Question about Remington Titanium SmartSystem R-9500 Electric Shaver
Cleaning mode not pulling cleaning fluid up into chamber for cleaning process
When activating the clean mode the system goes through its cleaning cycle but is not drawing the cleaning solution (oil) up into the chamber housing the razor head. Consequently, the shaver remains uncleaned. (This unit has worked fine for about 5 months previously. The cleaning fluid has routinely been changed monthly. However, during the most recent replenishing of the cleaning fluid, the old fluid came out an unusual brown, almost rusty, color).
  • 1 more comment
  • djfixerup Jan 17, 2008
    I have had the same problem with 3 units. They seem to last for about 5-7 months before the, what I think is the, pump stops working which pumps cleaning fluid from the base and into the head in order to clean it. When the first one broke I contacted customer service and they sent me a new replacement. After the 2nd one broke I again contacted customer service and they sent me another. When the 2nd one stopped working, the fluid pump, I contacted customer service and they never got back to me. I'll try again soon and see if I can get a response. I agree that this is certainly a Remington defect and they should recall all of these units and provide replacements that have been fixed properly.
  • jcamous Apr 29, 2008
    I have had shaver for about 6 months and I am also experiencing the same problem.  I am waiting for remington to get back to me for warranty replacement.
  • jt007 Dec 19, 2008
    2 year warranty and mines like 4 years old and i have no receipt it was a gift so i think im in trouble im having the same prob motors runs but razor wont get clean.
I have had the same problems as others have posted. upon inspection I have found that Remington in the assembly process use wiring for the cleaning unit, that is exposed to the cleaning solution. If you remove the base head for refilling, you will notice on the motor head, some fine wires running along the sides. If these break, become damaged, or corrodided, problems will occure. Depending on the break of which wire, will reflect on the charging of the unit, or the cleaning motor. The rust color is a result of the solution used having corrosive action on the wiring.
Posted on Sep 09, 2009
    Problem Solver:
  • 6 Answers
I had this problem with my Razor also. I took the cleaner apart and found the shaft from the motor to the impeller snapped. I have been unable to find any replacement parts anywhere. I guess it is cheaper for them to replace the whole unit each time than provide a new motor. Thats too bad as I liked the way it cleaned and blew the razor dry. So I bought a Norelco.
Posted on Mar 11, 2008
I have had the same problem.I sent an e-mail to Remington and they sent me a whole new unit including the shaver and accesories.Problem is the replacemant is doing the same thing again as the first unit.I got it for x-mas and am getting ready to contact remington for a 3rd unit,it is only June. What I am doing now is changing the fluid and filter and tip the unit forward to bring fluid in to the head cleaning chamber.It's half ass way to have to something,but Remington does have a problem with this and needs to recall or replace with an upgrade when available
Posted on Jun 02, 2007
My abs and brake light keeps coming on and off onnam2005 Buick Rainier cxl 2wd 4.2l with traction control
check: fluid level, brake reservoir filler cap for proper fit, brake level safety switch connection wires on master cylinder or reservoir cap that they are snug. If those are ok the brake light suggest an intermittent failure in the primary chamber when fluid is bypassing the seal. This is usually a accumulation of debris on the floor of the chamber. Changing the fluid is a start which should include a removal of the master cylinder, extracting the piston and inspecting the interior of the cylinder for sludge. clean out the sludge avoiding scratching the cylinder walls. reassemble, reinstall and bleed system. The ABS is likely related to the primary failure and should clear. The ABS light is likely telling you that the brakes are unevenly being applied and that the ABS diverter is being activated--as it should be.
Sep 17, 2017 | Buick Cars & Trucks
My 541t remington doesnt feed shells well and wont extract empties.
Second time on this one snce my last seems to have disappeared.
You can check the extractor on the bolt face for the second prob, be sure it's good and not snapped off, but your probs are classic fouled chamber stuff. Remove the bolt and remove the action from the stock and then really soak the chamber in some sort of cleaning fluid. Brake cleaner, transmission fluid, Hoppes or Rem Oil, or WD40. Soak the chamber and let it sit a bit. Then use a brass or bronze bore brush and scrub the chamber out well. I sock my cleaning rod into my power drill and use it to spin a brush really good in the chamber. WD40 or oil it and swab it out well and clean and lube as usual. Be sure to clean the feed ramp.
Oct 18, 2016 | Optics
Torn down Yard Man wont start
Fuel related if you can get it to fire with starting fluid.
May 12, 2013 | Mtd Garden
Nissan pathfinder 1996 engine does not turn off
Excess carbon build in your cylinders ,your engine is hot even if the gage in normal rings worn out no seal engine oil to the chamber ,change your fuel to high octane plus one injector cleaning fluid clean your air filter fit one set Iridium spark plugs set the timing give time 250 k for clean up your cylinders check your cooling system and flush fit new thermostat and radiator cup and antifreeze fluid.
Sep 21, 2012 | 1996 Nissan Pathfinder
Nebulizer is not providing mist..checked tubes and cleaned air filter..what could reason be?
There could be some dried fluid inside the tubes or medication chamber. Try cleaning the tubes really well even if they look clean and try cleaning the medication chamber with distilled water (better then tap water because it has been cleaned of all impurities), raise it out with warm distilled water (warm is better then cold to try to dislodge any dried medication), microwave the water to warm it up.
If that does not clean the medication chamber try boiling the medication chamber in a pot for 3 to 5 minutes in distilled water.
PS for the tubes use the warm distilled water.
I hope this helps you out!
