Question about Dell CDROM IDE 48X BLACK BEZEL 004FRP CD-ROM Drive
Dell CDROM 8245B wont read
Hi. I have a Dell Optiplex GX150 with a Dell cdrom CRN-8245B. The drive stopped responding completely, the green light stayed on permanently and the disk would not eject. I assumed this was a faulty drive, so I temporarily swapped it with a similar (but newer - 2003 versus 2001) drive from another Dell Optiplex. Now the drive can be heard spinning up to read the CD, and after initially flickering to read the disk, the read light extinguishes. However Windows 2000 pro does not detect any disk in the drive, saying "please insert a disk". I know the disk is valid because I can read it in other drives, but I have tried a couple of known good data disks and music disks to no avail. Windows reports the drive is operating normally. Deinstalling the driver and rebooting causes windows to correctly recognise the "new" device and reinstall the driver. The only other things I noticed were the BIOS setup on boot up reports "cdrom not installed", but clearly it is since windows recognises it and it spins up on disk insertion and asks me to insert a disk, so I assume this is a red herring (and the previous drive presumably would not have worked which it certainly did at one time). The connectors appear to be fine and a correctly seated on both the drive and the motherboard. No errors are apparent in the system error logs. There is a mysterious "PCI device PCI/VEN" which always fails to instal due to a lack of a driver, but I dont know what the deivce is windows is complaining about to find a suitable driver. I have assumed this is irrelevant to this problem at least. Between the original CD ROM working and then not there has only been time (drive wasnt used much), a USB multi port hub /card readers/virtual drives installed, and an external DVD burner occasionally connected which works just fine. I also notice in system properties for the drive it is expecting me to enter a region code as if this were a DVD drive. I am assuming this is due to the previous use of an external DVD drive, but I mention it just in case because its certainly not applicable to the cdrom of course. Given the above I am assuming the second drive is also faulty and Ive just had bad luck. Unfortunately its not easy to test the second drive elsewhere as the PC it came from is not usable. The only thing that would make me think otherwise is that the drive is spinning the disk up and otherwise working correctly .... and givemn teh previous drive also had problems Im wondering if it is something other than the drive ? Can anyone agree/disagree/suggest further tests etc ? Terry
  • Anonymous Feb 17, 2009
    My dell dvd rw drive module stopped responding and won't eject my disc
  • 22 Answers
Go to dell website 1. look for latest BIOS upgrade for your model 2. look for latest driver update for your cd model go to Device Manager a)look for conflicks (yellow triangle with exclamation points) b) uninstall these devices c) windows will automatically install them when you reboot Good luck!
Posted on Feb 01, 2007
SOURCE:
Does this drive also burn cd's?
Dear bobrvm ,
LG CRN 8245B is CD-ROM DRIVE you can't able to burn disk using this drive.for more specification. click on below link.
http://computershopper.com.com/cd-drives/lg-crn-8245b-cd/1707-3207_7-30086834.html
Thanks
Jun 17, 2011 | LG CRN 8245B (CRN-8245B) Internal 24x...
MY CDROM DOES NOT READ ANY TYPE OF DISK
try the following, It should help.
Go to the link below.
http://support.microsoft.com/gp/cd_dvd_drive_problems
on the page that comes up. click on the green run now box.
It will start a file download ( this file is perfectly safe as its directly from microsoft)
Once you download the file, make sure to run the file..
It will run a dignostic program that will attempt to repair and fix your broken drive!
KittyTech..
If you need further help, reach me via phone at https://www.6ya.com/expert/carolyn_427ff26936286336
Feb 20, 2011 | LG CRN 8245B (CRN-8245B) Internal 24x...
Need Driver for Dell Laptop (Latitude D600) CD drive(LG CRN 8245B)
It should be availble for free download from either the Dell website or the LG website. Just follow links for support and downloads.
Oct 07, 2010 | LG CRN 8245B (CRN-8245B) Internal 24x...
Need lg cd-rom crn-8245b driver
Hi, you need to install latest service pack for the operating system you are using.
Feb 04, 2010 | LG CRN 8245B (CRN-8245B) Internal 24x...
My lg cd-rom crn-8245b can burn cds, but it can play cds
hello mplsfanboy,
This drive is not a cd burner. It is only a 24X CD "reader". This means that it reads the cds but not write on a blank one. Here is a link to specs if you need:
http://www.dealtime.com/xPF-LG-CRN-8245B-CRN-8245B
I hope this answers your question. I thinkn you are trying to do something that is not supported by the drive.
Thanks!
mrstan
Jun 28, 2009 | LG CRN 8245B (CRN-8245B) Internal 24x...
LG CDROM drive model#CRN-8245B isnt reading cds
clean the lens of the cd drive,if still the same prblem,check another good/clean cd..if still the same...replace the lens or the cd drive.nothing else..
Jan 01, 2009 | LG CRN 8245B (CRN-8245B) Internal 24x...
Installing crn-8245b from dell to compaq?
First cheak your drive remove the jumper are not
remove the jupmer in the disk and instal any pc your drive means put as aadditional disk then it works
Jul 04, 2008 | LG CRN 8245B (CRN-8245B) Internal 24x...
Dvd - cd rom wont work
Dear friend, In your system cdrom drivers currupted for that drivers you need to install a mscdx file in drive "c" then it works fine.
Dec 14, 2006 | LG CRN 8245B (CRN-8245B) Internal 24x...
Only reads some disks.
hi try taking a air can spray with a nozzle and clean the laser eye other option is to buy a more quality CD's good luck
Mar 15, 2006 | LG CRN 8245B (CRN-8245B) Internal 24x...
Computers & Internet Logo
158 people viewed this question
Clive
Clive
Alun Cox
