Hooking up samsung tv LN32A300 tv
Have a new tv and don't know what connects to what and where they connect? Never hooked up tv, is not wall mounted. Help, need really simple information don't understand anything.
5 Suggested Answers
informatica
  • 1114 Answers
SOURCE: Connections on back of TV
You can download the manual from the link below: http://www.emersonaudiovideo.com/pdf/om/EWL3706.pdf Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Aug 16, 2007
SOURCE: how to remove the stand from samsung LCD TV
Place the tv on its screen flat on a soft surface,
you need to remove all the screws, not just the stand one marked.
Lift the back panel and then you will be able to slide down the stand, when you have removed the back cover you will also see where how your wall mount will fit to the chassis.
Place all the screws back on the back lid.
Posted on Feb 09, 2008
SOURCE: Remove base of Insignia ns-ltdvd26-09 lcd tv for wall mounting
Open up the panel on the back of the TV which covers the various input connections. At the bottom of the area previously covered, there are 8 screws (two rows of four screws). Remove them, and the entire stand should now slide right out of the TV. You can then replace the screws back in their holes, so you don't lose them. You do not need to disassemble the stand to do this.
Posted on Aug 18, 2008
  • 125 Answers
SOURCE: trouble with speakers (Samsung 2.1) to 52" sony bravia lcd
that is the simplest way. please rate, thanks and have a good day
Posted on Aug 25, 2009
Testimonial: "very fast, thanks for the help!"
Hooking up older Samsung TV to Roku and Dish devices.
If there are not the proper connection points then you are stuck you need to buy a new TV
Sep 04, 2016 | Roku Televison & Video
I have a Samsung LED TV Ln32a300 with a Broken Screen or Panel is it possible to fix?
Broken panel need to be changed. The price of a new panel is often more expensive than new TV.
Aug 13, 2016 | Samsung Televison & Video
I own a Samsung DLP 56" TV for which I purchased a swivel wall mounting bracket that holds up to 160 Lbs of weight. However when looking at the back of the tv set and the such smal size screws that...
Yes it will hold,the wall mount u bought it design for weight of 160 LBS and 50"-60" screen sized right?Just make sure hook up the wall mount on and over a wall area with strong woods beams supports have many fours by fours woods beams lumbers to take off the stress of the holding of the tv by those screws alone of the screen frame screws supports only.
Jun 30, 2011 | Samsung HL-T5676S Television
I want to know how to connect my lcd 32" tv to my new ht-c550 so that i can watch tv and listen to the sound of the tv through the surround system, what do i need to plug and where?
Not enough info here. But basically, the Audio Out from your TV (could be Toslink fiber-optic or Digital Coax or just Red and White Audio cables) go into the receiver's inputs (either TV, or Aux or whatever). If you just use the Red and White cables (stereo), you will not get true surround sound though. Just put your receiver on whichever one you hook it to (ie: Aux) and whatever sound is on the TV will come out the Stereo or Surround Sound. It's all a matter of hooking TV out to Stereo IN. Hope this helps; James
Apr 17, 2011 | Samsung Audio Players & Recorders
I cant get my tv to get the regular cable channels. i just hooked it up to a new connection, it has no digital box, it runs straight through the cable. ive done the channel search and i dont know what else...
If your TV has a menu button, go into the menu and try setting the input of the TV to the jack that you connected your cable to. Sometimes the TV will not check all the inputs and just does the default one when you do the auto-tune search function to find the active channels. Also, check to see that your wall receptacle is actually hooked into your active cable TV line. You should have a splitter somewhere in the same line that your other TV is using. If not, that jack that you are hooking up your new TV to is probably not active.
Jan 01, 2018 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Samsung tv wall mounting
For a true flush mount installation, you will need to recess your connections (i.e. power, HDMI, S-Vid, etc). Most tvs have the connections coming out of the bottom to allow flush mounting.
If your wall is not drywall, or you really don't want to bother with the expense of recessing your outlets and cable connections, just get a swivel arm mount. It will allow the TV to sit a bit further from the wall and still look ok.
Go to www.monoprice.com for great deals on mounts. I have 3 of them in my house and they are excellent quality.
May 22, 2009 | Samsung LN46A650 46 in. LCD HDTV
Help hooking a dvd player to a tv
  • have you try to hook the rca jacks to the tv they should be color coded red, white, yellow, yellow is the video, red and white is audio. same as hooking to tv box.
Mar 24, 2009 | Panasonic DMR-E30 DVD Recorder
Hooking up TV Guardian with Samsung HT-SK5
Just purchased system, didn't come with any speakers, but when hooked up to tv get picture and no sound unless I put headphones in.
Jan 07, 2008 | Samsung HT-SK5 System
Televison & Video Logo
59 people viewed this question
Top Televison & Video Experts