Jan 01, 2011 | Health & Beauty
My philips jet cleaner doesn't work anymore!! when i put the shaver onto it, the cleaning chamber empty symbol start to flash and then stop cleaning!!! i fill the cleaning chamber with braun cleaning fluid...
I have had 3 1050CC shavers all with the same problem. Apparently other models have the same issue. After about a year of use, the unit reverses after dipping the shaver into the cleaning solution for a second. Two were replaced by Philips within the 2 year warranty period. I still use the 3rd one. There are several things you can try. If the cleaning solution is low this will cause the shaver to reverse and not clean. Add more cleaning solution. I have noticed that sometimes I have to add more fluid to the unit after a week of use. Sometimes it is necessary to fill the solution a little above the max fill line. Be careful though. Filling it too much above the max fill line can cause cleaning fluid to run out of the bottom after a cleaning cycle. If the above two fixes don't work, then press the clean button and after the unit reverses back up, wait about 5 or 10 minutes and press it again and it should stay down as long as there is enough cleaning solution in the unit. If you wait too long or too little to press the button, it won't work. I have noticed if I press the button immediately after it reverses the same problem occurs. Also if I wait 30 minutes before pressing the button the same problem occurs. There must be some sort of timing cycle. You may have to repeat this process a few times to get it to stay down and clean. This is the only way I can get mine to clean now. Obviously something is getting dirty or wearing out over time in the cleaning system. Since I have had 3 shavers with the same problem, I know many others have had it too. Philips must be aware of the problem. It is frustrating that they don't offer help on their own website and consumers have to band together to solve problems that they should be solving. The two year guarantee is very generous, but there is a design flaw with this product.
Aug 09, 2010 | Norelco Arcitec Electric Shaver with Jet...
C86 Goes through printing process but nothing prints.
Have you carried out 2 or 3 head cleaning cycles? If not, do it. Is there ink on paper now after this cleaning? If so, but it is streaky, leave the printer for 24 hours and repeat the head cleaning. If not, you must soak the heads for at least 24 hours - use print head cleaning fluid or distilled water NOT TAP WATER. Proceed as follows:
Turn the printer on, and as soon as the print head starts to move, pull the power lead out of the printer, or turn it off at the mains. The print head should now be free to move by hand. Move it out of the way to the left. On the right you should see the print head parking area. There is a rubber cup that is designed to fit under the print head to keep the ink from drying out. Using a syringe or dropper, fill this cup with print head cleaning fluid. Then gently move the print head as far as it will go to the right. The print nozzles are now bathed in print head cleaner. Leave it for at least 24 hours, then repeat the cleaning cycle process.
Jan 28, 2009 | Epson Stylus C86 InkJet Printer
350 HUSQVARNA HAS SPARK WON'T START
Clean air filter and try starting fluid through air intake if you have spark this will definetely start it......On the rancher , is the air cleaner clean??? Remember that all you need to make an engine run is fuel , air , and an ignition source .. When you attempted to start the Husqavrna by adding fuel to spark plug chamber this actually causes a no start or very hard start condition it will act like if flooded....What does help if you remove the spark plug pull the pullstart and ensure that no liquid (gas is coming out of chamber) if it is keep pulling until it does not.... then take your spark plug ,after you have cleaned and gapped it, and with a butane lighter heat the tip for approximately 30 seconds and then reinstall plug and give it a yank after you spray starting fluid in the air intake....Good Luck
Jan 08, 2009 | Husqvarna Chain Saw 20" Bar
A Dell PowerEdge Server will not start. The server goes through the boot sequence, but after a while there is no activity. OS: Windows 2000 server
This sounds like a RAM issue or a strange peripheral problem (when the driver loads it kills the system). Try running the system on only 1 stick of RAM at a time, swapping until you find a bad stick. Also, clean the contacts off with a pencil eraser before putting them in.
If this doesn't help, pull PCI cards one by one (except for the RAID card, if any - but do pull out, clean and put back in the RAID card just in case it's a contact issue) at a time until the system boots (or just try safe mode, but this won't tell you which one is a problem).
If the system still can't boot, then I'd say it's probably the motherboard.
Jan 06, 2009 | Dell PowerEdge 2600 Server
Blue and green bulbs look like they have sawdust in them
Tubes need to be removed from set. Take off front lens with 4 screws, then remove the glass circle. Has a gasket, becareful. Do this over a sink. The fluid is a clear anti-freeze. Clean inside with Formula 409 and paper towel. Rinse with water and dry. There is a plastic expantion chamber on the side. Pull that out and clean it too. Put the tube back together. Note where the wingnut was when you took it apart and oriantate the lens to go in the same way. You can use a turkey baster to refill the tube through the expantion chamber opening. Fill it up as much as possable. Put chamber back on. Put tube face down for awhile and check for leaks. That round gasket can be reused sometimes, but check it first. Then put it back together and that's it. You'll have to unplug the board on the end of tube and the ground wires. Then unplug 2 seperate plugs...one for the yoke and the other for the convergace. Make sure you mark the wires you take off and the way the tube came out. Everything must go back the same way it came out. Fluid can be purchased at MCMelectronics.com Only need to do blue and green. Red never goes bad. Do one at a time. That's about it.
Dec 22, 2008 | Philips Magnavox 51MP392H Rear Projection...
Remington Titanium SmartSystem R-9500 Electric Shaver Logo
411 people viewed this question
Top Remington Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Jerry Greenberg
Jerry Greenberg
Stan Sexton
Level 1 Expert
Are you a Remington Health and Beauty Expert? Answer questions, earn points and help others
