Question about Whirlpool Refrigerators
Air difusser between freezer and fridge will not stop running
Sears replaced the difusser 1 1/2 years after buying the fridge because the plastic door broke. That part lasted 7 months so I knew what it was and replaced it myself. Now after 8 months the whole fridge holds it temp correctly but the difusser motor runs 24/7. Thats all you can hear in the kitchen is the motor running around and around. Is there a reset somewhere or should I replace it for the third time. I have shut everything down and pulled plug,but it just keeps running after plugging back in.
  • rhode99 Nov 29, 2008
    where would that be located on the fridge?
  • rhode99 Nov 30, 2008
    ok I ordered a circuit board and a diffuser.. Model #106.53293202
  • 33 Answers
When things like this happen I usually replace the main electronic circuit board which would control the motor operation timing, etc.
Posted on Nov 29, 2008
  • Larry Foster Nov 30, 2008
    Include your model # and I'll try to help you. Thanks
I have a PFSS5PJXCSS French door with bottom freezer GE Profile refrigerator. Was making an awful noise and both fridge and freezer were warm. I opened back panel of freezer to find ice everywhere,...
Had similar problem, freezer was working fine, but fridge was warm, (68 degrees) It wasnt my damper, the mother board was fried, and so was the inverter board that told the compressor what to do, after having the inverter and two mother boards replaced.......I threw it out, biggest piece of ****, only three years old, and Sears would not stand behind it, even though I used their repairmen. I will never buy another GE product, or enter a Sears store again
Jun 03, 2011 | GE Profile PDS20SFS Bottom Freezer...
Fisher & Paykal Refrigerator. E 522 B Plastic piece in door hinge fell out . Door now travels around and has big dent in front panel. I need to replace outer stainless door panel and plastic piece in...
The plastic piece that is moulded to the inner door that holds up the shelf on a fisher & paykel fridge has cracked and no longer holds the shelf. Can I buy a new door liner or does the whole door need to be replaced?
Jan 29, 2011 | Fisher and Paykel E522BRXFD Stainless...
The freezer has stopped cooling...meaning the fridge has stopped too. The fan continues to run, but blows warm air. Twice before the fan had frozen and stopped blowing the cold up to the fridge...we had...
replace the p.t.c. overload on the compressor body of the units compressor in the rear lower end of the unit,its not letting the compressor start and then not cooling
Jul 25, 2010 | Amana AFD2535DES French Door Refrigerator
Ice forms around fan and makes a loud humming noise
It's probablly caused by air leakage through the ice room fan electrical connection inside the freezer. Behind the back wall inside the freezer, the icd fan is the fan that blows air up to the in-door icemaker. The plug on that, into a molded plug on the back of the feezer compartment, is a red plastic part with three wires in it. Try filling in around the wires and the red plastic with a bit of silicone. (if you replace the ice room fan, the new plug comes with a rubber filler which seals this spot). (PS. Next time, avoid Sears)
Mar 31, 2010 | Kenmore 77554 / 77543 Bottom Freezer...
Freezer on bottom, cold, fridge not cold,ice on
Probably the difusser door that allows cold air from the freezer into the fridge portion, either stuck or control dial faulty
Aug 22, 2009 | Refrigerators
I have a Whirlpool Gold Conquest Mod# GS6shexnt00 side-by-side. About 18 months after buying it the refrigerator section stopped getting cold but the freezer section still worked even though it had iced...
Yes, the difusser door is not allowing cold air to enter the fridge section, a fridge freezer is actually just a freezer, some of the cold air is drawn off from the freezer to chill the fridge protion, if the door is stuck, broken no cold air is getting to the fridge section
GE side by side refrigerator. Fridge side not cooling - help!
Hi, they have changed lots of parts, were they defected, did they tested parts for faults or they just change parts, because it's available, there's always a reason why a certain part, go bad. so far you change most of parts in ref. check refrigerant (gas, freon) pressure, check compressor, for faulty suction and high side valve, it's possible your compressor loosing efficiency. or say if compressor normally pump 50 psi. now it's pumping 40 psi. is the refrigeration cycle balance ? is there restriction in your ref. system? is compressor running long enough? plug on ref. let it run for 1hr, listen to compressor for any clicking sound, fans and everything else could be working, be compressor not, compressor could be short cycling (not working long enough) also check voltage in receptacle(outlet) with digital multi-tester, get accurate voltage reading, let me know, could also be a faulty circuit breaker in house (building) not your ref. let me know, system could have very slow refrigerant leak, you could have a very small (slow) gas leak, that's why your refrigerator get hot first, then your freezer, there's a condensate line (loop) that passes through, ref body, close to doors to prevent door gasket from freezing, after few years sometimes develope leaks, cause by rusting. it's very possible there could be small leak in your system. let me know what happened.good luck.
Aug 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
11 year old amana bottom freezer icemaker drips water when filling tray
Hello dunc444444
You said, Bottom freezer works fine, but upper refrigerator has no cold air
Is your freezer so full that it is packed to the top especially in the rear?
Refrigerators and freezers share the air from the compressor and travel through vents in the rear of the freezer and fridge.
Sometimes it can effect the cooling in the fridge if the freezer articles block the vents!
The water overfilling in the ice maker is an ice maker problem only.
When we install an ice maker there is a short white plastic tube that we push through the rear
hole of the fridge which supply's the water to the maker, the outside water line attaches to this.
That tube we push through the fridge must go in till it stops. And empties in to a little sistran at the rear of the ice maker. Make sure it did not sip out or backwards a little when you may have moved
rolled the fridge out to clean under it!
Also you need periodically to remove the front grill down in front of the fridge and gently run a refrigerator brush under the coils to clean out the dust that may block air flow over the coils.(the coils are metal black tubes that run back and forth along the bottom of your fridge.
The vacuum will not reach in to that tight space. That's why they make a special brush for this chore.
Let me know how you do?
Huuum {
Let me know.
Please remember to leave a rating.
Oct 05, 2008 | Amana ARB9059CS Bottom Freezer...
Fridge won't quit running and get cold
2 common problems that unit has. 1 is the cold controls go bad and will cause the unit to either run or not run. 2 the freezer drain gets blocked up very easy and when the freezer defrost the water has noplace to go but the freezer bottom and could block the air passages so the cold air will not satisfy the control. so check the freezer bottom by removing the plastic peice on the bottom there are 3 plastic plugs in the front that secure it and some phillips screw in the middle. you can just lift it to check for ice. if there is none replace the cold control. good luck
Aug 04, 2007 | Haier HTQ21JAAWW Top Freezer Refrigerator
Refrigerators Logo
62 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
