009
Pioneer GEX-INNO2BK XM Radio Receivers backight problem
Have you tried changing the backlight controls in the menu? Pull up your menu, go to settings, then preference, and change display. Choose backlight display. You can put it always off, always on, or on for however many seconds.
Jun 05, 2010 | Pioneer GEX-INNO1 XM Radio Receiver with...
I have a pioneer GEX-XMP3 radio. No Sound
The same thing happened to my XMP3, I had to send it to Pioneer for a replacement XMP3........call Pioneer @ (800) 421-1404, Monday through Friday, between the hours of 7:00 a.m.
and 4:30 p.m. Pacific time.
Feb 15, 2010 | Pioneer Audio Players & Recorders
Pioneer vsxd412 overload
OVERLOAD indicator
This lights when an analog signal is too strong (the
SIGNAL SELECT needs to be on ANALOG). It
indicates the sound is distorting and the signal
should be reduced.
Dec 28, 2009 | Pioneer VSX-D412 Receiver
I have had my pioneer gexfm903xm tuner for abt 8 years it has worked fine untill last week now when i turn it on the radio isn't picking up the signal and after turning it off and on several times it will...
The unit must be reset under the following conditions:
When using this product for the first time after installation.
When this product fails to operate properly.
When strange (incorrect) messages appear on the display.
• To reset the microprocessor, press the RESET button on the unit with a pen
tip or other pointed instrument.
Nov 19, 2009 | Pioneer GEX-FM903XM
I purchased the car
Yellow
To terminal always supplied with power
regardless of ignition switch position.
Red
To electric terminal controlled by ignition
switch (12 V DC) ON/OFF
Black (ground)
To vehicle (metal) body.
Dec 02, 2007 | Pioneer GEX-FM903XM
No XM Audio, no fault indication
Buss cable is plugged into the wrong connector on the GEX-P920XM. The installation manual is not clearly written, the figure in the manual is correct.
Sep 22, 2006 | Pioneer GEX-P920XM Satellite Radio...
Car Audio & Video Logo
143 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
